BYAHHHH!
2001 Mustang GT
13.874
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() iTrader: 3 reviews
Pulley Change FYI
Well as most know I was shredding belts every 2 weeks! So after checking and such I called Procharger,Shannon told me to check my pulley and when you look over your pulley you should see a rib thickness coming out on the MOTOR side. This is so the pulley is as close to the blower as possbile. When when I switched from the 4.00 pulley the 4.00 i.d was on the inside...so with the new 3.4 I thought the i.d was always on the inside. NOPE, they just stamp them on either side. So beware of this Procharger guys who may not know! Now my belts lined up in the middle of the blower idler! Procharger has an awesome customer service! They help you till you fix it!
So I hope the belts stop shredding! Now I have to worry about pipes blowing off but thats part of it! It pulls so damn hard tho guys! I got on it from 45/50ish and looked back down doin 80 and it still pulls hard! Best inverstament of time and money!I just wanted to thanks MM.com members that helped me with this install since october!(you kow who you are) and I know for sure if it wasn't for MM.com it would have not been possible! So thanks again guys/gals! Thanks, Scott
![]() Precision Turbo|TurboSmart|TeamZ|Strange|Hellion|BBK|SCT|Edge Converters|Fairbanks|CG Fabrications|Treadstone |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() iTrader: 14 reviews
glad you got it fixed bro! and for sure, Procharger is VERY helpful!
![]() 4.75 MMR 900se Livernois ported heads HP 292s blower cams Procharger D1sc at 20+ psi IW 15% OD pulley (and more bolt ons) E85 ![]() Tune/numbers coming shortly!! |
BYAHHHH!
2001 Mustang GT
13.874
I will get some vids this weds for you guys! I am going to have the tranny tune tweaked some! And get that blow pipe fixed a little better. And check over all the t-bolts again!
2011 Caddy cts, 09 Jag XJ
sweet man glad you fixed the issue! i have a reichard racing 3.2 pulley coming in and i cant wait for it!
![]() 2000 GT- Gone but not forgotten |
#5 | |
BYAHHHH!
2001 Mustang GT
13.874
I cant believe how hard mine pulleys with 359rwhp and 346rwtq...I know it more than that but the dyno doesn't read auto rear wheel with a 3.5k stall and the 4:10s very well!
Threads Similar to: Pulley Change FYI
| Pulley Change | Lind | 94-95 | 3 | November 3rd, 2008 03:36 AM |
| How do you change a pulley on a cent s/c | jam77 | General Tech | 3 | January 9th, 2008 12:39 PM |
| Pulley change? | Exseque | 2005 - 2010 | 1 | March 25th, 2007 06:42 PM |
| vortech pulley change | 2001bullitt | 99-04 | 3 | January 19th, 2007 12:09 AM |
