Code 303 Cylinder 3 Misfire?
LinkBack (1) Thread Tools
Old May 14th, 2010, 01:27 PM   1 links from elsewhere to this Post. Click to view. #1
Sworn is on a distinguished road
So I was driving my car today and it started to run like crap. The SES light came on and it threw Code 303 Cylinder 3 misfire? What would cause this? I just replaced the plugs about a week ago! Thanks!
2000 Mustang GT 5 Spd, MagnaFlow Exhaust, Densecharger CAI, Steeda Timing Adjuster, Mach 1 Grille Delete, Carbon Fiber GT Hood. Ford Motorsport HD Clutch.
Old May 14th, 2010, 01:44 PM   #2
I'm guessing a bad COP? Do these go bad often?
Old May 14th, 2010, 01:45 PM   #3
12.35@114.08 w/ 1.88 60'
dcook_14 is a splendid one to beholddcook_14 is a splendid one to beholddcook_14 is a splendid one to beholddcook_14 is a splendid one to beholddcook_14 is a splendid one to beholddcook_14 is a splendid one to beholddcook_14 is a splendid one to beholddcook_14 is a splendid one to behold
iTrader: 7 reviews
It's not real common for them to go bad, but it might have. Do you have a friend that could pop one off thier car and see if it fixes it?
If the COP and injectors are ok, the problem almost has to be internal
Do the Right Thing, Cook. ~Zip.
Old May 14th, 2010, 03:29 PM   #4
I replaced the COP and it's still throwing the code. I guess that leaves me with either a bad injector or internal motor damage? BTW the car has 70K......
Old May 14th, 2010, 08:10 PM   #5
Mach1 FTW
LGHTNG02GT's Avatar
04 Comp. Orange Mach1
LGHTNG02GT is just really niceLGHTNG02GT is just really niceLGHTNG02GT is just really niceLGHTNG02GT is just really nice
iTrader: 11 reviews
i had a similar code before when i got my 4v swap done on my GT. turns out a vaccum leak played a big part in it. check your vaccum lines 1st. another trick is to replace the #3cyl COP with another COP from a diff. cylinder and see if the miss follows the change. if it isnt the COP or the plug, then like you said its probably the injector.
MM Nitrous Club #7
MM Cobra Club #87
Old June 21st, 2010, 01:54 PM   #6
cnagel is on a distinguished road
I have cylinders 1, 2, and 3 missfiring, what should i check first?
Old June 21st, 2010, 04:13 PM   #7
BYAHHHH!
Scott2001GT's Avatar
2001 Mustang GT
11.649 @ 119
Scott2001GT has much to be proud ofScott2001GT has much to be proud ofScott2001GT has much to be proud ofScott2001GT has much to be proud ofScott2001GT has much to be proud ofScott2001GT has much to be proud ofScott2001GT has much to be proud ofScott2001GT has much to be proud ofScott2001GT has much to be proud of
do you have fuel?
Powered by Ford
Boosted by Precision Turbo and Engine
Thanks to: Wagon Wheel Performance & STL Mustangs
Old June 21st, 2010, 04:16 PM   #8
yes
LinkBack to this Thread: http://www.moddedmustangs.com/forums/99-04/165876-code-303-cylinder-3-misfire.html
Ford Misfire Cylinder 3 - Kosmix : Reference, Videos, Images, News, Shopping and more... This thread Refback July 2nd, 2010 11:31 PM
Threads Similar to: Code 303 Cylinder 3 Misfire?
Cylinder Misfire PonyBoy02 99-04 13 March 19th, 2010 11:47 PM
Misfire in Cylinder 1 John's_stang 99-04 6 January 17th, 2010 10:27 PM
cylinder 3 misfire pavementpownder 99-04 1 April 3rd, 2009 07:50 PM
cylinder 6 misfire Jucostud 96-98 4 May 10th, 2007 11:46 PM
68 303 J Code theodoor24 Classic Mustangs 8 November 26th, 2006 01:35 AM
