The Deer Hunter
Damage Insight
Hey all, I wasnt getting any luck over in the clubhouse so I thought I would throw this over here and see if yall could help me out on this. Reps for insight
I am looking at a V8 swap and am wondering if this is worth messing with? I had originally planned on adding TF upper end kit when I swapped it over anyway but I dont know what else will be on this end that would not be useable anymore. ![]() ![]() ![]() ![]() ![]() Im guessing the radiator is gone, the power steering pump is gone, needs a new timing cover, the harness may be jacked up if I need the part attached to the fuse box, the reservoir may be in decent condition but odds are its toast, will need new belt, hard to tell if the brake booster is intact or not. Thats the brunt of what I can see. If anyone who owns a GT can chime in and let me know if there is anything else in that section I may be missing ill greatly appreciate it n give reps.
![]() Do not seek in others what you must find in yourself.
Seek first to understand, then to be understood. |
2003 gt
5.4 32v on the way
how much are they wanting for that? You should probably look for something else
2003 Mustang gt - usual mods - slowly working on 5.4 swap 2004 srt4 - Stock DD/winter beater Click here for your tuning needs Before asking a gearing related question click THIS link and enjoy all your saved time. |
2003 Mustang GT
Sorry Im confused, is that your car? Or are you looking to get the motor out of that car?
![]() Vortech V1 Intercooled @ 11psi 394rwhp/392rwtq @ 9.5psi 415rwhp/400rwtq @ 11psi on Methanol Tuned By: Pete @ Performance Dyno Affordable Supercharger Build Guide Supercharger Info for Noobs |
The Deer Hunter
They want $2000
I can make some but I dont think I will be able to make much back out of parting what is left. The only other offer I have that is anywhere close is a 95 that is in good running condition but they want $2600 for it. Mustangs are expensive in this part of Texas
The Deer Hunter
Sry I didnt explain well enough. I am looking to use that car as a donor to swap into mine.
2003 gt
5.4 32v on the way
Hell for that much look into a mark8 swap.
The Deer Hunter
Mark8?
Cant say I have heard of it. Nvm just found a write up. Thanks for the info
Seek first to understand, then to be understood. Last edited by Megawatts88; May 17th, 2010 at 11:48 PM. |
Moderator
2012 300a gt auto
12.10@116
sorry bro, that car is junk for your needs. a v-6 donor car needs to be hit in the drivers side door area to be a good canidate. you'll need everything under the hood but the hood prop rod & core support so it can't be hit in the front, & you'll need the computer & fuel lines so it can't be hit on the pass. side door area. you'll also need the fuel tank & accs so it cant be hit in the rear.
for the most part, you'll need every thing off the donor except the body shell & interior.
MM BRACKET RACING CREW CO-FOUNDER BAMA Performance Drag Team Founder 2012 300a GT auto
#9 | |
The Deer Hunter
Thanks for the help. What about the 95 GT? The one I have seen is running and no damage. I was originally thinking about this because I can do all the work myself as I have had the most experience working on pushrod motors.
2004 Mustang
Man looks like a lot of work.... Ummmmm....... If you do get it put in your v-6 then you would still not have limited slip rear unless you swap it which idk if thats hard or possible? If you could make it work it might now be too bad a deal b/c you would could use the motor for your car and sell what you can off the car then resell it or scrap the body for bout $250-$350. But i think it would be a better idea to just buy a GT and keep the V-6 as a dd. But good luck on whatev you decide.
2004 Mustang
casperGT said it
#12 | |
Moderator
2012 300a gt auto
12.10@116
have you talked to the guys in the v-6 section? some of them put down some pretty impressive numbers with v-6's & with the time, effort & money the v-8 swap will cost you to do it right, you can buy a ton of v-6 parts & might be faster in the end.
2003 Mustang GT
Yea I have to agree. Have a nice 4V motor for that much, possibly cheaper
Moderator
2012 300a gt auto
12.10@116
problem with the mk8 swap is that you just bolt it into a GT, not so with a v-6, you'll still need a GT donor car.
#15 | |
The Deer Hunter
My biggest problem is that I live in the middle of nowhere so there isnt a lot of places I can go to get help on "performance" items. I think the closest tuner is on the north side of dallas which is 4 - 6 hours away.
Seek first to understand, then to be understood. Last edited by Megawatts88; May 18th, 2010 at 12:06 AM. |
#16 | |
You will. Just like the gt-cobra mindset. You need to get what you want, go with your gut. If you want a gt, get a gt. OR get a v6 shell and throw a 4.6 in it.
![]() 99' Rio Red Mustang GT: --My Garage-- Check garage. Vortech V-1 intercooled running 9lbs of boost Life= eat, lift, eat, eat, eat, sleep, repeat
Its been done, joint 3.8 mustangs, theres a guy named Badazztang he did this he's willing to help anyone he even listed his email address. But for that much is not worth it as said theres a lot more work involved, I suggest to save a couple of thousands then sell you v6 and buy a v8.
computer, cluster, rear end, exhaust, wiring harness, tranny, think about the cost as well, but talk to badazztang.
2003 Mach 1 Procharged 500rwhp club
[QUOTE=Megawatts88;2875482]My biggest problem is that I think even if I do spend the money to make my 6er fast im still going to have that nagging thought in the back of my mind that its still just a 6er. /QUOTE] For the same reason a bought a GT.
#19 | |
The Deer Hunter
Lol I was on the same situation what I did was save money then bought the GT and still have the V6 but I trying to sell, after noticing that extra power I wanted to get rid of the v6 as soon as possible, if you really like you v6 then you're not ready for a gt wait that's what I did
Threads Similar to: Damage Insight
| need some insight. | ZoomZoomMFer | 4V / SVT | 8 | May 2nd, 2010 02:53 PM |
| need some insight | 707Stang | The Clubhouse | 11 | February 8th, 2010 07:52 PM |
| V6 in need of some insight | JKennedy | V6 Mustangs | 102 | February 16th, 2009 05:12 PM |
| Ok I need insight | darkhorse50 | 5.0 Mustangs | 2 | May 26th, 2008 10:29 PM |
| Need a little insight here! | sean1017 | General Tech | 4 | January 30th, 2008 03:49 PM |
