Car will not run after Vortech removal - Page 2
Old May 20th, 2010, 09:42 AM   #21
Blackbird1084 will become famous soon enough
Check your fuel shut off switch. Sounds like a vac leak or not enough fuel. Drop the tank and make sure there are no kinks in the line.
79 Buick regal 13.70 @102 350 sbc
97 Trans Am WS6 11.94 @112.26 1.603 60ft @Kcir
04 SRT-4 13.42@113.55 2.37 60ft
04 Mustang GT 12.19 @111.88 347hp 432tq 100 shot
06 Mustang GT 12.2929@114.30 2.01 60ft
MM Bracket Racing Crew Member #4
Old May 20th, 2010, 10:03 AM   #22
nathanielwilliam's Avatar
2001 Mustang GT
nathanielwilliam is on a distinguished road
Don't call me crazy...
An old mechanic showed me how to check for vacuum leaks and I have always used it.
Take a can of starting fluid or ether and spray it all around your engine while it is running. if the car starts to rev up, you found your leak.
wear some protective gear when you do this in case something happens.
I found the vacuum leaks on my 98 F-150 this way as well as some other people's cars.
2001 Mustang GT
short throw shifter
4:10 gears
3 inch dual exaust (no cats!)
I have an F-150 which I drove the balls out of for seven years. Now I have a mustang that I drive the balls out of also.
Old May 20th, 2010, 10:33 AM   #23
ZenMGT's Avatar
'02 GT 5spd
ZenMGT will become famous soon enough
when you were swapping MAFs,,,were you changing around the sensors, and housings? Maybe the '04 ended up with the 90mm housing and stock maf.
unless I read it wrong.
boringly stock........but running well
Old May 20th, 2010, 10:40 AM   #24
2011 Mustang GT 5.0
03_100th is on a distinguished road
nope, straight maf swaps. housing and electronics.
Old May 20th, 2010, 10:55 AM   #25
Your not crazy Nate I do the same thing and it works.
Old May 20th, 2010, 01:46 PM   #26
JLC_04GT's Avatar
JLC_04GT is on a distinguished road
just put it back!!!
Da General -S&B c.a.i, TB spacer, 75mm TB, OBX aluminum pulleys, DiabloSport Programmer, 3.73s, 75/100 shot of NOS!!!
Texas Stangs Crew!
Punishment Racing!!!
Get It Down Crew!!!
Old May 20th, 2010, 01:49 PM   #27
2011 Mustang GT 5.0
Originally Posted by JLC_04GT View Post
just put it back!!!
Put what back?
Threads Similar to: Car will not run after Vortech removal
Vortech guys, where di you run your bypass vacuum?? 01MGGT 99-04 3 April 11th, 2010 02:57 PM
Suggestion for car scratch removal products? roxas331 General Car Care & Detailing 5 August 4th, 2009 08:06 PM
What Will My Car Run? 1990mustanggt 5.0 Mustangs 15 July 26th, 2007 09:27 PM
What oil to run on a vortech supercharger?? bossman2kgt 99-04 7 June 24th, 2007 04:44 PM
removal of a vortech loosenut 99-04 5 November 21st, 2005 10:39 PM
