#21 |
2003 Mustang GT
14.03@100
Ya I'm looking at either CHE adj. uppers, or Baseline Prolaunch #1's anyway.
#22 |
2003 gt
5.4 32v on the way
If you get the lakewood lowers, do not get the baseline uppers. Both are designed to bring your ic back some, however combined you end up bringing it back too much.
#23 |
2003 Mustang GT
14.03@100
^How is this so? Just asking cuz idk how that works.
#24 |
2003 mustang v6 ;)
slow
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() iTrader: 2 reviews
the only way to get your pinion angle right is to be able to ajust your suspention and measure. i used a magnetic degree wheel. measured what degree my drive shaft was at then my pinion. if it is the wrong degree to will get axle binde and you will destroy your pinion seal.
#25 | |
2003 Mustang GT
14.03@100
#26 |
2003 gt
5.4 32v on the way
your ic is the point where the lines from your control arms cross. Lakewood lowers makes the lower control arm line come up at a sharper angle bringing the ic back, and baseline uppers pretty much do the same thing but for the upper control arms. If your ic is in stock location, or two far forward your car will squat too much. Bringing back the ic is like moving a leverage point so that your car pushes down harder on the axle when weight transfers. There is a point where bringing it back too far will work against you. I have adjustable control arms that I had setup in a way that worked similar to the lakewood lowers, and bought the baseline uppers thinking it would help. I had all sorts of traction problems until I adjusted the lowers to move the ic forward more. Also, if you do get the baseline uppers, don't get the one with bushings. The rear of my car feels so much better now than it did with bushings. Only downside is I can hear alittle extra noise, however I lack a back seat and am sure if I had one I wouldn't really hear anything extra.
#27 | |
2003 Mustang GT
14.03@100
That makes total sense now. I'm still up in the air about uppers anyway right now, plus I'm more worried about getting lower torque box reinforcements so I can install my BMR LCA's (don't wanna have to pull the LCA's again to do the TB's)
#28 |
2003 gt
5.4 32v on the way
Most of the time the problem is in the uppers, I haven't read too much where someone fucks up the lower control arm mount. If you are thinking about doing control arms for drag in the future, you should get a set of adjustable lowers or a set like the lakewoods.
#29 |
2003 Mustang GT
14.03@100
Well depending on which UCA's I get will determine which way I go w/ the LCA's down the road (either keeping the BMR's or getting adj./Lakewood LCA's).
#30 |
2003 gt
5.4 32v on the way
Remember they recommend something like adjustable lowers for the baseline uppers.
#31 |
2003 Mustang GT
14.03@100
I'm already lowered though, half coil cut on stockers, and I also have separate lowering springs that will put me 1.5 inches lower. The way I see what they are saying is see what they will do at stock height, then lower if need be.
#32 |
2003 gt
5.4 32v on the way
oh yeah, lowering your car works against you for drag. With stock or stock like suspension, a lowered car has an ic that is moved forward.
Threads Similar to: Would these make a HUGE difference???
| Will a new HU make much difference in SQ? | MisterBilbo | Audio/Video | 7 | December 3rd, 2009 11:12 PM |
| does it really make a difference as to what brand o/r x i get | 02mustanggt | 99-04 | 8 | August 16th, 2009 01:17 AM |
| Do skinnies really make a difference? | SDYC00GT | 99-04 | 23 | March 24th, 2009 10:45 PM |
| make a difference | WilltheThrill | The Clubhouse | 6 | October 23rd, 2007 06:30 PM |
| will it make a difference? | youngstang09 | 99-04 | 5 | February 1st, 2007 12:10 AM |
