2011 Mustang GT 5.0
Car will not run after Vortech removal
OK...I am about to my wits end....
The vortech kit was removed from a 2004 and installed on a 2003. The deal with the 04 was that he did not have the stock parts to put back on, so we put the stock parts off of the 03 on it. Here is a list of the stock parts....throttle body, injectors, MAF, fuel pump and inlet ducting. The only issue that was found was that the 04 had a 90mm lightning MAF on it so when it was put back to stock we had to splice the 2 wires for the built in IAT sensor back on the MAF plug. At first I just used crimps and I thought that maybe that was the issue with the bad running. Well, tonight I soldered the wires instead and it still does not run right. The car starts and idles for a little while then dies. While it is running, if you try to give it throttle it will sputter and hesitate and then die. I am out of ideas, please help...
2003 Mustang GT
Thats because the car hates you for taking the Vortech off.
![]() Vortech V1 Intercooled @ 11psi 394rwhp/392rwtq @ 9.5psi 415rwhp/400rwtq @ 11psi on Methanol Tuned By: Pete @ Performance Dyno Affordable Supercharger Build Guide Supercharger Info for Noobs |
I Blumpkin Entirely Way Too Much
2005 Mustang GT
did you reflash your tune? your computer was tuned to run with the vortech, now theres no vortech. which means it wont run right til its tuned
MM + Cleavage member #22
Did you reconnect the IAC? That is what my car did when I had my IAC in the wrong spot. Take a picture of the engine bay and maybe we can help more. Also, make sure the car has a tune for the Lightning MAF and is tuned for the change in injector size etc.
Vortech V-2 SQ 3.33 pulley, Intercooler, Tial BOV, SCT XCal2, KB BAP, Pro-5.0 STS, Accufab 75mm TB and Plenum, O/R H-Pipe, Flowmaster exhaust, 3.73 gears, MM XD LCA's, Lakewood 70/30 Struts, MM CC Plates, UPR Front Coil Overs with 14/175 lb springs. |
2011 Mustang GT 5.0
2011 Mustang GT 5.0
Yes, the car has a new tune in it from an SCT SF3 now. The weird thing is that the 04 was bought with the Vortech on it already. There is no chip connected to the computer and according to Vortech support that is what they do for those kits. There is also no tuner with the car so I have no idea how the car was running right in the first place, unless tthe previous owner used a tuner on the car but did not leave it with the car and did not put it back to stock. I thought at first that the computer may have to be reflashed to stock by Ford but when I installed a tune from my SF3 it did not help at all....That is 1 unlock down the tubes. The 04 is not my car. I bought the kit from this guy for $1100. It came with a BBK 75mm TB, Vortech kit, 42lb injectors, 90mm lightning MAF, AFM powerpipe and a SVT Focus pump and installed it on my 03.
2011 Mustang GT 5.0
The IAC for 03 and 04 are built into the stock MAF. The lightning MAF and the bigger injectors are now on my 03. It is tuned with an SCT Livewire and runs just fine. It is the 04 that we put back to stock and now does not run right...
not the IAT (Intake Air Temperature) sensor, the IAC (Idle Air Control) valve.
2011 Mustang GT 5.0
lol...sorry read that wrong. The IAC is plugged in. It is the stock one that came off of my 03. We switched throttle bodys also. What do you mean by you had your IAC in the wrong spot? It is connected to the TB and can only go on one way.
2003 Mustang GT
is their a vacuum leak somewhere?? Not throwing any codes? TPS voltage?
2011 Mustang GT 5.0
I have not seen any vacuum lines unplugged. No codes. Did not check the TPS voltage, I figured it was OK since it was working just fine on my car. Do you know what it is suppose to read on these cars? I know the Fox bodies like to be set to around .95 I believe?
2003 Mustang GT
I forget to be honest. Hmmm, idk this is odd. Im trying to think of some things. Im stumped to be honest. Hopefully someone else can help you more....
Did you clean the IAC? Disconnect the battery for an hour and then connect it?
2011 Mustang GT 5.0
Nope, didnt try cleaning it. It was working great on my car. I will try the battery again.....
2002 mustang gt
Na
Check vac line to throttle body same thing was happening when I blew off the line from valve cover to throttle body
12.85 @ 114
so the 04 has 03 MAF, injectors, intake, plenum, throttle body, etc
and you sure you are tuning the car right? I mean, fuel wise?
![]() MODS: Vortech V1 T-Trim @ 7.5 PSI (tuned down) Comp Cam Stage 2's + more 432 rwhp / 396 rwtq 02/27/2011 NEW VIDEOS! **It takes ~$60 a rwhp (over stock) for a 99-04 Mustang GT.** Do the Math ![]() C2H5OH on the horizon |
I Hate Convertibles...
check the vacuum line on the back of the plenum, its easy to miss and leave unplugged.
2011 Mustang GT 5.0
The 04 has an 03 maf, injectors and throttle body only. Should these parts exchange for stock on each car? The tune is just a built in tune on the SF3 for a stock car. Wouldn't an 04 have pretty much the same stock parts as an 03?
2011 Mustang GT 5.0
#19 | |
12.85 @ 114
Mafs hooked up right? Did you hook the IAT back up to the stock MAF? You tuned it in that tuner back to stock injectors? What about spark plugs? cops?
#20 | |
2011 Mustang GT 5.0
Yes, I had to splice the the two end (gray) wires back into the harness for the MAF plug. yep, stock injectors, stock maf. Unless for some reason the car is not taking the tune. It says on the tuner that it downloaded fine into the car, so I cant see that being the issue. Never pulled the plugs or COPS. The car should still at least run if the plugs are still gapped tighter than stock dont you think? |
Threads Similar to: Car will not run after Vortech removal
| Vortech guys, where di you run your bypass vacuum?? | 01MGGT | 99-04 | 3 | April 11th, 2010 02:57 PM |
| Suggestion for car scratch removal products? | roxas331 | General Car Care & Detailing | 5 | August 4th, 2009 08:06 PM |
| What Will My Car Run? | 1990mustanggt | 5.0 Mustangs | 15 | July 26th, 2007 09:27 PM |
| What oil to run on a vortech supercharger?? | bossman2kgt | 99-04 | 7 | June 24th, 2007 04:44 PM |
| removal of a vortech | loosenut | 99-04 | 5 | November 21st, 2005 10:39 PM |
