LOWER INTAKE MANIFOLD please help
Old May 20th, 2010, 12:15 PM   #1
2002 mustang gt
quickndslick2 is infamous around these partsquickndslick2 is infamous around these parts
Send a message via AIM to quickndslick2
Question
i need to get a lower intake manifold by the end of this week i was looking at thyphoon but dont know to much about it, then elderbrock but they have carburated or not and idk which to get, and theres a ford racing 1 that is PI and its thicker and bigger than stock, i have no idea which or what to get if any of you guys can point me in the right direction i would apreciate it, i also checked out trick flow track heat but its not the same set-up or look as the 1 i have so i dont know if it will work well with my cai tb and plenum, what do u guys recommend????
Old May 20th, 2010, 12:24 PM   #2
Blackbird1084 will become famous soon enough
Why do you need it?
79 Buick regal 13.70 @102 350 sbc
97 Trans Am WS6 11.94 @112.26 1.603 60ft @Kcir
04 SRT-4 13.42@113.55 2.37 60ft
04 Mustang GT 12.19 @111.88 347hp 432tq 100 shot
06 Mustang GT 12.2929@114.30 2.01 60ft
MM Bracket Racing Crew Member #4
Old May 20th, 2010, 12:47 PM   #3
12.35@114.08 w/ 1.88 60'
dcook_14 is a splendid one to beholddcook_14 is a splendid one to beholddcook_14 is a splendid one to beholddcook_14 is a splendid one to beholddcook_14 is a splendid one to beholddcook_14 is a splendid one to beholddcook_14 is a splendid one to beholddcook_14 is a splendid one to behold
iTrader: 7 reviews
As far as the edlebrock piece, do you plan on running a carb? If not then get the non-carbed version.
Unless you're pushing major power just get a replacement stocker
Do the Right Thing, Cook. ~Zip.
Old May 20th, 2010, 12:52 PM   #4
2002 mustang gt
i have stage 2 heads and the port job is way biiger than the stock intake manifold holes so not enough air is flowing threw
Old May 20th, 2010, 01:03 PM   #5
iTrader: 7 reviews
Can you get the intake port matched?
Old May 20th, 2010, 01:36 PM   #6
Dcook you can't really port the stocker without risking cracking.
Old May 20th, 2010, 02:32 PM   #7
1999 GT 35th LE
99GT35thLE has a spectacular aura about99GT35thLE has a spectacular aura about
Buy the Typhoon and have a shop do a gasket match port job for you.
That's what I had done to mine and it runs good, but most of your power is in the high RPMs, not a lot on the lower end. Mine really moves when I hit about 3500 rpm, but with the heads and cams I have on mine I'm running to 6500 rpm.
Drive it like you stole it
Old May 20th, 2010, 03:04 PM   #8
iTrader: 7 reviews
Good to know, thanks blackbird!
What about the FRPP unit? That's a lot thicker than the stocker, and probably not plastic
Old May 20th, 2010, 04:10 PM   #9
2002 mustang gt
im runnin to 6500 rmps too will get a custom dyno tune next wendsday i will let u guys noe
Old May 20th, 2010, 04:27 PM   #10
The frpp bullitt style intake(2v svo) won't match up to regular 2v heads from my understanding. If you want an intake that won't crack if you have an n2o backfire but don't want to spend a ton then by all means get the typhoon. But the hardballr will see alittle bit better gains. Since your reving to 6500 then the trickflow or the edelbrock will take you up there with ease. The edelbrock is cheaper then the trickflow to get it all setup. Unless your like me and scoure eBay and find a track heat for just over half of retail.
Threads Similar to: LOWER INTAKE MANIFOLD please help
lower intake manifold help pleaseee quickndslick2 99-04 2 April 7th, 2010 09:29 PM
hole on lower intake manifold? tvc2389 5.0 Mustangs 2 March 18th, 2008 09:59 PM
2003/2004 lower intake manifold Fast98stang 99-04 2 January 12th, 2008 10:49 PM
gt40 upper/lower intake manifold MustangSparks 94-95 1 July 17th, 2007 04:14 AM
