serious drivability issues
Old May 17th, 2010, 07:04 PM   #1
redrocket's Avatar
redrocket is on a distinguished road
So im still trying to figure out what my problem could be. The car was running fine and then a buddy and me installed a front mount intercooler. disconected MAF for a bit, reclocked the vortech, buttoned everything up and it idles and starts up fine but at partial throttle there is a serious misfire at 2000 rpm and up. Im have a lot of surging and bucking and Now it sounds like im having compressor surge even without boosting. As its misfiring you can hear the compresser fluttering. I upgraded the BPV and still same thing. I took it to a very reputable tuner that only tunes modulars and he seems to be stumped too. I have no DCTs either. The MAF is reading fine below 2k rpms. My Maf is only 2 months old too and is 2600. I have checked for vacuum leaks and leaks in the connections but i have found nothing. Any ideas? The tuner says its not allowing him to dial in the Air/Fuel Ratio. It keeps changing what amounts to add or to take away
RET tuned 718rwhp/588tq
Old May 17th, 2010, 08:20 PM   #2
Shaun03GT's Avatar
2003 Mustang GT
Shaun03GT has a brilliant futureShaun03GT has a brilliant futureShaun03GT has a brilliant futureShaun03GT has a brilliant futureShaun03GT has a brilliant futureShaun03GT has a brilliant futureShaun03GT has a brilliant futureShaun03GT has a brilliant futureShaun03GT has a brilliant futureShaun03GT has a brilliant futureShaun03GT has a brilliant future
iTrader: 12 reviews
Im going to throw out a few ideas.
Vacuum leaks? Ur postive theres no vacuum leaks?
Bypass valve stuck open?
Pigtail that goes into MAF ripped?
Clean the MAF
Replace the COP's?
Just for shits and giggles, run the regular discharge again, and see if it still has the same problem. Should take like 20 minutes to setup...connect the BPV, and run the discharge pipe done.
Vortech V1 Intercooled @ 11psi
394rwhp/392rwtq @ 9.5psi
415rwhp/400rwtq @ 11psi on Methanol
Tuned By: Pete @ Performance Dyno
Affordable Supercharger Build Guide
Supercharger Info for Noobs
Old May 17th, 2010, 11:46 PM   #3
redrocket's Avatar
i have pretty much checked that stuff except for the cops. The stock bosch one was on there when the problem started and i changed it out hoping to fix at least the compressor surge issue.
Old May 17th, 2010, 11:49 PM   #4
Shaun03GT's Avatar
2003 Mustang GT
iTrader: 12 reviews
Idk thats wierd. No leaks in the intercooler piping to cause turbulance on the MAF right? The bypass valve is t'd off and setup correctly right?
Idk though, Id try setting up the discharge pipe only with the MAF again and see how that is, see if its just when you have the Intercooler setup
Old May 17th, 2010, 11:51 PM   #5
ajm
Blow through or suck through? If suck through its always a possibility that maf location with the i/c is hurting you.
Threads Similar to: serious drivability issues
4.2 issues SleeperStang88 V6 Mustangs 5 October 19th, 2009 09:22 PM
Drivability prob MATT02GT 99-04 13 June 25th, 2009 01:49 PM
Drivability tune RyanGT 99-04 18 July 4th, 2008 12:39 AM
Drivability 07stanggt 2005 - 2010 43 April 8th, 2008 09:38 PM
nitto DR drivability leebunnyz 2005 - 2010 42 August 10th, 2007 04:49 PM
