LinkBack (5) | Thread Tools |
#1
Quick steps of cleaning the IAC.
1st of all, I would like thank ANYONE in this forum who helped and supported me in finding the solution for the problem i had in my car.
basically, the engine was not starting properly when the car was parked for more than 4 hours approximately, i had to accelerate it a little manually until the engine gets warm, then then the rpm gets to the normal value. Luckily, I found the solution for that and did everything at home, special thanks to all of the members who provided me the answer when i posted about this problem. Problem description: -The engine will not start when the vehicle is parked for more than 3-4 hours. (the RPM raises for 1 second and then the engine shuts off) -The engine could be started by accelerating it manually. -When the engine is already warm, there was no problem in the start up at all. Solution: Simply, the Idle Air Controller (IAC) needed to be cleaned from inside. And here are the steps you should follow: *Tools you need: -8mm spanner+ socket wrench w/8mm socket -Curb cleaner/WD40 -New IAC gasket (recommended) -Fender covers (if you really want to avoid scratching your car) 1. the first step is to disconnect (X) wire and then loosen the two 8mm bolts which are located on upper and lower of the IAC. ![]() 2. You may need to disconnect other wires or remove some hoses that bothers you during the operation. 3. Remove the IAC from the Throttle Body, you will notice that the gasket needs to be replaced sometimes, here is how it looks: ![]() BTW, it wasn't spoiled this much, I shredded it a little by mistake because I didn't know that its so soft. 4. Clean the holes in the IAC, also try cleaning the which is directly on the Throttle Body using the curb cleaner/WD40. ![]() ![]() 5. Now after cleaning the part properly, it is time to replace it again. Use the new gasket if the old one is ruined. 6. Make sure all the plugs, wires, and hoses are completely back to normal and on their original places before you end up your work. 7. Start it up, and keep it running for couple of minutes and you are done. Notice: make sure all the work will be done when the engine is not warm. Well, I made this at home and it worked 100%, thanks again for anyone who supported me to solve this problem, I hope you like this topic guys .
![]() 2000 Mustang GT Auto -Custom o/r X-pipe -Flowmaster super 44 mufflers Facebook: http://www.facebook.com/Abdulla.Rawanbakhsh Email: wolfmania90@hotmail.com |
'02 GT 5spd
![]() iTrader: 1 reviews
Cool - I'll be doing this soon
boringly stock........but running well
02 Mustang GT
excellent writeup.
Thanks guys!
It's in the details Mod!
01 Cobra Vert
Nov 09/10 ROTM!
Thanks for the write up. I think this will be helpful to a few members here.
![]() Pinup in signature by loish.net Modded Mustangs Cobra Club#007 Military Crew E5 VOTED MM's BEST SIGNATURE 2010. THANKS STANGGTR07 |
01 Cobra Vert
Nov 09/10 ROTM!
BTW, I am adding it to the HOW TO thread at the top of the forum for future members.
no problem, oh that would be great, thanks man!
01 Cobra Vert
Nov 09/10 ROTM!
No problem. Reps on the write up as well.
02 Mustang GT
+ reps as well, thank you.
on a side note - gotta love when its an easy fix on our cars
2003 Mustang GT
Great write up man. Reps to you. Good pictures too, obviously took your time writing that.
![]() Vortech V1 Intercooled @ 11psi 394rwhp/392rwtq @ 9.5psi 415rwhp/400rwtq @ 11psi on Methanol Tuned By: Pete @ Performance Dyno Affordable Supercharger Build Guide Supercharger Info for Noobs |
12.35@114.08 w/ 1.88 60'
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() iTrader: 7 reviews
Nice writeup for sure! Can you do a rundown of the benefits of cleaning it? Like what issues you were having with your car? Don't need a novel, just cliffnotes.
Do the Right Thing, Cook. ~Zip. |
Thank you all!
@dcook_14, thanks man, talking about the benefits, as I mentioned in the beginning of the topic, I can now easily start up the engine without having any (RPM falling down) issues, it starts immediately without the need of accelerating it manually. Also the car is breathing better than before, especially when shifting from P to drive, the rpm doesn't jump.
....it worked 100%!
I checked it again today, no start-up issues at all! ..
2004 Mustang GT Conv.
Was hoping this would fix my issue. Got the same thing happening. But no joy....
2003 Mustang GT
If the IAC cleanse does not fix your idling problems it's time to check and clean the MAF. Even easier to to do than the IAC.
I thought it was my IAC being dirty, but turns out of MAF was dirty which fucked up my gas ratio thus causing RPMs to sway and my car to vibrate. Good luck. |
1996 mustang gt
13.07@104.66
+1 reps i will be doing mine this week along with all the fluids and alum d/s install.
2004 4R75W Mustang GT
13.179 @ 104.30
Nice wright up, but your dirty ass engine makes me sad
...Mods in garage
2002 mustang gt
this was the exact thing happening to my 02 mustang gt...im happy i read this before i spent alot of cash having stuff replaced
LinkBack to this Thread: http://www.moddedmustangs.com/forums/99-04/165357-quick-steps-cleaning-iac.html
| High RPMs problem! - CMC Forums | This thread | Refback | September 2nd, 2011 02:20 PM | |
| High RPMs problem! - CMC Forums | This thread | Refback | September 2nd, 2011 02:19 PM | |
| In need of IAC.. Idle air control for 96 - Northern California Ford Owners | This thread | Refback | January 31st, 2011 05:39 PM | |
| In need of IAC.. Idle air control for 96 - Northern California Ford Owners | This thread | Refback | January 29th, 2011 04:28 AM | |
| WTH is wrong? - Ok a few days ago my car was running really lousy. I changed the plugs (took out NGK platinum 2's) the old plugs had rust colored specks on the electrodes but otherwise looked clean although they smelled really rich. I put the new plu | This thread | Refback | December 10th, 2010 08:31 PM | |
Threads Similar to: Quick steps of cleaning the IAC.
| problems with cleaning the IAC | 99cobradroptop | 4V / SVT | 3 | March 26th, 2008 02:18 PM |
| IAC Cleaning | kuskye25 | 5.0 Mustangs | 9 | December 30th, 2007 08:36 PM |
| Really Quick Question (Cleaning 02 Sensors) | Onemanzu | The Clubhouse | 2 | November 21st, 2007 11:01 PM |
| Steps For Properly Cleaning MAF? | White2000GT | 99-04 | 10 | September 20th, 2006 04:13 AM |
| IAC Cleaning | 99mustang232 | 5.0 Mustangs | 7 | July 17th, 2006 12:47 PM |
