ticking noise
Old April 20th, 2010, 11:20 AM   #1
1999 Mustang GT
easye88 is on a distinguished road
ticking noise
i just rebuilt the 4.6 in my 99 GT, fired it up and right away noticed a ticking sound. it sounds like its coming from the top of the motor. i dont think the problem is in the heads because they are brand new factory ford heads. both timing chains, tensioners, and guides have been replaced with new ones. i've heard that a bad injector will make a ticking sound. how can i check the injectors? any other suggestions?
Old April 20th, 2010, 11:22 AM   #2
Spurred Snake's Avatar
2003 GT & 2003 Cobra
Becoming a corner junkie...
Spurred Snake is a jewel in the roughSpurred Snake is a jewel in the roughSpurred Snake is a jewel in the roughSpurred Snake is a jewel in the rough
Headers make a ticking sound and Fords are bad about getting them. I got some new shorties for right around 300$. Your GT will run better, LT's are harder to install, but it will be better if you like the deeper sounds...
Formerly known as SVT_WANNABE
MILITARY CREW - E-3 - ARMY
ANTI-RICE Founder
*My YouTube Channel*
http://www.youtube.com/user/PS3Turbostangs?feature=mhee
There is nothing SVT can teach me about jizz and swallowing, I assure you
Old April 20th, 2010, 11:26 AM   #3
1999 Mustang GT
i put a set of ford racing shorties on it, sounds mean as hell all except for the ticking sound lol where would the ticking sound come from if its coming from the headers? around the gaskets?
Old April 20th, 2010, 11:27 AM   #4
AndrewA.'s Avatar
2001 Mustang GT
8.9@78
AndrewA. will become famous soon enough
Might be a spark plug? Check to see if they are all tight.
Fire it up, burn it down.
Old April 20th, 2010, 11:28 AM   #5
1999 Mustang GT
will do that...any advice on how to check the fuel injectors tho?
Old April 20th, 2010, 11:29 AM   #6
If they are brand new, yes around the gaskets, see if any of the bolts are loose... Stock manifolds tend to crack and break right where the piping into the weld. Metal heating, cooling, heating, cooling, will eventaully wear out. It expands and shrinks in other words.
Does the ticking stop when your car warms up?
ANTI-RICE Founder
Old April 20th, 2010, 11:32 AM   #7
1999 Mustang GT
svt wannabe...the ticking does not stop when the motor warms up...the first thing i checked was the header bolts because i first thought it was an exhaust leak, but all the bolts were tight...
Old April 20th, 2010, 11:36 AM   #8
Are the gaskets new also?
ANTI-RICE Founder
Old April 20th, 2010, 05:01 PM   #9
bigz5000's Avatar
1998 Mustang Cobra
bigz5000 will become famous soon enough
Take a peice of hose about 3 ft long, and put on end to your ear and move the other aroung where you think the leak is coming from. It will be obvious when you find it. If you still are not sure, take it to a local muffler shop and have they will check it out for free. I would guess it to be your header gasket, if thats the case when you replace it, make sure to use a copper, or some sort of metal gasket. While your doing that, you should probally order a set of Stage 8 locking bolts to prevent the bolts from ever coming loose they are about $50.
Good Luck
MMR Built Short Block, Vortech V1 Supercharger, AIS Methanol Injection, BBK LT's, X Pipe, Flowmasters, Steeda Springs, Tokico Shocks, Spec 2+ Clutch, Tri Ax shifter, 4:10's, SCT Tuner
Old April 20th, 2010, 07:20 PM   #10
unblock is on a distinguished road
i dont wanna high-jack this but my car tick when its cold land when it warms up it kinda disappear could it be the manifold gasket or manifold themselves are cracked? it only do it from the driver side
Old April 20th, 2010, 09:14 PM   #11
JerseyTrueBlue's Avatar
2001 Mustang GT
JerseyTrueBlue has a spectacular aura aboutJerseyTrueBlue has a spectacular aura aboutJerseyTrueBlue has a spectacular aura about
Easy, get a video man. There are so many ticks, clicks, and other strange noises that a motor can make, trying to diagnose is much easier if we could hear the problem ourselves.
True Blue Crew Member #2
315's Crew Member (Dat azz)
255/298
Founder of the please leave my signature alone, I want it to say what I put there and don't appreciate you deleting it club
Old April 20th, 2010, 11:49 PM   #12
Exhaust leak without a doubt... Your manifold is cracked. A small crack though, metal expands when heated and shrinks when cold. When your header heats up the metal expands and almost closes the crack (thats why you still hear the faint tick). You need to get them fixed, they only get worse. Metal expands and contracts so much then its very flemzy. I'd recommend looking around for headers on AM. I got mine for under 300. LT's would benefit you the most though...
Drivers side is VERY easy to take off, only thing you have in your way is the tranny dipstick...
ANTI-RICE Founder
Old April 21st, 2010, 11:35 AM   #13
1999 Mustang GT
i actually found the problem to be a bad fuel injector..i checked all 8 with an ohm meter after finding out they were supposed to read 10 to 18 ohms and one of them were bad..replaced it, and now the tick is gone...thanks to all who responded
Old April 21st, 2010, 11:55 AM   #14
nathanielwilliam's Avatar
2001 Mustang GT
nathanielwilliam is on a distinguished road
I'm sure you've checked this but do you have enough oil / the right oil in it? ticking can also be caused by your valves not having oil on them.
2001 Mustang GT
short throw shifter
4:10 gears
3 inch dual exaust (no cats!)
I have an F-150 which I drove the balls out of for seven years. Now I have a mustang that I drive the balls out of also.
Threads Similar to: ticking noise
Ticking noise cbasmas 99-04 33 October 13th, 2008 03:46 PM
Ticking Noise? 99Rumblebee V6 Mustangs 3 September 27th, 2008 12:08 AM
ticking noise tweeters97 96-98 2 March 16th, 2008 09:31 PM
ticking noise 1 SNAKE 3 V6 Mustangs 19 February 14th, 2008 06:03 PM
Ticking Noise nathom05 99-04 0 December 17th, 2007 07:57 AM
