Rear Axle Help Im Going Crazy!!
Old June 18th, 2010, 11:00 PM   #1
yansito is on a distinguished road
Not so long ago I slid into a curb and bent my passenger side rear axle, so i decided to change it today, so i took everything apart and now after this i was trying to put the new axle back in but it will not go in no matter what i do, the old one came out as it should i pushed it removed the C clip and pulled it out slowly and now when i try putting either one back in it goes in maybe and 1 inch away from where its suppose to stop but it doesn't go any farther... now i changed the bearings do u guys think it could be that the new bearings aren't letting me go any further or what do u guys think????
Old June 18th, 2010, 11:19 PM   #2
Moderator
casper gt's Avatar
2012 300a gt auto
12.10@116
casper gt has a brilliant futurecasper gt has a brilliant futurecasper gt has a brilliant futurecasper gt has a brilliant futurecasper gt has a brilliant futurecasper gt has a brilliant futurecasper gt has a brilliant futurecasper gt has a brilliant futurecasper gt has a brilliant futurecasper gt has a brilliant futurecasper gt has a brilliant future
if it really is an inch too long (thats a bunch in this situation) I'd say you have the wrong axle for your car.
MM BRACKET RACING CREW CO-FOUNDER
BAMA Performance Drag Team Founder
2012 300a GT auto
Old June 18th, 2010, 11:50 PM   #3
no i measure it is the same size as the old one the thing is that when i push it in it doesnt go in deep enough for me to put the C clip on it. it goes in fine and then about an inch away from where i would have to put the C clip on it, it stops and wont go no further.
Old June 18th, 2010, 11:54 PM   #4
Shaun03GT's Avatar
2003 Mustang GT
Shaun03GT has a brilliant futureShaun03GT has a brilliant futureShaun03GT has a brilliant futureShaun03GT has a brilliant futureShaun03GT has a brilliant futureShaun03GT has a brilliant futureShaun03GT has a brilliant futureShaun03GT has a brilliant futureShaun03GT has a brilliant futureShaun03GT has a brilliant futureShaun03GT has a brilliant future
iTrader: 12 reviews
Just do a 31 spline rear
Vortech V1 Intercooled @ 11psi
394rwhp/392rwtq @ 9.5psi
415rwhp/400rwtq @ 11psi on Methanol
Tuned By: Pete @ Performance Dyno
Affordable Supercharger Build Guide
Supercharger Info for Noobs
Old June 19th, 2010, 12:03 AM   #5
Moderator
casper gt's Avatar
2012 300a gt auto
12.10@116
if your SHURE the new & old axles are identical, try removing the abs sensor & see if that helps.
2012 300a GT auto
Old June 19th, 2010, 12:23 AM   #6
ajm
I agree with casper. First thing i thought is maybe its a used axle out of a random 8.8 and the axle length is different.
Old June 19th, 2010, 12:32 AM   #7
!FACEPLATED!
F8L GT's Avatar
7.84 @ 86.01
iTrader: 13 reviews
i agree with casper and AJM, but if you didnt remove the sensors before pulling the old ones, then how did you get them out??
Old June 19th, 2010, 12:53 AM   #8
Moderator
casper gt's Avatar
2012 300a gt auto
12.10@116
true on the sensors, I was thinking mabie he got lucky & somehow got the old one out without removing them
2012 300a GT auto
Old June 19th, 2010, 01:04 AM   #9
competition orange's Avatar
2004 mustang gt
competition orange is on a distinguished road
i'm sure you tried it but did you try turnin axles alittle bit to slide it in cause if your an inch away i would say abs sensor in way or the splines ain't lining up.
395hp/436tq tuned by lasota racing at rodeheavers on a mustang brand dyno.
Old June 19th, 2010, 02:27 AM   #10
The Big Spoon
jessemachone's Avatar
88 5.0 5 Speed Notch <><
never fast enough
jessemachone is a glorious beacon of lightjessemachone is a glorious beacon of lightjessemachone is a glorious beacon of lightjessemachone is a glorious beacon of lightjessemachone is a glorious beacon of light
Did you do the wheel bearings too? If so, maybe you don't have them driven all the way in.
Old June 19th, 2010, 03:11 AM   #11
1999 Mustang GT
hardhitter has a spectacular aura abouthardhitter has a spectacular aura abouthardhitter has a spectacular aura about
Send a message via AIM to hardhitter
lol that's the last thing he said he did
Vortech V2 Si
Old June 19th, 2010, 03:21 AM   #12
1999 Mustang GT
Warriorofice is on a distinguished road
are they made in china ?
Old June 19th, 2010, 07:47 AM   #13
Well i ordered the axle from autozone it came with the abs sensor on it already and it doesnt seem as if the sensor is in the way cuz not even the old one that came out really easy is going back in, how would i know if the bearings are all the way in?? is there a certain depth to it or something????
Old June 19th, 2010, 08:28 AM   #14
The Big Spoon
never fast enough
Doesn't say he made sure he drove them all the way home though.... I imagine that if he is smart enough to remove them, he is smart enough to know how to install them and make sure they bottom out..... If he only installed them flush, it would keep him from installing the c clips.
thanks for pointing this little tid bit out.... i have a habit of not reading to the end of the post.
Old June 19th, 2010, 08:32 AM   #15
The Big Spoon
never fast enough
you have to drive them in until they bottom out. You have to drive them a little past the edge of the housing. You can probably use your old one to get this done. I use the flat side of a big socket. Put a piece of woor between the socket and your hammer when hitting it or put an extension on the inside of the socket and hit the extension - causing the socket to drive in the bearing.
Old June 19th, 2010, 08:41 AM   #16
1999 GT 35th LE
99GT35thLE has a spectacular aura about99GT35thLE has a spectacular aura about
Go to Autozone and get the loaner bearing and seal installation kit.
Use the bearing installer tool and drive the bearing in until it seats. Then install a new oil seal. The oil seal should be flush with the end of the housing.
You also need to remove the ABS sensor from the brake bracket.
Drive it like you stole it
Old June 19th, 2010, 07:59 PM   #17
The Big Spoon
never fast enough
yeah, what he said...... I was posting while tired
Old June 19th, 2010, 08:17 PM   #18
neverfastenough1's Avatar
I am sure you looked everywhere on the outside for anything making contact, so I am going with the splines aren't lining up. Mine didn't slide right in either. I just played with them til they did.
Old June 25th, 2010, 05:15 PM   #19
Alright here is the update, the POS bearings that came with the axle didn't let the whole axle slide in, i noticed because i saw scratches on the axle so i went to auto zone and got a timken bearing and seal and everything went well from there on. Thanks for all the responses and help.
Old June 25th, 2010, 06:12 PM   #20
2004 mustang gt
your welcome!
Threads Similar to: Rear Axle Help Im Going Crazy!!
99-04 Rear axle in my 97? sharkbait 99-04 4 April 26th, 2010 11:22 PM
Rear Axle BlK2002GT 99-04 8 February 13th, 2008 06:16 PM
Rear axle help VIXEN_GT 99-04 2 July 27th, 2007 07:40 PM
8.8 rear axle 5litercobra 5.0 Mustangs 6 May 31st, 2007 10:28 PM
Rear Rotors and Rear Axle rondaw3g0410 99-04 1 September 6th, 2006 10:00 PM
