porting stock intake manifold
i wasnt too sure if this is a repost or even possible but just wondering if anyone had any views on if porting the intake was possible and if there are any gains in hp from doing it.
has anyone done this? or see any tech articles about doing this??
MM's nicest mod, :)
you can't port plastic there homie, now if you are talking about the plenum then yes you can port them, don't know if its really worth the effort cause it won't gain you that much.
06 Dodge MegaCab Diesel 455rwhp/815rwtq REAL TRUCKS DON'T USE SPARK PLUGS |
ya i know you can port the plenum and the TB for like a awesome 2hp. but i wasnt sure if that plastic one could be or not. i figured maybe if it was thicker then maybe but i guess not.
RLY SRS
Thats the kicker with these cars...The damn plastic intake...
and a good one will cost you.
#6 | |
it was like be kicked in the nuts...
What about porting my stock manifol? Do you think that would be good for me to do?
The main problem with the stock intake is not the size of the runners, but the length and shape of them. Factory manifolds are designed for good drivability and emissions at all rpms. So even if you could port it you wouldn't notice much. I recently picked up a used typhoon on ebay for $400 and spent 2 hours porting and polishing it. Should make some nice HP for not a lot of money.
-Jon |
#9 | |
http://www.musclemustangfastfords.co...bullittintake/ Bullitt Blast Performance enthusiasts know one way to increase power is to improve the airflow to the engine. If you own a 4.6 2V, it means installing an '01 Bullitt intake manifold. Unlike the plastic intakes found on all '96-present GT models, the '01 Bullitt manifold is cast aluminum which gives it some advantages--first, because it can be ported, and second, because if you run nitrous, there is a much smaller chance of blowing the thing into a million pieces should your engine encounter a dreaded nitrous backfire. Another attribute is the shorter, yet larger, runners. If there is a downside, it is the weight. The Bullitt intake weighs about 35 pounds, which is about twice the weight of the plastic one.
I've heard mixed reports, everyone wants to try out all these new intakes, but how much hp can they actually put out?
MM's Mad Scientist
Slow Fella
![]() ![]() ![]() ![]() ![]() ![]() iTrader: 2 reviews
Hell, I port matched my stock (plastic PI) intake with some router bits made for wood just to even up the entry into the ported heads. I don't know if it really mad a difference, but it inly took about 30 minutes. Just be careful not to get in there to deep. That plastic comes off fast.
Threads Similar to: porting stock intake manifold
| Swapping a 98 V6 intake manifold with for a 99 V6 manifold | 98mustang | V6 Mustangs | 6 | November 21st, 2010 12:20 AM |
| Taking off Stock intake manifold | 95blueGT | 94-95 | 9 | June 18th, 2007 10:50 AM |
| Stock head and Intake Porting | GizmosMustang | 5.0 Mustangs | 21 | May 3rd, 2007 11:29 PM |
| intake,lower and upeer porting | SPF0percent | V6 Mustangs | 7 | April 12th, 2007 05:11 PM |
| v6 splitport intake manifold porting/polish | 99mustang232 | V6 Mustangs | 1 | November 28th, 2005 10:25 AM |
