2003 Mustang GT
5.00@speed of sound
ac idle
Hi you guys, New to the forum
Anyways on to the question. 2003 Mustang GT. Why is it when my ac is on, the car idles absolutely perfect. but if i turnd the ac off, my cars spits and sputters. The car is perfectly fine, all tuned up. the only thing out of date is the front 02's. but if they were bad, why would it idle so perfect with the ac on? Dumb question? GET OVER IT its the internet haha |
2001 Mustang GT
change the belt and o2s
2001 Mustang GT
![]() ![]() ![]() iTrader: 3 reviews
Screw the O2's, your problem sounds like a dirty IAC (idle air control) valve. You could try cleaning it with something like MAF cleaner and see if this fixes the problem. If not you might have to replace it like I did. My car died when I turned the A/C on instead of off, but the IAC is a common occurance on these cars.
![]() True Blue Crew Member #2 315's Crew Member (Dat azz) 255/298 Founder of the please leave my signature alone, I want it to say what I put there and don't appreciate you deleting it club |
Don't turn the a/c off, problem solved! I am good, huh. You idle picks up every time your compressor kicks in, at least thats how it works on a stick because the idle is lower than an automatic. An automatic is idled a little higher to keep it running smooth when in gear and the brake applied. Again, at least thats how it works on foxbodies. Thats why its not recommended to use a computer from a stick in an auto (foxbody). I would try the iac cleansing and while you are at it, wouldn't hurt to clean the maf and change the air filter if its old.
2003 Mustang GT
5.00@speed of sound
leave the ac on huh? you see that becomes a problem during winter.
like i said, the car is tip top, i keep my throttle plate, plenum, and idle control motor clean, i check it every 10xxx maybe ill replace the iac though. its just weird, my car has never idled well. i could understand a little rough, but mine just gets plain nasty sometimes |
Threads Similar to: ac idle
| Mustang idle surge and base idle reset | 1slo5.0 | 5.0 Mustangs | 47 | July 26th, 2011 10:52 PM |
| A new way for our idle to F up!!! | Novanutcase | 99-04 | 2 | June 2nd, 2009 11:59 AM |
| Cant idle | Lazor05 | 5.0 Mustangs | 13 | March 21st, 2009 05:19 PM |
| Aftermarket TB/Plenum hanging idle/low idle issues! | Novanutcase | 99-04 | 12 | August 13th, 2008 11:24 AM |
| Idle Problems Code 1506, Idle Overspeed Error | jagstang96 | 96-98 | 3 | August 29th, 2006 04:11 AM |
