Help with FMIC install please!
I'm currenty installing my CxRacing intercooler kit, and i'm curious on where to cut the fender to run the pipe up in the fender and to the upper plenum. If anyone has pictures or advice please let me know, it would be greatly appriciated!
![]() Check out my garage... 2000 Crystal White GT Vert ![]() 1996 Black GT Coupe-SOLD |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() iTrader: 14 reviews
shouldnt have to "cut it" unless you have a powerpipe or something else using the hole in the side of the inner fender. piping should just route up into the engine bay.
![]() 4.75 MMR 900se Livernois ported heads HP 292s blower cams Procharger D1sc at 20+ psi IW 15% OD pulley (and more bolt ons) E85 ![]() Tune/numbers coming shortly!! |
yeah i have a 4" AFM power pipe...so my 3" intercooler pipe wont fit in the same hole as my powerpipe...
#4 | |
I Blumpkin Entirely Way Too Much
2005 Mustang GT
![]() Just playing man, he should be right...
MM + Cleavage member #22
exactly right. Well you will indeed need to cut it then. The powerpipe should have a template to go by. Mine did. But i didnt use it. I used and air chizzel with a cutting bit and cut mine out. You might could use a sawzall?
![]() 4.75 MMR 900se Livernois ported heads HP 292s blower cams Procharger D1sc at 20+ psi IW 15% OD pulley (and more bolt ons) E85 ![]() Tune/numbers coming shortly!! Last edited by BakerFX4; May 4th, 2010 at 05:51 PM. |
I just cut mine to fit by eyeballing it.
![]() *read sig as dolb said!
2005 Mustang GT
haha yea.. but in all seriousness. Bakers got good advice man, stick with him and you'll get er did.
for dolbs!!
sawsall, or dremel. i found my dremel to be EXTREMELY handy throughout my supercharger install. i bought a metal cutting attachment kit from lowes for like $10 and it works wonders.
2002 Procharged GT 12.503 @ 113.08 351rwhp 353rwtq Car Videos: http://www.youtube.com/user/mell00ut5?feature=mhee
2003 Mustang GT
The fenderwell was tricky for me with the stock intake, and retarded intercooler piping. I cut about 5" along towards the engine bay. Same height. I marked it, and cut it with a dremel.
Then used a magnet, and vacuum to get all the pieces of metal. Also, get some fuel hose, cut it directly in the middle, put it along the fenderwell where you cut, and itll look nice and not hacked up.
![]() Vortech V1 Intercooled @ 11psi 394rwhp/392rwtq @ 9.5psi 415rwhp/400rwtq @ 11psi on Methanol Tuned By: Pete @ Performance Dyno Affordable Supercharger Build Guide Supercharger Info for Noobs |
Threads Similar to: Help with FMIC install please!
| Supercharger and FMIC are in!!! pics | PhillyStyle | 99-04 | 27 | May 10th, 2010 02:51 PM |
| My FMIC Setup | Shaun03GT | 99-04 | 10 | February 18th, 2010 11:56 PM |
| CX racing FMIC? | 05roush0090 | 2005 - 2010 | 0 | December 30th, 2009 08:07 PM |
| need some pics of fmic installs please!!!! with bumpers off.. | turbot4 | 99-04 | 16 | May 28th, 2009 06:10 PM |
| fmic?and turbo? | 87merkur | 2.3 Mustangs | 3 | April 11th, 2008 12:14 PM |
