battery light prob
this car just started doing this.the battery light keeps coming on and going off.it stays on from around 1 min to 10 mins give or take.battery and alternator is good,what else or where should i start to fix the problem
'01 Gt Vert auto
13.2@103.8 n/a Stock stall
that happens to mine all the time had battery and alternator checked and there both good
2000 GT
I would start by checking all your grounds, and free testing for alts have been known to not be completely accurate.
2000 Black convertible GT: KB 15psi, and other goodies... ![]() 1971 Datsun 240 z: Header and rebuilt motor. (The DD) |
well i had advance auto to check it and then when the light came on i unhooked the battery while the car was running and it never quit so i guess ill start checking ground.where is the most common place for the bad grounds?
2000 GT
Clean them all. Factory has grounds to the painted metal (bad to begin with). 3 under the hood. Main ground leads to the oil filter (near there), and then branches off to k member. Clean them all, or file them down. Both connector side and on chassis.
Also there are an additional 2 in the car on the passenger side. One on the left, under the dash by radio. And one in the kicker panel by ecu. But these grounds are the least problematic since inside the car, they are not exposed to the elements.
2000 Black convertible GT: KB 15psi, and other goodies... ![]() 1971 Datsun 240 z: Header and rebuilt motor. (The DD) Last edited by RyanGT; April 22nd, 2010 at 12:57 AM. Reason: grammer error |
#6 | |
1992 Mustang GT
auto-X only
oh and listen to Ryan's advice. |
Threads Similar to: battery light prob
| Battery Light | christovofdunn | V6 Mustangs | 10 | August 9th, 2010 05:05 AM |
| Weird battery prob... | suprajay79 | 99-04 | 3 | August 4th, 2009 05:46 PM |
| battery light? | ZoomZoomMFer | 99-04 | 6 | April 16th, 2009 12:02 AM |
| Battery light | DblAughtGT | 99-04 | 0 | April 13th, 2009 11:05 AM |
| Battery light | AnFking6908 | V6 Mustangs | 2 | June 1st, 2008 08:54 PM |
