Anyone who has degreed the SOHC motor GET IN HERE!
Old April 20th, 2010, 11:23 PM   #1
2003 Redfire Mustang GT
before new mods - 13.60@101.40
OH03GT will become famous soon enough
Angry
Its not the timing or degreeing that im having the problem with. Its getting T.D.C.. The process is simple u put the degree wheel on the crank n turn the motor over by hand - yea i get that - I turn the motor clockwise and everythin is fine, i got to turn the crank counterclock wise and the crank bolt loosens up! I cant for the fucking life of me get the motor to turn counterclock wise without the crank bolt backing its self out of the crank. I have alread had problems gettin the bolt tight (ie: stripping the crank bolt on the first few threads) cleaned out the threads in the crank and got a new bolt, n the same thing happened! i either get it tight n the degree wheel wont move or its too lose n turning counterclock loosens it up! ANY SUGGESTIONS!?!?! i would use a Crank Socket, i have looked around n seems there are none for our crank. maybe im wrong tho. REPS TO WHOEVER HELPS!
MY GARAGE
MM Bracket Racing Crew Member #2
Originally Posted by Scott2001GT View Post
mmmmm went from wanting to see a chicks picture to dick measuring...MM.com
Old April 21st, 2010, 09:24 AM   #2
bump
MY GARAGE
Old April 21st, 2010, 09:40 AM   #3
tattoo junkiee's Avatar
96 mustang gt
tattoo junkiee is on a distinguished road
Send a message via ICQ to tattoo junkiee
if you dont have to turn it back far you could just stick a prybar in it and move it thats how i held mine still so i could loosen the boltbut be carefull not to put to much pressure on it or ya might break something
Old April 21st, 2010, 09:41 AM   #4
BakerFX4's Avatar
BakerFX4 has much to be proud ofBakerFX4 has much to be proud ofBakerFX4 has much to be proud ofBakerFX4 has much to be proud ofBakerFX4 has much to be proud ofBakerFX4 has much to be proud ofBakerFX4 has much to be proud ofBakerFX4 has much to be proud ofBakerFX4 has much to be proud ofBakerFX4 has much to be proud of
iTrader: 14 reviews
I just did mine but i didnt have a problem with that when i built it. but the bolt all the way in till it starts turning the crank. Then give the ratchet a quick jerk as an impact would do to get it just a lil bit tighter. then get the crank where you want it. When finished give it the quick jerk to loosen it.
Make sense?
4.75 MMR 900se
Livernois ported heads
HP 292s blower cams
Procharger D1sc at 20+ psi
IW 15% OD pulley
(and more bolt ons)
E85
Tune/numbers coming shortly!!
Old April 21st, 2010, 09:44 AM   #5
yea makes sense, but like i said when i do get it tight enough to turn it the other way, its too tight to move the degree wheel.
MY GARAGE
Old April 21st, 2010, 11:13 AM   #6
Proud American
MustangMatt96GT's Avatar
Its going to take longer, but just spin the crank clock wise the whole time til you are on the other side of TDC. it will take a little longer, but it will work for you.
Take some loctite and put it in there... when you need the bolt back out get a breaker bar and a torch, heat the crank up and take it out...
RIP Travis Billings
Special Thanks to:
Andrews Racing Transmissions
Baseline Suspensions
25.3 SFI Chassis Build
Never Lift Racecars
Old April 21st, 2010, 12:07 PM   #7
April 2012 ROTM
wishIhada5.0's Avatar
2002 GT, True Blue, Stick
wishIhada5.0 is a jewel in the roughwishIhada5.0 is a jewel in the roughwishIhada5.0 is a jewel in the roughwishIhada5.0 is a jewel in the rough
Send a message via AIM to wishIhada5.0
if you use blue lock tite you wont need a torch
True blue crew founder/member #1
378/442 rwhp/rwtq*on a Mustang dyno* cams are in..#'s coming this summer
Old April 21st, 2010, 12:13 PM   #8
13.2
Mustang02gt is on a distinguished road
I just rebuilt my 4.6 and after finding tdc and getting my cams in time, or any time id turn the crank id put my car into gear (5 speed) so the was resistance going against the motor as i tightened the crank bolt with my breaker bar, once i got it fairly tight I would put it back in neutral to check for clearance and then back into gear to break the bolt loose again.... but i also didnt use a degree wheel for tdc
Old April 21st, 2010, 12:13 PM   #9
limited's Avatar
99 limited edition vert
limited is a glorious beacon of lightlimited is a glorious beacon of lightlimited is a glorious beacon of lightlimited is a glorious beacon of lightlimited is a glorious beacon of light
I used an impact and the proper length bolt, when you roll over to the stop then back to the stop(your using a stop?) then loosen bolt with impact and turn wheel to split difference and retighten.
also if I remember the pulley is keyed and if you can get a cresent behind wheel, just open wrench just enough to go over crank(tight fit) and when you turn wrench against key it will turn/hold engine...make sense?
KB'd 446rwhp/451rwtq, Mustang Dyno http://www.youtube.com/watch?v=3ZDpQ0EEm1M
Tuned by Joe at http://www.tricktuners.com
Threads Similar to: Anyone who has degreed the SOHC motor GET IN HERE!
best motor oil for a supercharged sohc? wahoo09 99-04 11 May 7th, 2009 06:58 AM
sohc to dohc svt cobra motor John's_stang 99-04 4 March 24th, 2009 01:30 PM
DOHC motor and SOHC computer zerofx150 99-04 4 June 4th, 2007 08:47 PM
96 sohc swap to 04 terminator motor 1quick96 Modular Mustangs 3 March 20th, 2007 05:49 PM
SOHC to DOHC motor swap Invictus 99-04 15 March 12th, 2007 12:08 PM
