Engine wont stay running and knocking on driver side???
Today while driving my car on the highway around 60 mph the engine cut out on me and died... no check engine light and car was not overheating....strange.... After the car died I pushed the car to the side of the road and opened the hood and there was smoke coming out my intake filter. I then checked the gauges again and coolant and no check engine light. The engine would crank but would not start.... I had my diablo in the trunk so I ran the diagnostics and No trouble codes. After about 30 mins of sitting on the side of the road waiting for the tow truck I tried starting the car again and the car barely started and then died. After cranking on it a few more times and giving the car gas it started again and died. I tried again and gave the car some gas and the knocking began so I let off the gas and it stalled out and died again... I got the car towed to my house and pulled the driver side valve cover to see if i could find the prob.....but I cannot find the exact locating of the knocking noise.... I tried cranking the car over again with the valve cover off and it appears that the knocking dosent occur until the engine starts to fire......but the sound is def. coming from the driver side head!!! Has anyone had this prob. before? Does anyone have any suggestions??? Ive also put that 108 octane booster crap in the gas tank on the previous 3 fill ups ( not this tank) even though i didnt have a prob with this when i did it... Im prob. gonna get it towed to JPC this week if I cant figure it out..
My car only has bolt ons: Diablo tune, K&N intake, performance products throttle body,throttle body spacer, plenum, and intake manifold, underdrive pulleys, 3.73 gears, aluminum driveshaft, flowmaster cat back, steeda tri-Ax, and I run 93 gas (mileage 76,000)Engine wont stay running and knocking on driver side??? |
I will post video in the morning
damn that sux , lets hope it somthing easy to repair
Just a thought, but in my experience, by your description it sounds almost like a valve is stuck closed? If you could have somone crank the engine while inspecting the valvesprings for movement, then do the same with the spark plugs remove. Might be a stretch but you gotta start somewhere
Nitrous is like a hot girl with an STD... you wanna hit it, but your afraid of the consequences 02' GT ~ Twin Screwed 469hp/493tq |
Thanks FoxHoss for the recommendation. Today I inspected the valve springs the best i could and they seem to all be working properly. I cranked the engine with all coils unpluged and everything appeared to be working fine. Then I connected the coils and took a short video of the car attempting to stay running. I didn't want to start it again but i thought this might help if i post it. (The car will not start or continue to run unless i give it a good amount of gas and hold it).
Is it possible that timing slipped on just this head?? Timing chain and tensioners apear to be fine as well.. Any more suggestions before I take it to the shop??? Thanks, Ryan
Update ran compression test on engine. No compression on passenger side of engine. Pulled valve cover on pass side and all rockers are broken off and laying inside of head. Im now breaking down enigne so i can remove heads.
'01 Gt Vert auto
13.2@103.8 n/a Stock stall
goodluck on it
![]() 253rwhp 294rwtq motor 337rwhp 427rwtq 90 shot |
yikes! well good job on finding the failure. now just to find what caused it, and what to do about fixing it. hopefully with some upgrades, if the budget will allow it that is.
On a side note, which i know you dont want to hear. but if there is no compression and the rockers are broken off, cross your fingers that the valves didnt drop :/
It appears that my timing chain tensioner failed and caused this mess im in..The tensioner broke into 3 pieces.....I pulled the passenger head off and all the valves have marks on them... The pistons appear to be fine, there are only a few small scratches on the top and all cylinders are holding coolant still.
I really dont have the money to spend but it looks like im getting a credit card now and while Im this far I guess ill just pull both heads and drop them off at a machine shop and upgrade the cams and get the heads redone.. Any suggestions on what type of cams I should get?? This is my daily driver so I dont want to overdo it and kill my gas mileage. Next year I plan to supercharge the car as well. Thanks |
bummer.. i hope this never happens to me.. and if it does.. oh well it'l give me the reason to buy aftermarket parts and send the heads to get ported&polished...
Da General -S&B c.a.i, TB spacer, 75mm TB, OBX aluminum pulleys, DiabloSport Programmer, 3.73s, 75/100 shot of NOS!!! ![]() ![]() Texas Stangs Crew! Punishment Racing!!! Get It Down Crew!!! |
#12 | |
2003 Redfire Mustang GT
before new mods - 13.60@101.40
dude what the fuck happened?! how the hell does all your rockers break off!? n how the fuck did your tensioner break>!?
2005 trd tacoma sport
someones been beating the ever living hell out of their car
Wish I had a cool story to tell you guys but this car hasn't even been to the track since I owned it. However, I did run it hard a few times 2 weeks ago at the ocean city car show. It just died on me while crusing at 60 mph in 5th gear on the highway.
Pics of broken and bent Rockers and broken tensioner: Broke Ass Car pictures by Mustang200285 - Photobucket Any recommendations on cams?? Do you think i should just get the heads rebuilt ported and polished? |
1999 Mustang GT
Check these guys out Modularheadshop - MHS Nick can set you up with some nice heads and cams for a great price.
Quick 99 Thanks for the info. I may go with the Stage 2 PI heads and cams combo package from the Modularheadshop - MHS you recommended. Does anyone have this setup on their motor? And what kind of gains should I expect?
damn , im suprised that it would even start and run with all that shit busted
Hey Guys I now have the engine pulled waiting for some heads. Also nitced my motor mounts were broke and Checked my clutch and found thats its on its last leg. Anyone have any recommendations on a performance clutch??? I was looking around on these forms and seems that centerforce is higly recommended! What do you think about the centerforce DF800075? Centerforce DF800075 - Centerforce Dual Friction Clutches - Overview - SummitRacing.com Also can I use my stock flywheel with this clutch or any other performance clutch? I hope I can, my budget is getting really tight...
Threads Similar to: Engine wont stay running and knocking on driver side???
| Got Her Running, But wont stay running...help? | Speedstang302 | 5.0 Mustangs | 10 | August 28th, 2011 05:58 PM |
| so i instaled my stereo and now my car wont stay running | Dennis | Audio/Video | 21 | May 17th, 2008 07:55 PM |
| car wont Stay running | 01dutchGT | Classic Mustangs | 8 | April 23rd, 2008 02:42 PM |
| Car wont stay running | Spiderz | Classic Mustangs | 10 | March 8th, 2008 08:14 AM |
| Stang wont stay running, after warm up...???? | ttop5.0 | 5.0 Mustangs | 2 | November 28th, 2006 04:10 PM |
