12.85 @ 114
Guys w/ Vortechs and Intercooler... question
Hey guys. I am in the middle of my install, trying to figure out the best way to route the piping into my fender well (in regards to both Intake and piping to the intercooler). Do you guys have any pictures of how you have it done? I am trying crazy things right now to make it work. Just wondering what others have done. Thank you so much.
Matt
![]() MODS: Vortech V1 T-Trim @ 7.5 PSI (tuned down) Comp Cam Stage 2's + more 432 rwhp / 396 rwtq 02/27/2011 NEW VIDEOS! **It takes ~$60 a rwhp (over stock) for a 99-04 Mustang GT.** Do the Math ![]() C2H5OH on the horizon |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() iTrader: 4 reviews
Clock the blower to around a 45* angle or so and run the pipe straight down behind the fan to get it to the ic. To get it back up through the fender well different people have done different things. I wanted as few bends as possible so I just took an air hammer/air chisel and cut straight down from the factory hole until I was pretty close to the rail, then cut across. Made a straight shot from the ic to the tb, other than the 90* bend needed to get to the tb.
2003 Mustang GT
Thats the tricky part imo. I had to cut the fenderwell to make the hole bigger. But I took fuel hose, cut it and half and put it around where I cut so it didnt look tacky. Heres an engine bay pic kind of give you an idea:
![]() ![]() Hope that helps, I can probally get some better pics tomorrow. To dark out
![]() Vortech V1 Intercooled @ 11psi 394rwhp/392rwtq @ 9.5psi 415rwhp/400rwtq @ 11psi on Methanol Tuned By: Pete @ Performance Dyno Affordable Supercharger Build Guide Supercharger Info for Noobs |
2003 Mustang GT
jesus christ, sorry for the over size picture. Didnt realise I didnt re-size it
BYAHHHH!
2001 Mustang GT
13.874
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() iTrader: 3 reviews
just keep moving them around and it will all fit into place. Just takes time
![]() Precision Turbo|TurboSmart|TeamZ|Strange|Hellion|BBK|SCT|Edge Converters|Fairbanks|CG Fabrications|Treadstone |
2003 Mustang GT
Clean install right here too:
DIY Intercooler Install on the 99-04 Mustang - High Performance Mustangs Inc.
BYAHHHH!
2001 Mustang GT
13.874
damn! i like the braided line for the IAC!
2003 Mustang GT
I know thats sick. I want to do that idk where to get it though.
When i do a powerpipe, Ill definatley have to do some adjusting on the IC piping, Im leaning towards that way
^ summit has it for fairly cheap. If you cant find it a piece of large diameter -an stainless fuel line with the little pretty ring to cover the frayed ends will work just as well.
Edit: Ive never been able to find it on summits website by just looking around and such, must not be looking in the right area but you can find it in the book and get the part number pretty easily. Last edited by ajm; May 18th, 2010 at 12:19 AM. |
2003 Mustang GT
Something like this would probally work right?
Spectre Performance 29490 - Spectre SSteel-Flex Fuel Lines - Overview - SummitRacing.com
BYAHHHH!
2001 Mustang GT
13.874
wouldn't look at good on the GT setups being so short IMO
12.85 @ 114
damn you guys respond fast... lol.
Yeah I mean we have pretty much "got it" but it doesnt seem as clean as it could be. I will have some pics up tomorrow. I was just curious if I was doing something wrong... we put a solid 10 hours into the install today... crazy. PS Funny Story, Nicked a A/C line... filled the entire garage with freon lol
2003 Mustang GT
Lol thats why I love these forums. I post something, like 20 minutes later I have 10 replies.
Yea the intercooler piping gave me the hardest time. I had to cut some piping to make it fit right. Post pics tomorrow, and we can help you out more. I should be able to get some pics of how I have mine setup tomorrow
#14 | |
12.85 @ 114
-Installed 42lb injectors -New Plugs -Drain Oil -Tap Pan -Installed vortech mounting bracket -Mounted Head Unit -Removed Bumper Support/Fabricated for Intercooler -Installed Intercooler -Installed All Piping, Including Intake (MAF is hooked up and read to go) To Do Tomorrow: -Finish hooking up Blowoff valve -Modify front bumper to fit w/ intercooler piping (and hopefully be able to keep fog lights) -Fill Car With Oil (bold so I dont forget lol) -Replace Fuel Pump -Call Tripple A and get Towed to shop to be tuned Oh and before I forget... how tight is it in your fender well w/ ur filter and the piping that goes to the cooler? I mean my stuff is ON TOP of eachother... is that OK?
BYAHHHH!
2001 Mustang GT
13.874
no reason u cant keep the fogs. I had to cut the fog light housing on the driver side tho.
2003 Mustang GT
Very nice man. What kind of MAF do you have?
My intake an IC piping are on top one another so dont worry. Just make sure you crank everything down. Dont want stuff blowing apart.
12.85 @ 114
Stock lol, w/ a mafia extender. I am just doing this temporarily until I can buy a blow-through MAF and new blow off valve.
2003 Mustang GT
Ohhh okay I got ya. You may want atleast a 90mm Lightning MAF...Only $80 on Buy Ford Racing.
When you chance to blow through MAF, make sure you route ur IAC after the MAF, dont make the same mistake I made lol. Could NEVER idle right
12.85 @ 114
how do I hook up my IAT sensor? i have an 04, its in the maf currently. I bought the sensor but now I just need to hook it up. any ideas?
If you bought the sensor there is 2 wires that come out of it. VMP Tuning - Buy Ford SCT & GM Custom Handheld Flash Tuners Performance Economy Towing: 05+ Slot Style MAF connector pigtail solder on that link has a diagram of your MAF wiring. You just cut off the two IAT wires and hook them up to your IAT sensor.
Vortech V-2 SQ 3.33 pulley, Intercooler, Tial BOV, SCT XCal2, KB BAP, Pro-5.0 STS, Accufab 75mm TB and Plenum, O/R H-Pipe, Flowmaster exhaust, 3.73 gears, MM XD LCA's, Lakewood 70/30 Struts, MM CC Plates, UPR Front Coil Overs with 14/175 lb springs. |
Threads Similar to: Guys w/ Vortechs and Intercooler... question
| Intercooler ??? tech question | 00ROUSH | 99-04 | 59 | June 25th, 2009 02:13 AM |
| Question (PSI without Intercooler) | mmvi | V6 Mustangs | 20 | February 4th, 2008 11:41 AM |
| intercooler guage question | moose14 | Modular Mustangs | 2 | October 9th, 2007 09:27 PM |
| does anybody like Vortechs over Prochargers? | StuTheMusicEngineer | General Tech | 38 | January 21st, 2007 05:48 AM |
| If You Don't Like Vortechs Stock Inlet Setup... | mustang_montana | General Tech | 0 | September 3rd, 2006 02:10 AM |
