2004 Mach 1
12.57 @ 111.72
chatter on start up
My engine seems to chatter on first start for about 2 to 3 seconds, then quietes down to a light tick.. then after its warm its fairly quiet. Half a year ago it would do this once in a while(mostly in the morning after sitting all night), now it seems to chatter on start up 70% of the time cold or hot. I tried 5w30 oil and that seemed to make it slightly worse so im now back to using 5w20 again.
Thoughts? Im not sure if its something I should really worry about or not..
2004 Azure Mach 1 - K&N FIPK, 3/8" intake spacer, SCT Tuned, BBK O/R X, Magnapack CB, Tri-Ax, Built 31 spline diff with Eaton Truetrac, 4.10's, MM LCA's, Raptor shift light 2004 Mustang GT - Sold |
2001 Mustang GT
![]() ![]() ![]() iTrader: 3 reviews
Maybe it's the lash adjusters? Or timing chain guides. How many miles are on the motor and have you tried to locate where the noise is coming from?
![]() True Blue Crew Member #2 315's Crew Member (Dat azz) 255/298 Founder of the please leave my signature alone, I want it to say what I put there and don't appreciate you deleting it club |
2004 Mach 1
12.57 @ 111.72
just rolled over to 100,000k yesterday.. im gonna try to narrow down exactly where its coming from soon
2004 excursion,71 mustang
1 hour,11.0
Use a motorcraft oil filter. It keeps the oil were it belongs longer than most other filters. Other filters will bleed down back into the filter and pump.
There is a huge thread about the modular clatter on startup on the truck forum I'm a member on. |
2004 Mach 1
12.57 @ 111.72
Youtube distorted the quality a tad.. But you can hear hte noise at 11 to 12 seconds in
Its been a lot worse than this at times. And yet once in awhile it doesnt do it at all.. |
def lash adjusters dude. you ever taken one out before? you could buy all new ones or take them out and bleed/clean them like i did.. once they were squished all the way down in a vice i put the little red tube that comes with the b12 chemtool spray right on the hole and sprayed it while letting the vice out.. let the lifter sit for about 2 min and did it again.. i had about 7 pretty stuck lash adjusters and this freed them up pretty good
![]() 480RWHP 450RWTQ 15psi @ 15* on 91 octane |
i think baker had a bunch colapse on him at around 100k
what kind of 5w20 are you running?
11.91@113
I told you it was the lash adjusters/guides cept when u sent me the vid it had the timing different and i heard it at a later time.
![]() [url]http://www.youtube.com/watch?v=PTFyQGmctJA |
if you end up pulling them out you can pm me and ill tell you how to do it. or ajm could help you too
2004 Mach 1
12.57 @ 111.72
im using 5w20 AMSOIL. is it gonna hurt it if I leave it alone for too long?
11.91@113
hope it doesnt catch and skip a gear like mine did and throw the timing completely off.
if they are collapsed then you wont have the propper preload on the follower and it can get ejected out from underneath the cam. also.. its going to cause the valve not to open as far as it should and hurt performance.
Threads Similar to: chatter on start up
| clutch chatter? | RainsFather | 2005 - 2010 | 4 | February 20th, 2010 01:46 PM |
| Hurst Chatter | beefmobile | 2005 - 2010 | 43 | November 2nd, 2008 11:32 PM |
| Clutch Chatter | lwhitetrash88l | V6 Mustangs | 2 | April 13th, 2008 12:27 AM |
| clutch chatter | Black Five 0h | 5.0 Mustangs | 6 | March 11th, 2008 01:18 PM |
| Clutch Chatter | bcnsucks | 94-95 | 6 | November 15th, 2007 11:20 AM |
