2011 Mustang GT 5.0
04 to 03 computer swap
I was wondering if there is any problem with using a 2004 ECM in a 2003 and vice versa. They are both manual trans and 4.6's. The reason I am asking this? I bought a Vortech SQ kit off of this guy I know. I had to swap my stock parts to his car because he did not have any of it. I have an SCT Livewire that I will be getting a custom tune for sometime this week. The problem is once I put his car back to stock it runs real bad, will hardly stay running. I am thinking that since the Blower was on it there is something done to the computer. I know that when you buy the kits you have to send your ECM to Vortech to have them modify it. Does anyone know what exactly they do to it? There is no module plugged into it at all. Does Vortech reflash them? Anyway, I was thinking that to get around this problem I could put my computer (2003) in his car (2004) and vice versa so I can get his car running correctly.
I know this is long....but any help would be greatly appreciated. Thanks |
2001 Bullitt
12.25@110.4
The only problem I see is with the PATS, it has to match up with the gauge cluster in the car. If you disable the PATS, it should be just fine.
2011 Mustang GT 5.0
2001 Bullitt
12.25@110.4
Changing the cluster with the car that the ECU came out of is an option, but it's not hard to disable PATS with the LiveWire, I'm sure.
2011 Mustang GT 5.0
2001 Bullitt
12.25@110.4
then I'd just swap gauge clusters. I thought the ECU was coming out of a parts car.
2001 Bullitt
12.25@110.4
If the mileage is considerably different between the cars, you can just swap out the PATS boards on the back of the cluster also, forgot about that.
#8 | |
2011 Mustang GT 5.0
Thanks for your help on this.....
12.35@114.08 w/ 1.88 60'
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() iTrader: 7 reviews
If you're going to swap everything over you're going to have to swap ignitions too. The key is chipped with the PATS code too, so that needs to match the cluster and the PCM.
Or you could just tell the guy to spend some money and talk to a tuner like Joe at Trick Tuners and get him to write a tune for a stock GT.
Do the Right Thing, Cook. ~Zip. |
Threads Similar to: 04 to 03 computer swap
| Which one is easier??a rear end swap or engine swap? | Bies08 | V6 Mustangs | 42 | May 11th, 2010 04:33 PM |
| 1995 351 to swap or not to swap.& how to? | Jeffery9508 | 94-95 | 9 | August 3rd, 2008 08:00 AM |
| does a 4.2l swap need new computer? | v6_armyguy | V6 Mustangs | 3 | July 11th, 2008 01:02 AM |
| Is An 93 5 Speed Computer The Same As An 89 A9l Computer?? | e3sean | 5.0 Mustangs | 4 | February 4th, 2008 07:40 PM |
| EEC computer swap | 5.0LX88 | 5.0 Mustangs | 0 | February 27th, 2007 02:47 AM |
