8 or 6 bolt pressure plate?? - Forums at Modded Mustangs
post #1 of 23 Old May 24th, 2010, 10:41 AM Thread Starter
01KnightRiderGT's Avatar
Send a message via MSN to 01KnightRiderGT
So I started doing my auto to manual swap.
Which is the appropriate flywheel for my crank, I have a 2001 Mustang GT, is it a 8 or 6 bolt????
Thanks to all
btw i meant flywheel not pressure plate
Black Stang Member #13
315's Crew Founder
My Track Videos
01KnightRiderGT is offline
post #2 of 23 Old May 24th, 2010, 10:45 AM
SteviGX's Avatar
Send a message via AIM to SteviGX
The pressure plate will come with your clutch kit. The flywheel is either 6 or 8 bolt. Do you have romeo or windsor heads?
Mineral Gray Club Member #2
Just your average 22 year old dumbass
If you didn't build your car, and your bragging about it, STFU
SteviGX is offline
post #3 of 23 Old May 24th, 2010, 11:01 AM Thread Starter
Im not really sure.
My door jam sticker has a date of 08/01, so my guess is that it will be the 01-04 Mustang which will be a 6 bolt.
Right???
I also decoded my VIN number and discovered that my car was assembled in Dearborn: Dearborn, Michigan.
Not sure if that will help....
315's Crew Founder
My Track Videos
post #4 of 23 Old May 24th, 2010, 11:19 AM
SteviGX's Avatar
Go count your valve cover bolts just to make sure. You'll either have 11 or 13/14. That way you can make sure.
SteviGX is offline
post #5 of 23 Old May 24th, 2010, 12:25 PM
UnixHH's Avatar
Send a message via Yahoo to UnixHH
wont the pressure plate work on both 6 and 8 bolt flywheels?
480RWHP 450RWTQ 15psi @ 15* on 91 octane
UnixHH is offline
post #6 of 23 Old May 24th, 2010, 12:48 PM
SteviGX's Avatar
yeah...just a matter of what size clutch he needs to pick up. But yeah you are right
SteviGX is offline
post #7 of 23 Old May 24th, 2010, 12:50 PM Thread Starter
I meant to to say the flywheel in my OP.
I counted the valve cover bolts, and i have 11 on each side
315's Crew Founder
My Track Videos
post #8 of 23 Old May 24th, 2010, 12:58 PM
UnixHH's Avatar
ra ra ra rrooomeo 6 bolt crank
UnixHH is offline
post #9 of 23 Old May 24th, 2010, 01:00 PM Thread Starter
so it is a 6 bolt flywheel
Thanks guys reps
315's Crew Founder
My Track Videos
post #10 of 23 Old May 24th, 2010, 07:21 PM
SteviGX's Avatar
yep unix got it. Glad to help man.
SteviGX is offline
post #11 of 23 Old May 28th, 2010, 09:05 AM Thread Starter
I was able to find this package that brings everything needed, well almost everything
Look here
Looks like a good kit.
What are yalls opinions on this clutch?
Seems to bring everything for the clutch end
But i'm a bit curious, it says to check the 8th digit of your VIN if it is a W then you have the 6 bolt crank.
But my 8th digit is a X soooo….
It confusing because it says that the kit is applicable for a 1996-2004, but it also says that it’s for a 6 bolt crank, don’t 1996-2001 bring a 8 bolt crank, and a 2001-2004 have the 6 bolt….
Lol you see my confusion….
Thanks again
This is what they say......
Q: What flywheel do I use for my 4.6?
A: All 4.6 Cobras use an 8 bolt flywheel, FMS # M6375G46 for Billet or M6375R00 for Aluminum. GT's are a little different. You will need to check the VIN # of the car. If the 8th character in the VIN is the letter X, the motor is a Windsor and will use the same 8 bolt flywheel as the Cobras do. If the 8th character is the letter W, the motor is a Romeo and uses a 6 bolt flywheel part # M6375F46.
315's Crew Founder
My Track Videos
post #12 of 23 Old May 28th, 2010, 09:42 AM
SteviGX's Avatar
You have an 11" clutch. So this one will work since it's a 10.5
SteviGX is offline
post #13 of 23 Old May 28th, 2010, 09:45 AM Thread Starter
but my valve cover has 11 bolts which means its a romeo right?
315's Crew Founder
My Track Videos
post #14 of 23 Old May 28th, 2010, 09:48 AM
SteviGX's Avatar
Yeah. I'm ass backwards man sorry. 6 bolt not 8. That ad makes no sense. If you have a romeo car it should be 6 bolt??? So..idk.
SteviGX is offline
post #15 of 23 Old May 28th, 2010, 09:50 AM Thread Starter
Im so fucking confused, I have been piecing a whole kit for a 6 bolt crank, now to discover that I have an 8 bolt crank. (i think)
315's Crew Founder
My Track Videos
post #16 of 23 Old May 28th, 2010, 02:49 PM Thread Starter
any ideas???
315's Crew Founder
My Track Videos
post #17 of 23 Old May 28th, 2010, 02:50 PM
if the car isn't your dd, you could just pull the trans out and count the bolts since you're gonna do it anyway.
roybrown45 is offline
post #18 of 23 Old May 28th, 2010, 02:51 PM Thread Starter
it is a DD
lol
i need to know what flywheel and clutch to order, i dont have everything yet to pull the tranny
315's Crew Founder
My Track Videos
post #19 of 23 Old May 28th, 2010, 03:04 PM
DegralDan's Avatar
My 99 is a Windsor and 8 bolt, I don't know when or why they changed it. I think i remember 13 valve cover bolts
http://i25.photobucket.com/albums/c57/audegral/2df4ef84.jpgOle Reliable
DegralDan is offline
post #20 of 23 Old May 29th, 2010, 08:11 PM Thread Starter
for any other ideas???
315's Crew Founder
My Track Videos
Human Verification
