needing injectors, questionSSSS
Old April 21st, 2010, 09:57 PM   #1
2004 mustang gt
american_muscle is on a distinguished road
Hea, the time has come and my head and cam swap has finally caught up with meand my car seems to be running a little lean (starts up rough and dosent run QUIT like it had). Weird thing is that is doing it now....back in the winter months it ran fine/awesome. Change in weather have anything to do with it? Anyway, I am going to upgrade my injectors and am to NOT upgrade too much, was thinking about 24 lbs'ers. Here are some questions I NEED answered:
1) The car has PINK toped injectors with the letter D on them, are they 19 lbs?
2) If I change the injectors will I have to change the MAS as well? I have a granetelli 95mm calibrated for 19lbs....will the computer recalibrate the air/fuel mix?
3) Will I need a bigger pump, or just a bigger regulator?
I know I am forgetting something..... Anyway. Tell me what yall think, thanks!!!
Old April 21st, 2010, 10:01 PM   #2
ajm
I doubt you need new injectors but anything is possible. Did you get it retuned after the heads and cams? If not thats why its running lean.
Threads Similar to: needing injectors, questionSSSS
Needing Some Help with the 3.9 d3f4c3d V6 Mustangs 13 March 6th, 2009 07:11 PM
Needing some opinions Hess 99-04 36 October 29th, 2008 01:44 PM
needing some help on my 87 gt 87gtmustang 5.0 Mustangs 9 October 26th, 2008 07:11 PM
problem needing help Dennis 96-98 8 July 22nd, 2007 04:49 PM
still needing help!!! jerb43 96-98 4 December 21st, 2006 07:03 PM
