#41 |
2001 mustang gt & 86 gt
9.84(86stang)
vht can do the trick lol
White Mustang Crew Member #8 2001 white mustang gt- exhaust, intake, 96k 1986 mustang-shootin for 9.8 this year, will have vids soon
#42 |
12.88 @ 109.45 N/A
![]() ![]() ![]() ![]() ![]() ![]() iTrader: -1 reviews
Good suspension and DRs will do the trick. Hooking on or off the track isn't gonna happen with 450rwhp, stiffer lowering springs and street tires. At the very least get a wide set of DRs that have a decent tread pattern so you won't be sliding all over the place in the rain.
#43 |
2002 GT, 1989 GT, 1984 GT
maybe i'm wrong or just dont know but couldnt you just detune the beast a little bit when on the street?? get rid of some of that rwhp??
#44 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() iTrader: 14 reviews
^no, thats not how it works. lol.
![]() 4.75 MMR 900se Livernois ported heads HP 292s blower cams Procharger D1sc at 20+ psi IW 15% OD pulley (and more bolt ons) E85 ![]() Tune/numbers coming shortly!! |
#45 |
Just sell it and get a Prius
My Car- 2004 Mustang GT Her Car- 2011 V6 Auto Premium Saving up for either a 2009 Shelby GT500 or a 2011 5.0...Can't decide! |
#46 | |
12.88 @ 109.45 N/A
You actually could pull a bunch of timing out and make much less power, but why would you want to do that? The direction he should be heading is figuring out how to plant the power he does have. |
#47 |
02 Mustang GT
9.91@133
Why do you "NEED" traction through 1st on the street??
2002 GT PI heads Twin 60mm turbos Th400 6.34@114 1/8 9.99@137 1/4 http://i160.photobucket.com/albums/t...t/DSCF5654.jpg http://i160.photobucket.com/albums/t...2gt/IMG060.jpg |
#48 |
what size tire are you running OP ?
if your already wearing 315 in the back then completely disregard my question but if your not. you should probably get some.
#49 |
BYAHHHH!
2001 Mustang GT
13.874
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() iTrader: 3 reviews
So people run street tunes and have track tunes too. But thats not your avarage car
![]() Precision Turbo|TurboSmart|TeamZ|Strange|Hellion|BBK|SCT|Edge Converters|Fairbanks|CG Fabrications|Treadstone |
#50 | |
12.88 @ 109.45 N/A
That being said, that's not what this guy needs. 450rwhp is very streetable when you are running the right setup for that amount of power. He isn't gonna be hooking any better on the track, actually most likely much worse if he doesn't get a good set of tires and maybe some suspension to back up that power. Also, why do you need to go WOT in first or second gear with 450rwhp on the street anyways? It's not like half throttle won't pull harder than most every car around you, and you won't be sliding all over the place. I have daily driven +420rwhp on the street with street tires for like a year and a half. You just learn that on street tires, you will smoke the hell out of the tires in first or second at past half throttle. If that's not what you want, then get some better tires. Last edited by tbirdscwd; April 21st, 2010 at 11:24 PM. |
#51 |
lol. I knew it! Let me know when you plan on going again. I can't run until I get the rear end fixed, but if it's fixed when you go I'll try and stay with you on the track.
![]() Black Stang Crew #007 Car Built By Me and CraigsList.com Mods: MGW, Bassani Catted X, Flowmaster's, Accufab 70MM TB, Stack Racing Plenum + spacer, JLT CAI, Diablo Tune, Slotted rotors + ceramic pads. More to come! I hope.
#52 | |
12.84@108
![]() iTrader: 4 reviews
And before anyone says anything about the 400 N/A, I already know it is almost "IMPOSSIBLE" on a 2V, but I think I have a real chance with the set up I got going.
![]() MMR 950 Stroker TFS 38cc Heads MHS TFS N/A stage 3.5 cams 11.5:1 compression Nitrous Express wet kit 12.84@108 2.0 60' on motor. race weight was 3750lb 354whp 330wtq motor, 480whp 500wtq 150shot. Proud Iraq and Afghanistan Vet |
#53 | |
12.88 @ 109.45 N/A
#54 |
To the op. Get some good adjustable shocks/struts they will help. I've tried the softer 4cyl springs in the back of my car and I can tell you right now they didn't help me at all. If your car squats hard enough to bounce in the rear like mine is doing then you'll just unload the tires(and I run full slicks) right after the launch. Is the car launching straight? If it's twisting to one side real bad that can also cause a loss of traction. A good axle/body mounted sway bar would help that or if you don't mind the extra noise an anti-roll bar would make dam sure it launched straight. Oh and the only dr I've ever had that was good in the rain was the nitro 555r's and they drove just like a street tire in the rain. But if I were you try the nt05r's they seem like they'll be the happy medium that everyone will end up using.
79 Buick regal 13.70 @102 350 sbc 97 Trans Am WS6 11.94 @112.26 1.603 60ft @Kcir 04 SRT-4 13.42@113.55 2.37 60ft ![]() 04 Mustang GT 12.19 @111.88 347hp 432tq 100 shot 06 Mustang GT 12.2929@114.30 2.01 60ft MM Bracket Racing Crew Member #4 |
#55 | |
The Mean Green
![]() But ya man, Sticky tires will make the most difference outta anything...
#56 |
12.73@111.36
What gears are you running?
ProCharger P-1SC, 9 psi, STD 396/383; Uncorrected 388/375; SAE 383/370 Mods list in Garage. |
Threads Similar to: These cars suck !!!!!!
| Muscle cars = sport cars?? | Mistertribal | The Clubhouse | 40 | May 19th, 2010 07:07 PM |
| Suck On This! | TheUNZippee! | The Clubhouse | 41 | August 16th, 2009 10:08 PM |
| This would suck. | Imran | The Clubhouse | 14 | June 17th, 2009 01:41 AM |
| Muscle Cars Vs. Compact Cars?? I Need Help Deciding.. | Hunt_chevs | The Clubhouse | 12 | June 3rd, 2009 09:34 PM |
| This Would Suck | acehole | Videos | 6 | December 21st, 2006 07:17 AM |
