Roots type blower for a 96 on a 00? - Forums at Modded Mustangs
post #1 of 21 Old May 14th, 2010, 03:06 PM Thread Starter
As the title says, should a roots type blower designed for a 96 2v motor fit on to a 2000 2v motor?
2000 Roush Mustang- Vortech V2, Anderson Powerpipe, 42lb injectors, 75mm BBK Throttle Body and Intake Plenum, Bassani X-Pipe, Borla Side Exit Cat-Back, Roush Brakes and Suspension, 3.73s, aluminum driveshaf
wahoo09 is offline
post #2 of 21 Old May 14th, 2010, 03:33 PM
SCREWd2V's Avatar
according to Kenne bell
'96-'04 Mustang 4.6 2V 2.1L Supercharger
yes
SCREWd2V is offline
post #3 of 21 Old May 14th, 2010, 04:36 PM
BYAHHHH!
Scott2001GT's Avatar
iTrader: 5 reviews
there is.
KB and Eaton
But go with KB if you can
Powered by Ford
Boosted by Precision Turbo and Engine
Thanks to: Wagon Wheel Performance & STL Mustangs
Scott2001GT is offline
post #4 of 21 Old May 14th, 2010, 04:40 PM
BYAHHHH!
iTrader: 5 reviews
well KB its roots its a twin screw
Powered by Ford
post #5 of 21 Old May 14th, 2010, 04:42 PM
limited's Avatar
you can put a 2000 on a 96 but not the other way around, ports are different on non-pi's, I believe
KB'd 446rwhp/451rwtq, Mustang Dyno http://www.youtube.com/watch?v=3ZDpQ0EEm1M
Tuned by Joe at http://www.tricktuners.com
limited is offline
post #6 of 21 Old May 14th, 2010, 04:42 PM
iTrader: 7 reviews
yes
Sorry, but if you actually look at that link you'll see that the superchargers are broken out from 96-98 and 99-04. The head design is different between the two generations, so I don't see the earlier charger working on later heads.
What supercharger were you looking at?
Do the Right Thing, Cook. ~Zip.
dcook_14 is offline
post #7 of 21 Old May 14th, 2010, 04:44 PM
JerseyTrueBlue's Avatar
Yeah non PI stuff one a PI motor isn't happening and vice versa. Sorry man but unless you want to non pi your car I wouldn't buy it lol.
True Blue Crew Member #2
315's Crew Member (Dat azz)
255/298 bolt-on's and stuff
JerseyTrueBlue is offline
post #8 of 21 Old May 14th, 2010, 04:48 PM
BYAHHHH!
iTrader: 5 reviews
idk for sure but could u call and order a KB for a NPI?
But yeah I cant see a NPI to PI or PI to NPI either.
Powered by Ford
post #9 of 21 Old May 14th, 2010, 04:53 PM
iTrader: 7 reviews
A KB is a twin screw, not a roots. Big difference. Twin screws compress air internally and roots compresses externally, causing it to be much less dense and less efficient. A roots blower will make less power vs a twin screw at the same power level.
EDIT: Scott I'm sure you know this and it's just a typo, but I figured I'd lay it out for anyone else reading along
dcook_14 is offline
post #10 of 21 Old May 14th, 2010, 04:57 PM
BYAHHHH!
iTrader: 5 reviews
i ment isn't a roots but twin screw...my badz. But thanks for clearing it up for others bro!
Powered by Ford
post #11 of 21 Old May 14th, 2010, 05:20 PM
SCREWd2V's Avatar
no
thanks. you're right. fixed.
SCREWd2V is offline
post #12 of 21 Old May 14th, 2010, 05:41 PM
iTrader: 7 reviews
Yeah your sentence seemed a little screwy so I figured it was just a typo. If it were baker though, I'd say he just didn't know shit
Lol, nice. Good work finding the link in the first place though!
dcook_14 is offline
post #13 of 21 Old May 15th, 2010, 01:18 AM Thread Starter
Thanks for all the responses. The blower in question is a roush product, but is different from the others i have seen before. I picked it up, along with some other parts, for basically nothing. The car I am looking to use this in I bought for the motor. With the motor pulled I have the body sitting here and am looking to put something in there that is as fast and inexpensive as possible without being terribly unreliable. Before anyone gets into the "pick 2 because you cant have all 3" speech, I'm just looking for the best combination of the 3. What combination would work with the blower I have? NPI motor, truck engine (they dont have PI heads right?), anything else? also I have a set of 98 cobra heads w/o cams and a set of 03-04 termi heads laying around the garage... A buddy of mine has the a ported termi blower for sale... any input on a possible combination?
thanks
wahoo09 is offline
post #14 of 21 Old May 17th, 2010, 11:45 AM
iTrader: 7 reviews
Is it even a question that you should build a teksid shortblock, put the 03/04 heads and ported eaton on?
dcook_14 is offline
post #15 of 21 Old May 25th, 2010, 12:28 PM Thread Starter
I had a bit of a typo on that post, i have a set of 98 cobra heads and 03 termi cams. I know the easton blower would be the best power option, but for this build im more concerned with budget. Trying to do it as inexpensively as possible and the 4v heads w an eaton blower would require a stout (ie expensive) shortblock...
wahoo09 is offline
post #16 of 21 Old May 25th, 2010, 01:54 PM
Hooo Ha Ha
sharkbait's Avatar
iTrader: 10 reviews
Wahoo
is this what it looks like? If so then no it will not fit on a 99+ system. They only work on 96-97's.
853rwhp @ 23psi
75mm Turbo 5.4 swap E85
#turbo2v
10.11 @ 138mph STOCK LONGBLOCK
9.11 @ 149mph - New Longblock /w Powerglide
www.JPCracing.com 410-729-0005 ext. 11
PM me if you need any parts or advice!
sharkbait is offline
post #17 of 21 Old May 25th, 2010, 05:04 PM Thread Starter
yes indeed, that would be it. so i guess ill scratch that off the list for use of this project, unless i put in a 96-98 4.6 i guess. Will it kit on any other 4.6s? say a pickup or a crown vic? always have wanted to build up a stout cop car
wahoo09 is offline
post #18 of 21 Old May 25th, 2010, 06:06 PM
Rollin' 18/ pushin' 2
97S281's Avatar
iTrader: 18 reviews
Nope, I tried that a few years ago. They used to make a KB Twin screw for the 96-98 but stopped production on it due to the engine failures resulting from it's use. They state you can use the 99-04 model if you use P.I. heads, but you would really need to rebuild your shortblock first due to the higher compression resulting from the p.i. swap.
MODS IN GARAGE
All SVO'D UP
97S281 is offline
post #19 of 21 Old May 25th, 2010, 06:08 PM
97S281's Avatar
iTrader: 18 reviews
Originally Posted by sharkbait View Post
Wahoo
They are non intercooled as well and only produce 6 lbs of boost.
MODS IN GARAGE
All SVO'D UP
97S281 is offline
post #20 of 21 Old May 25th, 2010, 06:10 PM
Hooo Ha Ha
sharkbait's Avatar
iTrader: 10 reviews
It will only go on a Non PI 4.6
Thats the supercharger that should be coming in for me on thursday.
Aslong as it is a Non pi 4.6 it will bolt right on for the most part. There not really good for high boost applications...there just decent blowers for the price
also 97S281, yes there are non intercooled. But pulleyd (just like any other supercharger) they can make more boost. But you have to deal with more heat (just like any other supercharger). So meth injection is the only way to go with them.
853rwhp @ 23psi
#turbo2v
Human Verification
