2004 mustang gt
![]() iTrader: 1 reviews
wot backfire an p0172 code with kb 1.7
ever since kb 1.7 install i get a pop or backfire at wot while shifting and over 500miles it has thrown a p0172 rich bank one code about five times any suggestions on what may be wrong some say sticking open fuel injector i even tryd unpluging bap which should lean it out an still got the code while it was unplugged it had it had alot more power with bap unpluged so i know it leaned it out but still got rich code
395hp/436tq tuned by lasota racing at rodeheavers on a mustang brand dyno.
2011 Caddy cts, 09 Jag XJ
if its running that rich you should probably get it retuned
![]() 2000 GT- Gone but not forgotten |
What's your fuel system, do you still have a PPRV?
Vortech V2 Si
By the way don't go WOT with the BAP uplugged ever.
Vortech V2 Si
99 limited edition vert
backfiring thru intake or exhaust?
KB'd 446rwhp/451rwtq, Mustang Dyno http://www.youtube.com/watch?v=3ZDpQ0EEm1MTuned by Joe at http://www.tricktuners.com |
2004 mustang gt
almost positive through the exhaust.
2004 mustang gt
yea,i know it ain't good to do it but just wanted to see if it stopped the pop,also the guy that had kit before me was hitting 460rwhp at 9 psi which is unheard of with kb tune but he found out when he unhooked kit to sell that bap was never hooked up so that explains the xtra hp gains and he put 40,000 miles on kit with no bap,he was lucky.
try swapping your coil packs from left to right and see if problem follows, sounds like you have a coil going bad
2004 mustang gt
i may try that and if that doesnt work i may try switching injectors from side to side
2004 mustang gt
PPRV will removing this get rid of the popping?
2004 mustang gt
i currently have the kb tune for this,do you think this problem could be mechanical or a tune issue?what about a dyno tune do you think that would resolve this issue?
2000 gt
id put it on a dyno and see what it does. sounds like it's rich. one of those mail order tunes can work okay, but it isn't optimal. each car is different and will react differently.
Procharged 2000 5 Speed BAB GT, built motor, blower cams, speedy dyno tune 412 hp, 450 rw tqHARDCORE CREW BRIGHT ATLANTIC BLUE CREW #1 MEMBER |
2004 mustang gt
ok,i just wish i wouldve waited and got dyno tune cause the chip cost me $200 and now i wont be using it cause i have a xcal3 i want the future tunes on .the dyno tune is going to cost me $400 which sucks,i hope its worth it. lasota racing is supposed to do it.
Baker Jr.
You will be alot happier with a good dyno tune..
MMR-Modular Mustang Racing Phils Machining-For your ABS Module Delete Manifold! American Muscle-www.Americanmuscle.com HorsePower By Hermonn-TUNER THANKS TO ALL SPONSORS,READY FOR THIS 2012 RACING SEASON!
i don't know if this has any relation, but doesn't kenne bell's bypass valve vent directly to the driver's side heads? so once you get off the throttle going WOT the bypass valve will open, dumping all of that boosted air into the driver's side heads. would that have anything to do with it?
2002 Procharged GT 12.503 @ 113.08 351rwhp 353rwtq Car Videos: http://www.youtube.com/user/mell00ut5?feature=mhee
Threads Similar to: wot backfire an p0172 code with kb 1.7
| DISCOUNT CODE DELETED - New Code Available - Please Read! | AMNick | American Muscle | 86 | May 14th, 2012 08:22 PM |
| SES light-code P1401 code-& DPFE sensor ?'s | PacificMustang01 | V6 Mustangs | 6 | May 18th, 2010 02:39 PM |
| Backfire? | PiggySmallz | 2005 - 2010 | 19 | February 26th, 2009 01:24 PM |
| Backfire! | mustangmanic | 99-04 | 13 | July 30th, 2008 10:57 AM |
| backfire | ttop5.0 | 5.0 Mustangs | 7 | May 17th, 2006 10:25 PM |
