Theft Light Flashing After Pulling The Motor And Car Wont Start. Help - Forums at Modded Mustangs
post #1 of 4 Old June 21st, 2010, 11:37 PM Thread Starter
Hey guys, just put the motor back in, and now when i go to start it it cranks and will never fire up. The theft light is blinking rapidly on the dash, could this have anything to do with it? if so what can i do to fix it? Also, some o2 sensors are not connected in the exhaust pipes yet, as i dont want to continue till i can make sure the car will at least run. We pulled the motor and upon putting it in ran into this problem. Anyone know any way to reset the PATS system, or how to disable it? or is the theft light supposed to be blinking? havent had the car running for over a month so i forget if that happened when i usually started it up. But, i dont think it did. ANY help is appreciated!
tkrizzy3 is offline
post #2 of 4 Old June 21st, 2010, 11:48 PM
You tripped the PATS system, that's why the theft light is blinking. Did you swap out the ECU or gauge cluster with the engine? They must be matched together.
I had a shop install an aftermarket alarm and remote start into my old GT, and somehow they triggered the PATS while installing the remote start, and the only way to get the car to start was to take it to the dealer and have the PATS reprogrammed. I could have gotten it tuned and disabled PATS in the tune and started it, but they screwed it up, so they paid to get it fixed at the dealer.
Bullitt5339 is offline
post #3 of 4 Old June 21st, 2010, 11:53 PM Thread Starter
well i did not swap out ecu or gauges put i figured thats what happened with the pats system. Only way to fix it is go to a dealer? is it possible to have a locksmith do it?
tkrizzy3 is offline
post #4 of 4 Old June 22nd, 2010, 12:17 AM
0949er's Avatar
dealer or a hand held tuner
MODS:
Vortech V1 T-Trim @ 7.5 PSI (tuned down)
Comp Cams XE270-AH
+ See Garage
432 rwhp / 396 rwtq 02/27/2011
NEW VIDEOS!
**It takes ~$60 a rwhp (over stock) for a 99-04 Mustang GT.** Do the Math
PLANS ON HOLD
0949er is offline
Human Verification
