People who want to go Supercharger...READ
Old May 18th, 2010, 10:09 PM   #1
Shaun03GT's Avatar
2003 Mustang GT
Shaun03GT has a brilliant futureShaun03GT has a brilliant futureShaun03GT has a brilliant futureShaun03GT has a brilliant futureShaun03GT has a brilliant futureShaun03GT has a brilliant futureShaun03GT has a brilliant futureShaun03GT has a brilliant futureShaun03GT has a brilliant futureShaun03GT has a brilliant futureShaun03GT has a brilliant future
iTrader: 12 reviews
A lot of people on here latley have been going towards the supercharger route. So I wanted to make a post to help you go in that direction.
Why you should:
Building a supercharger can be as expensive as buying cams, springs, retainers and install. Thats roughly $2,000. If you look in my sig I have a link where I put togeather, and many other people have put togeather a kit for under $2000.
The gains will literally be 5-6x greater than cams. And making more power is a pulley away (as long as you have the fuel to do so)
Vortech Vs Procharger Vs Paxton:
Everyone has their own opinion, and people will say Procharger is better, or Paxton is better, or Vortech is better.
Me, I got a great deal on the headunit, and Ive heard great things from Vortech. Plus the V1 is so loud. I personally like Vortech. But If I had money, I may have just bought a new Warrantee'd Procharger Kit.
Head Units:
Mustang owners (96-10+) need Counter Clockwise Rotation headunits. Heres a list of Head units:
Vortech V1
S-Trim, T-Trim
Vortech V2
S-Trim, Sq-Trim, Si-Trim, T-Trim
Vortech V3
Sq-Trim, T-Trim
Procharger
P1-SC
D1-SC
F1-A
Paxton Novi
1200
1500
2000
2200
Intercoolers:
Ive been getting a lot of P.M's latley on intercoolers. "Which intercooler should I get?" or "Should I get an intercooler?" etc..
Without an intercooler, your IAT's (intake air temps) will be high, because the Headunit runs hot, and compressed air in general is hot. You dont "have" to run an intercooler, but its a good insurance upgrade, itll make more power, cooler IAT's etc.
The Intercooler I try to get people to buy is here:
CX Racing Intercooler with BOV
For the price, you cant go wrong. Comes with the BOV, the pipe with the BOV flange, the IC, and all the piping.
Dont forget with an intercooler, the car will make less boost. As theres more volume to fill. The supercharger has to shoot all that compressed air probally about 7 feet of piping, and fill the intercooler too. Down below Ill post how much boost youll make with Pulleys.
Powerpipes:
Ive heard mixed opinions on powerpipes. About how much boost they will give you. Ive heard 0, Ive heard 3psi. It will give you some rwhp.
Anderson Ford Motorsport makes them, and Modular Powerhouse makes them. You can get them for around $220.00.
Intercooler vs Aftercooler:
As many people will tell you, aftercoolers are very ineffcient. They use water too cool them down, and after 1 track run or a race or whatever the water will be hot, and hotter IAT's. You can use ice to cool it down, but it wont make your problem go away for good.
Intercoolers will keep a much more efficient rate of cooler IAT's. As its pushing cool air through it. And cooler IAT's makes for more horsepower, and better ET's at the track.
Pulley Sizes:
BOOST WILL CHANGE PER HEADUNIT. Boost will drop, but power will be higher (Thanks mell0)
Vortech:
Discharge (No intercooler or aftercooler)
Boost will be a lot easier to make because its pushing compressed air only about 1ft to the motor. These are estimates, not exact numbers:
3.6 Pulley - 10psi
3.33 Pulley - 12-13psi
Anything smaller will probally be too much for the stock bottom end.
Aftercooler:
3.6 Pulley - 8psi
3.33 Pulley - 10psi
3.12 Pulley - 12psi
2.87 Pulley - 13+psi
Intercooler:
3.33 Pulley - 6-8psi
3.12 Pulley - 8-10psi
2.87 Pulley - 10-12psi
2.62 Pulley - 13+psi
Im not sure on Procharger but from what Ive heard:
3.6 Pulley - About 10psi
3.4 Pulley - About 12psi
Hopefully mell0, Baker or Scott can chime in here
Belt Sizes:
Vortech
3.6 Pulley = 108" Belt
3.33 Pulley = 108" Belt
3.12 Pulley = 107.5" Belt
2.87 Pulley = 107.5"-107.38" Belt
2.62 Pulley = 107.38" Belt
You can buy Goodyear Gatorback Belt at Autozone or Summitt for $35.
Procharger, Im not sure, again hopefully mell0, Baker or Scott can chime in here.
MAF:
Mass Air Flow, Theres 2 kinds.
Draw Through (like our stock ones)
Blow Through
The general rule of thumb is, intercooled you should run a Blow Through, no Intercooler you can run a Draw Through.
Blow Through allows you to run your Bypass valves open, and tuners love to tune with blow through.
90mm Lightning Draw Through
PMAS Blow Through MAF
SCT Big Air Blow Through MAF
Vortech V1 Intercooled @ 11psi
394rwhp/392rwtq @ 9.5psi
415rwhp/400rwtq @ 11psi on Methanol
Tuned By: Pete @ Performance Dyno
Affordable Supercharger Build Guide
Supercharger Info for Noobs
Old May 18th, 2010, 10:09 PM   #2
Shaun03GT's Avatar
2003 Mustang GT
iTrader: 12 reviews
Fuel Injectors:
With boost on the stock bottom end you can run 39lb or 42lb Fuel Injectors. A good thing to run if your eventually looking for big numbers are 60lb Injectors
Fuel Pump:
255lph Focus Fuel Pump
Ford GT Supercar Fuel Pump
The 255lph is a direct bolt in. And from what Ive heard can handle 380rwhp without a Boost a Pump (BAP details below)
Ford GT Pump needs modification's. Very easy though. Mine hit max duty cycle at 370rwhp. But people have hit 425+ without a boost a pump.
Kenne Bell Boost a Pump:
20amp for single Pump
40amp for dual Pumps
I bought mine used for $160. Works fine. It works as an amplifier and generates for volatage for the fuel pump. For example:
With my Ford GT Pump, my fuel pump hit max duty cycle at 5,500rpm with 370rwhp.
With my 20amp Boost a pump, Im now at 384rwhp and only 82% duty cycle.
Only takes about a half hour to install and is very easy.
Spark Plugs:
You need to run 1 step colder plugs, and gap them from .030-.035. Use neversieze.
Custom Tunes:
Dyno tuning for a supercharger will run from $200-$500 depending on the location and the tuner. You absolutley need a tune to go WOT. Some cars may be able to be driven without a base tune, but dont go WOT.
You can usually email your tuner, and he will send you a base tune to drive the car there.
I hope this helps. If you have any questions, PM me.
Old May 18th, 2010, 10:19 PM   #3
3sportbob's Avatar
MY OTHER RIDE IS YOUR MOM
3sportbob will become famous soon enough
Nice wrap up of all the stuff you learned in your project.
reps to you.
“I Saw Elvis at 1000 Feet”
"I was doing fine until about mid-corner when I ran out of talent."
Old May 18th, 2010, 10:21 PM   #4
I8ACMRO's Avatar
2003 Mustang GT
14.03@100
I8ACMRO has a spectacular aura aboutI8ACMRO has a spectacular aura aboutI8ACMRO has a spectacular aura about
Nice writeup. Reps sent your way
http://www.moddedmustangs.com/forums...-member-30498/
Originally Posted by RZNCAIN View Post
Drive the shit out of it and replace shit when it breaks. No point in having these things if we are going to drive them like a bunch of pussies!
Old May 18th, 2010, 10:24 PM   #5
Shaun03GT's Avatar
2003 Mustang GT
iTrader: 12 reviews
Thanks guys. Ive learned so much on these forums from so many people, I cant even start naming people. Just trying to return the favor
Old May 18th, 2010, 10:27 PM   #6
koessl's Avatar
1998 GT suckaaa
4 tickets @ 1 stop
koessl will become famous soon enoughkoessl will become famous soon enough
repzzzzzzzzz
Military Crew
Completely stock... I promise.
Old May 18th, 2010, 10:28 PM   #7
mell0's Avatar
2002 Procharged GT, STR
12.503 @ 113.08
mell0 is just really nicemell0 is just really nicemell0 is just really nicemell0 is just really nice
Send a message via AIM to mell0
good stuff, but don't forget the boost is going to change per head unit. for example, a p1sc makes 8 lbs with a 3.85inch pulley, but a d1sc will make 8 lbs with a 4 inch pulley, so the pulley sizes to boost comparisons aren't going to be the same with all the vortech head units, or all the procharger head units. just something to consider.
and it's called the F1-A, not the F1-SC.
2002 Procharged GT
12.503 @ 113.08
351rwhp 353rwtq
Car Videos: http://www.youtube.com/user/mell00ut5?feature=mhee
Old May 18th, 2010, 10:28 PM   #8
00mustang00's Avatar
2011 Caddy cts, 09 Jag XJ
00mustang00 has a spectacular aura about00mustang00 has a spectacular aura about
reps man thats an amazing write up!!!
2000 GT- Gone but not forgotten
Old May 18th, 2010, 10:30 PM   #9
mell0's Avatar
12.503 @ 113.08
and don't forget the aviator pump either. supposedly flows in between the GT and svt focus pump, but requires no modification to fit in.
2002 Procharged GT
12.503 @ 113.08
351rwhp 353rwtq
Old May 18th, 2010, 10:32 PM   #10
Imran's Avatar
01
Imran has much to be proud ofImran has much to be proud ofImran has much to be proud ofImran has much to be proud ofImran has much to be proud ofImran has much to be proud ofImran has much to be proud ofImran has much to be proud of
However, if you're slowly building up a kit, you will get bored in the waiting process and will wish that you hadn't sold your cams for parts that you can't install yet.
Old May 18th, 2010, 10:33 PM   #11
Shaun03GT's Avatar
2003 Mustang GT
iTrader: 12 reviews
Not to many people run the Aviatior pump so I didnt bother. Pete and Mike Dez told me it sucks, better off with the 255lph so I didnt bother to post it
Old May 18th, 2010, 10:39 PM   #12
Shaun03GT's Avatar
2003 Mustang GT
iTrader: 12 reviews
I gotta disagree with you. Theres nothing better knowing you got a steal on something. And your saving up for something better. Unless it takes you like 6 months to save up for everything then I guess I could see where ur coming from.
Building a kit would take less time to save up for a new kit anyways, and get it for less than half the price
Old May 18th, 2010, 10:40 PM   #13
VivaLaMustang's Avatar
VivaLaMustang is on a distinguished road
Great writeup. Supercharging is the way to go. Best HP per $$
2000 Ford Mustang GT (Auto), AM CAI, Flowmaster Exhaust, Mach 1 Chin and Grill Delete Kit, Mach 1 Honeycomb rear panel
Old May 18th, 2010, 11:15 PM   #14
It's in the details Mod!
M.P. Cobra Fan's Avatar
01 Cobra Vert
Nov 09/10 ROTM!
M.P. Cobra Fan has a reputation beyond reputeM.P. Cobra Fan has a reputation beyond reputeM.P. Cobra Fan has a reputation beyond reputeM.P. Cobra Fan has a reputation beyond reputeM.P. Cobra Fan has a reputation beyond reputeM.P. Cobra Fan has a reputation beyond reputeM.P. Cobra Fan has a reputation beyond reputeM.P. Cobra Fan has a reputation beyond reputeM.P. Cobra Fan has a reputation beyond reputeM.P. Cobra Fan has a reputation beyond reputeM.P. Cobra Fan has a reputation beyond repute
I added this thread to the stickied 99-04 info and how to thread.
Reps as well
Pinup in signature by loish.net
Modded Mustangs Cobra Club#007
Military Crew E5
VOTED MM's BEST SIGNATURE 2010. THANKS STANGGTR07
Old May 18th, 2010, 11:19 PM   #15
Shaun03GT's Avatar
2003 Mustang GT
iTrader: 12 reviews
sweet thanks man!! What about the how to build an affordable supercharger thread? Thanks again
Old May 18th, 2010, 11:28 PM   #16
April 2012 ROTM
wishIhada5.0's Avatar
2002 GT, True Blue, Stick
wishIhada5.0 is a jewel in the roughwishIhada5.0 is a jewel in the roughwishIhada5.0 is a jewel in the roughwishIhada5.0 is a jewel in the rough
Send a message via AIM to wishIhada5.0
dude...awesome write up...all of the fuel mods apply for KBs too...youz haz teh repz!!
True blue crew founder/member #1
378/442 rwhp/rwtq*on a Mustang dyno* cams are in..#'s coming this summer
Old May 18th, 2010, 11:40 PM   #17
01 Cobra Vert
Nov 09/10 ROTM!
No problem man. Done.
Military Crew E5
Old May 18th, 2010, 11:41 PM   #18
Shaun03GT's Avatar
2003 Mustang GT
iTrader: 12 reviews
Cool thanks dude much appriciated
Old May 18th, 2010, 11:48 PM   #19
BYAHHHH!
Scott2001GT's Avatar
2001 Mustang GT
13.874
Procharger as 2 different intercoolers. 3 core and 2 core.(there is a race type too) but a 2 core will take a less boost than a 3 core. With a P1sc and a 3.4 pulley I make 10psi at 6k. Thats with a 3 core intercooler. WIth a 2 core I could prob so 11 or so. WIth a D1sc I would be about 15 or so.
Prochargers use a 107.xx belt for a 4in to 3.4 pulley.
You could also mention rib setups!
Old May 18th, 2010, 11:52 PM   #20
BYAHHHH!
2001 Mustang GT
13.874
also 39lbs injectors are ev6 injectors. You will need adaptors to work. YOu can find them on 03-04 Cobras.
Threads Similar to: People who want to go Supercharger...READ
This is some bs Time warner people read dr.gonzo! The Clubhouse 14 December 31st, 2008 08:19 AM
People who live in/or near Oklahoma, Please Read! 98stangv6 The Clubhouse 0 September 4th, 2008 11:22 PM
People who live in/or near Oklahoma, Please Read! 98stangv6 Southwest 0 September 4th, 2008 11:21 PM
OK/TX Six Flags event people. Please READ 98stangv6 The Clubhouse 14 August 5th, 2008 10:51 PM
