Timing cover for a 99 GT
Old May 18th, 2010, 10:25 PM   #1
AllThrtl is on a distinguished road
I know the timing covers were unique for the 99 models, but are there any other that are interchangeable? The stock one for my 99 is toast, looks like a new one from ford will run about $300, surely there's another option that will still use my 3 bolt tensioner and belt configuration. I've found a few that are similar, but casting numbers are different... Any ideas?
Old May 19th, 2010, 12:01 AM   #2
mm's nitrous mod
SWEET2KSTANG's Avatar
2000 mustang gt
11.79@115.83 (old set up)
iTrader: 8 reviews
the 00 models had the same cover, both years were windsors. i cant remember if mine is a 3 bolt or not tho. i know the auto's i have ran across were 3-bolt, but not sure about manuals. i just havent paid enough attention. the covers are interchangeable, and you can route the belt different as well if needed.
Old May 19th, 2010, 12:31 AM   #3
Moderator
casper gt's Avatar
2012 300a gt auto
12.10@116
casper gt has a brilliant futurecasper gt has a brilliant futurecasper gt has a brilliant futurecasper gt has a brilliant futurecasper gt has a brilliant futurecasper gt has a brilliant futurecasper gt has a brilliant futurecasper gt has a brilliant futurecasper gt has a brilliant futurecasper gt has a brilliant futurecasper gt has a brilliant future
my 2000 windsor has a 1 bolt tensioner & its an auto. the 3 bolt thing is just for 99's as far as I know.
MM BRACKET RACING CREW CO-FOUNDER
BAMA Performance Drag Team Founder
2012 300a GT auto
Old May 19th, 2010, 12:33 AM   #4
Moderator
casper gt's Avatar
2012 300a gt auto
12.10@116
the belt routing is the same though for all 99-04's, regardless of the tensioner.
2012 300a GT auto
Old May 19th, 2010, 12:36 AM   #5
I think they used the 3 bolt tensioner in 2001, but on a romeo motor. I wonder if it's possible to modify a romeo cover to fit. I think it would just involve enlarging a few of the bolt holes for the windsor's larger 10mm bolts in the heads and at the bottom...
Old May 19th, 2010, 01:08 AM   #6
Moderator
casper gt's Avatar
2012 300a gt auto
12.10@116
should be about it.
2012 300a GT auto
Old May 19th, 2010, 11:26 AM   #7
ok, thanks, I'm on the hunt for one if anyone has something laying around....
Threads Similar to: Timing cover for a 99 GT
timing cover ? Graytex 96-98 3 July 25th, 2009 03:29 AM
timing cover ZoomZoomMFer 99-04 8 September 16th, 2008 04:08 PM
Help Please Timing Cover!!!! Stang281GT 99-04 12 July 9th, 2008 05:53 PM
timing cover Black Five 0h 5.0 Mustangs 3 April 17th, 2008 09:52 AM
Timing Cover 68 dlxcoupe 96-98 3 March 31st, 2008 01:59 AM
