#21 |
2003 Mustang GT
Yea thats what I ment, gaskets for the headers where they meet the heads. I only said that because I remember what happened to yours f8l lol
![]() Vortech V1 Intercooled @ 11psi 394rwhp/392rwtq @ 9.5psi 415rwhp/400rwtq @ 11psi on Methanol Tuned By: Pete @ Performance Dyno Affordable Supercharger Build Guide Supercharger Info for Noobs |
#22 |
!FACEPLATED!
Yup I was stupid and used the gaskets that came with the headers, and had to swap them out for some SCE copper ones when I blew the pass side gasket. Luckily the second time doing it was way easier than the first time I did it. Still never remove the k member to do them
![]() MM Bracket Racing Crew Co-Founder ~Its a Drag Car, Not a Show Car~ LINK-->Custom Race Transmission Build<--LINK
#23 |
Ohhh ok, they are just saying where the collectors are I won't need the gaskets down there... which is what connects to the mid-pipe (Mac offroad h-pipe in my case)
Right? Thanks guys, god this forum is awesome! ![]() Suggestions for header gaskets? |
#24 |
!FACEPLATED!
Correct
#25 |
2003 Mustang GT
Wait what? You did longtubes without removing the K-Member??? How? I know your using Flowtech.
#26 |
!FACEPLATED!
K removal is not a must when doing long tubes, it just takes a little longer. it only took me 2 hours to swap out the header gaskets. You just need to be able to lift the enging up a little
#27 |
KB'd GT
I had a header leak that i had to fix. I knew i had to drop the k so i figured i'd put in a tubular K. Then coil overs, A arms, etc. I figured if i'm doing the front, might as well do some coil overs in the back. So new lowers, TQ arm, PHB, sway bar. Be careful because sometimes the "while I'm at it" can get really expensive!
#28 |
#29 |
2003 Mustang GT
F8L said he did the SCE Copper Header gaskets
#30 |
crap, he did! sorry! and those are the same part number no matter what header I'm using?
#31 |
how will i kno if i blow my gaskets? haha
cuz till now everything is running fine... except blowing that passenger AC line on the firs test drive. now my air isnt cold haha
![]() Stock Rear Springs FOR SALE! PM Me Stock 99-04 GT Exhaust Manifolds FOR SALE! PM Me |
#32 |
12.35@114.08 w/ 1.88 60'
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() iTrader: 7 reviews
@ OP I used the FRPP gaskets. Part number will be the same regardless of what brand of header you're putting on
It'll tick like an exhaust leak. Almost sounds like an older car with a bad lifter
Do the Right Thing, Cook. ~Zip. |
#33 | |
#34 |
It'll tick because there is only exhaust going through it every other upstroke of the piston. If it were a hiss that means that something is leaking that constantly has pressure to it.
#35 |
Interesting. I think I have a leak wher my prochamber bolts to my stock catback on the passenger side. Cuz when I drive near metal guard rails or watev it sounds like a "sssssssss" like a sssssnake. Hahah
Threads Similar to: longtube header install; while I'm in there...
| longtube header install | Speedstang302 | 96-98 | 77 | March 15th, 2010 08:02 PM |
| Longtube header question | ndfrspd | 99-04 | 4 | May 22nd, 2009 03:21 PM |
| Mac Longtube Header install | Srt2stang725 | 2005 - 2010 | 31 | April 2nd, 2009 11:26 PM |
| longtube header install question | russell16 | 99-04 | 5 | September 21st, 2008 02:54 PM |
| longtube header install time | thecloneranger | 2005 - 2010 | 3 | February 19th, 2008 12:37 PM |
