Heads and cams or supercharger???
Old June 17th, 2010, 01:08 AM   #1
Myslowstang's Avatar
2003 Mustang GT
slow
Myslowstang is on a distinguished road
I have a mustang gt that puts down 300 rwhp and just like everybody else I want more. My question is should I do heads and cams like the new trick flow package or should I go for a supercharger like procharger. The only problem I have with the supercharger is that I think I'll have to detune it because of the limits of the bottom end. I'm leaning towards the new trick flow heads and some comp cams. What do you guys think?
Old June 17th, 2010, 01:13 AM   #2
2002 GT
poranksta is on a distinguished road
superchager, used procharger.
2002 GT', 5speed,
Magnaflow:
Magnapacks
Cat-less x pipe
K&N drop-in air filter
Old June 17th, 2010, 01:17 AM   #3
MustangGT06 is an unknown quantity at this point
Wait, you're putting down 300 RWHP with no heads/cam?
Old June 17th, 2010, 01:27 AM   #4
2003 gt
5.4 32v on the way
DickH is just really niceDickH is just really niceDickH is just really niceDickH is just really niceDickH is just really nice
Fast NA Gt is nice, but supercharged GT is faster.
Old June 17th, 2010, 01:43 AM   #5
Hooo Ha Ha
sharkbait's Avatar
1997 Mustang GT
11.65 @ 115
sharkbait has much to be proud ofsharkbait has much to be proud ofsharkbait has much to be proud ofsharkbait has much to be proud ofsharkbait has much to be proud ofsharkbait has much to be proud ofsharkbait has much to be proud ofsharkbait has much to be proud of
iTrader: 10 reviews
I think the dyno may be off a tad. But supercharger
410rwhp 520rwtq @ 12.9 psi
Old June 17th, 2010, 01:56 AM   #6
2003 Mustang GT
slow
Yes I'm putting down 300rwhp n/a without heads and cams but if I add a supercharger it should add about 150 hp right? That as far as I know (450rwhp) is too much. If I were to add some of those new trick flow heads with some 270 comp cams I think I should be close to the limit of the stock bottom end. I would like to put in the 278 comp cams but I don't think they will fit without some relief cuts in the pistons. I know they say that you can put bigger cams in with the new trick flow heads but what is the largest cam you can fit with the trick flow heads safely? I have 4:10 gears so a large cam is not out of the question.
Old June 17th, 2010, 02:01 AM   #7
Shaun03GT's Avatar
2003 Mustang GT
Shaun03GT has a brilliant futureShaun03GT has a brilliant futureShaun03GT has a brilliant futureShaun03GT has a brilliant futureShaun03GT has a brilliant futureShaun03GT has a brilliant futureShaun03GT has a brilliant futureShaun03GT has a brilliant futureShaun03GT has a brilliant futureShaun03GT has a brilliant futureShaun03GT has a brilliant future
iTrader: 12 reviews
How are you putting down 300rwhp no cams? or heads? You could be putting down 300hp at the motor...not at the wheels though.
Anyways, supercharger. If you paid for cams, valves, retainers, install (if you had to have a shop do it) you would spend maybe more than building or buying a used s/c kit.
Depending on boost level's and what not you should see between 360rwhp-420rwhp.....
But no way are you making 300rwhp no heads or cams...sorry man lol.
BTW Welcome to the forums
Vortech V1 Intercooled @ 11psi
394rwhp/392rwtq @ 9.5psi
415rwhp/400rwtq @ 11psi on Methanol
Tuned By: Pete @ Performance Dyno
Affordable Supercharger Build Guide
Supercharger Info for Noobs
Old June 17th, 2010, 02:03 AM   #8
2003 Mustang GT
slow
I don't think the dyno is too far off. My best time is 13.3 @ 103 mph and my heavy mustang weighs in at 3900. It's a conv so I'm trying to get a better idea what I should do before I put a roll bar in. Anybody have any luck with those trick flow heads???
Old June 17th, 2010, 02:08 AM   #9
Shaun03GT's Avatar
2003 Mustang GT
iTrader: 12 reviews
I traped at 104.8mph with 260rwhp...so your probally at 260-265rwhp...what are your mods?
Old June 17th, 2010, 02:14 AM   #10
2003 Mustang GT
slow
My car was dyno tuned at 300rwhp and 330rwtq. I have the dyno sheet. I have a full exhaust system and eveything from an intake manifold to the filter. Also have underdrive pullies and 4:10 gears. I know dyno pulls are not the best measuring tool but besides my 13.3@103 it's all I have. When I got my car my best time was 14.79 and it was stock for the most part.
Old June 17th, 2010, 02:16 AM   #11
Shaun03GT's Avatar
2003 Mustang GT
iTrader: 12 reviews
Idk man, 300rwhp really isnt likley...about everyone on these forums will tell you that.
Old June 17th, 2010, 02:16 AM   #12
Hooo Ha Ha
sharkbait's Avatar
1997 Mustang GT
11.65 @ 115
iTrader: 10 reviews
i ran a 13.6 at 227rwhp
Old June 17th, 2010, 02:20 AM   #13
Blown284's Avatar
1966 Mustang Coupe
Won't See The Track
Blown284 is a jewel in the roughBlown284 is a jewel in the roughBlown284 is a jewel in the rough
Send a message via Yahoo to Blown284
Post the dyno sheet/and mods done. If you're just rockin bolt on's and a tune there's no way you doing that @ the tire without heads/cams.
If I was you, I'd save a little more and rebuild the bottom end and boost. I eat N/A stangs all day long (no offense to any of you), but boost will make more power and you'll see better response to a lot of mods. I'm looking at headwork and cams and plan on a being somewhere in the area of 600 whp, right now with stock heads, a built bottom end, and 14psi I make 509 rwhp
Previous Rides
1997 Blown Cobra-Sold & Missed
2004 Lightning-Traded
2001 Turbo GT-Traded
1966 Mustang Coupe-Sold
2006 Audi A3-sold
1998 Bagged Silverado- Sold
1997 BMW AC Schnitzer 540i S5
Old June 17th, 2010, 02:20 AM   #14
2003 Mustang GT
slow
My local track is not a very good track. My buddy has an 02 gt with an 03 4v cobra motor with 471rwhp and his best time is 12.8
I'm not here to defend my car, I'm here to ask you guys what you think between adding some heads and cams to a stock 300rwhp motor or a supercharger.
Old June 17th, 2010, 02:26 AM   #15
Shaun03GT's Avatar
2003 Mustang GT
iTrader: 12 reviews
No ones trying to pick on you. Just letting you know theres definatley something wrong.
Also, do a supercharger. The money spent in heads and cams is a lot more than supercharging.
Old June 17th, 2010, 02:28 AM   #16
Blown284's Avatar
1966 Mustang Coupe
Won't See The Track
471 rwhp and damn near a 13 second 1/4 mile? Tell your buddy he needs to look into the "driver mod". Jesus thats horrible. I ran mid 11's on street tires on 509 rwhp.
And if you're motor is stock it isn't 300 rwhp (rwhp= rear wheel horse power) FYI. Unless you swappeda motor I call shinanagins
Previous Rides
2006 Audi A3-sold
Old June 17th, 2010, 02:29 AM   #17
2003 Mustang GT
slow
I'll have to scan it or take a pic my dyno sheet then post it. So everybody is saying supercharger huh? But isn't the limit of a stock bottom end around 425rwhp? Doesn't a supercharger add about 150rwhp on a 300rwhp motor? That's 450rwhp if I know my math or am I retarded?
Old June 17th, 2010, 02:31 AM   #18
Blown284's Avatar
1966 Mustang Coupe
Won't See The Track
I'd say retarded lol...j/k...Depends on boost...How much are planning on boosting.
Previous Rides
2006 Audi A3-sold
Old June 17th, 2010, 02:34 AM   #19
Hooo Ha Ha
sharkbait's Avatar
1997 Mustang GT
11.65 @ 115
iTrader: 10 reviews
I wouldnt say the supercharger adds 150rwhp...youve gotta work for that.
Matters how much boost your running.
Also i doubt your making 300rwhp and even if you dyno sheet reads it i know its not putting that much stress on the internals. You can probobly handle 6-8psi easily
Old June 17th, 2010, 02:42 AM   #20
2003 Mustang GT
slow
I'm telling you people that it's dynoed at 300RWHP!!! why is that so hard to believe? If the stock motor is 260hp and I've added EVERY bolt-on I could add why can't that add up to 360hp? Full lenght headers add? Off road h-pipe adds? Slp catback add? Intake manifold adds? Intake plenum? Spacer? TB? MAF? Filter? Underdrive pullies? Gears? Etc. Does anybody have full bolt-on with less rwhp? I'm telling you what I have. I'm asking for you help not defending my car. Please stick to the topic. Heads and cams or supercharger on a STOCK 300rwhp 4.6 2v motor?!?!?!?
Threads Similar to: Heads and cams or supercharger???
Heads, cams, intake or supercharger???? cedp83 99-04 76 May 20th, 2010 01:18 PM
Turbo cams vrs supercharger cams adrenaline=lifeline 99-04 7 October 26th, 2008 01:10 PM
heads and cams with supercharger?? SilverStang03 99-04 3 October 18th, 2008 02:51 PM
supercharger or full bolt ons,heads,cams sonicblue 99-04 8 August 25th, 2006 08:28 PM
