Coil pack install?? - Forums at Modded Mustangs
post #1 of 5 Old May 8th, 2010, 03:13 PM Thread Starter
takiller's Avatar
Coil pack install??
Hey guys im installing my coil packs right now and im down to the last 2...BUT the bolt just keeps turning and it wont come out. has anyone else ran into this issue? did you guys just use some pliers to hold it down and then unbolt it? Both the last ones are doing the same thing..any advice??
C&L CAI, 75 TB, Plenum, O/R H Pipe, SLP LM1's (Dumped), Eibach SS, Tokico S/S, Moser 31 Splines, Cobra Diff, FRPP 410's, XCal 3 93 Tune
takiller is offline
post #2 of 5 Old May 8th, 2010, 03:27 PM
energiesource's Avatar
well hopefully you didnt strip the heads.. you can just try pulling on the coil pack as you unbolt it, but i wouldnt try prying on it
energiesource is offline
post #3 of 5 Old May 8th, 2010, 03:36 PM Thread Starter
takiller's Avatar
im not sure what its called but it like it has one of those things in place so when you try and unbolt the bolt it just keeps turning but deosnt come out. i cant think of it for the life of me...is it possible??if you know what im talking about.
takiller is offline
post #4 of 5 Old May 8th, 2010, 03:44 PM Thread Starter
takiller's Avatar
nah the heads are fine and ive been carefull...im just dumbstruck why it just keeps turning and it wont come out. (and yes ive made sure its the right direction for removal ) the ones on there right now are factory.....and the other ones came out no prob.....clueless.....
takiller is offline
post #5 of 5 Old May 8th, 2010, 04:23 PM Thread Starter
takiller's Avatar
alright guys...got em out and switched. when i started the car it smoke a little...not much at all...is that normal after switching out the coil packs??? maybe cuz its more spark than its used to???
takiller is offline
Human Verification
