#41 | |
12.85 @ 114
260 CRANK hp. Not rear wheel. Listen, we have all been around the block, and we would know if you could achieve 300 RWHP w/out heads and cams. With FULL bolt ons, (minus heads and T/B ONLY) I maxed out at 288 rwhp. That is with one of the best tuners on the east coast tuning my car. There is no WAY you are at 300 rwhp w/out heads/cams. There just isnt enough bolt ons that can get you that high. Either your numbers are crank HP/TQ or something was off.... Trust us. We are not jealous I promise. but back on topic, get a supercharger for sure. Depending on the pulley size, you cna make whatever numbers you feel comfortable with. I make 408 right now and If just put on the next step up pulley, I will make 450+
![]() MODS: Vortech V1 T-Trim @ 7.5 PSI (tuned down) Comp Cam Stage 2's + more 432 rwhp / 396 rwtq 02/27/2011 NEW VIDEOS! **It takes ~$60 a rwhp (over stock) for a 99-04 Mustang GT.** Do the Math ![]() C2H5OH on the horizon Last edited by 0949er; June 22nd, 2010 at 12:19 AM. |
#42 |
13.7@103
You wouldn't make 370 with heads and cams. TO THE WHEELS NOT FLYWHEEL.
find a little vortec, throw a 9psi pully on it. then you'll have 370-400 to THE WHEELS NOT FLYWHEEL. Your welcome.
![]() Bigbore Kooks (parting out 2v motor) N/A 5.3 4v Build
http://www.moddedmustangs.com/forums...ing-build.html |
#43 |
12.85 @ 114
hey what you callin little? :-p
![]() MODS: Vortech V1 T-Trim @ 7.5 PSI (tuned down) Comp Cam Stage 2's + more 432 rwhp / 396 rwtq 02/27/2011 NEW VIDEOS! **It takes ~$60 a rwhp (over stock) for a 99-04 Mustang GT.** Do the Math ![]() C2H5OH on the horizon |
#44 |
MM's Orangest
2004 Mach 1 Mustang
You could with 4V heads. Just saying.
![]() Looking for 03/04 4V ABS Wiring Harness Connector/Incomplete Wiring Harness (with ABS connector) |
#45 | |
Da General -S&B c.a.i, TB spacer, 75mm TB, OBX aluminum pulleys, DiabloSport Programmer, 3.73s, 75/100 shot of NOS!!! ![]() ![]() Texas Stangs Crew! Punishment Racing!!! Get It Down Crew!!! |
#46 | |
#47 |
11.85 @ 125
![]() ![]() iTrader: 2 reviews
i had a novi 2000 on my 02 gt and it made 400rwhp & 400rwtq on 10 psi with water/meth injection. the water/meth was the key to making the numbers. I only made 365 rwhp & 375 rwtq without. hope this helps.
#48 |
Damn dude 300hp on a dyno ?? Thats a factory freak or you have more then you know. Anywho I never seen a 2v or 4v dyno that with out a blower or H/C work but if thats what your mustang is putting down then sweet jesus grats ! I say throw a Procharger on that bad boy and go rape some bowtie boys.
#49 |
2004 mustang gt almosgt:)
13.8 @ 108.33
i would deffinatly go with the supercharger. jus get it tuned and dynoed right and you will be laying down 400-425rwhp easy. max boost i would say for stock bottom end would be 8 psi. good luck deciding tho
#50 |
OP just curious if you know what Compression your engine is at ?? Did not proof read whole thread.
#51 | |
MM's Orangest
2004 Mach 1 Mustang
#52 | |
12.73@111.36
ProCharger P-1SC, 9 psi, STD 396/383; Uncorrected 388/375; SAE 383/370 Mods list in Garage. |
#53 | |
![]() 2003 DSG Mustang GT 5spd Full Bolt On's, Suspension, Built Rear, V1 S N/A: 266/300, 3,550lbs, 13.44 @ 100.5 1.77 60' Non-intercooled: 356/371, 3,575lbs, 12.81 @ 110.47 1.86 60' Intercooled: 362/370 |
#54 |
2002 Mustagg GT
1/4 - We'll see soon
Dude get what will make you feel better. Quick HP and room to grow = Supercharger
NA power which is badass in my book -- Heads, cam, manifold, injectors, pump, great tune, & maybe some added compression and you can make so real HP to the wheels on that motor but will cost you prob double what you can get a used charger for. ** Off topic ** I put down 260 / 300 to wheels & I have full bolt ons. Just added a stewart water pump which prob give me 5-6 to wheels so thats 260. Also mild cams suposidly and mild port & the tuner said that my motor pulled strong for what was done so If you are at a legit 300 to the wheels I really wonder where that 40 is comming from B/C I want that! ha. You say car stock 260 but in reality it is like 200 to the wheels & maybe 220 if your lucky so IDK bro. +++ Welcome!
" Drive Fast - Take Risks " LawlessRebel ![]() SOLD - My 02 Supercharged. Got a 95 5.0 for a few weeks till I sell or trade it!
#55 |
2002 Mustagg GT
Yeah you should post that Dyno sheet. Would like to see the power curv. What type dyno? My guy had the DynaPack dynos.
Threads Similar to: Heads and cams or supercharger???
| Heads, cams, intake or supercharger???? | cedp83 | 99-04 | 76 | May 20th, 2010 01:18 PM |
| Turbo cams vrs supercharger cams | adrenaline=lifeline | 99-04 | 7 | October 26th, 2008 01:10 PM |
| heads and cams with supercharger?? | SilverStang03 | 99-04 | 3 | October 18th, 2008 02:51 PM |
| supercharger or full bolt ons,heads,cams | sonicblue | 99-04 | 8 | August 25th, 2006 08:28 PM |
