normal bolt ons
Old June 24th, 2010, 01:24 AM   #1
kjdionmemphis's Avatar
2001 Mustang GT
9.08 1/8
kjdionmemphis is on a distinguished road
Exclamation
normal bolt ons
I have a
2001 GT
2 1/2 Off Road X-Pipe
2 1/2 mid pipes
2 1/2 Dynomax Race Bullet Mufflers w/ turndowns
diablo predator
4.10 rear gears
underdrive pullys
CAI
the only down fall is its an auto
How you guys think it will run.
Old June 24th, 2010, 01:43 AM   #2
stal94gt's Avatar
2003 mustang v6 ;)
slow
stal94gt has much to be proud ofstal94gt has much to be proud ofstal94gt has much to be proud ofstal94gt has much to be proud ofstal94gt has much to be proud ofstal94gt has much to be proud ofstal94gt has much to be proud ofstal94gt has much to be proud ofstal94gt has much to be proud of
it depends your some of your mods may not be helping you to much as a stock motor. you loose alot of low end torqe with your exhaust but your gears deff help alot and will help get your car into the rpm's it needs to go fast. and tires matter
Old June 24th, 2010, 01:44 AM   #3
tommy93's Avatar
2001 Mustang
tommy93 has a spectacular aura abouttommy93 has a spectacular aura about
Originally Posted by kjdionmemphis View Post
I have a
2001 GT
2 1/2 mid pipes
diablo predator
4.10 rear gears
underdrive pullys
CAI
why dont you just take it for a spin, and then tell us?? lol is it in s shop right now or something?
All Bark, No Bite
Old June 24th, 2010, 01:48 AM   #4
2001 Mustang GT
9.08 1/8
running street tires rate now looking to put some 15s on it so i can get more side walls with slicks
also been thinking about putting a converter in it also to get the rpms up in the power
anyone the has a good ideas for what i should do next i will be more then happy for info this is my first build that is with an inj car
Old June 24th, 2010, 01:49 AM   #5
2001 Mustang GT
9.08 1/8
ya getting gear put in
Old June 24th, 2010, 02:22 AM   #6
2001 Mustang GT
9.08 1/8
also looking at getting a 75mm tb and elbow for intake
Old June 24th, 2010, 02:47 AM   #7
Hooo Ha Ha
sharkbait's Avatar
1997 Mustang GT
11.65 @ 115
sharkbait has much to be proud ofsharkbait has much to be proud ofsharkbait has much to be proud ofsharkbait has much to be proud ofsharkbait has much to be proud ofsharkbait has much to be proud ofsharkbait has much to be proud ofsharkbait has much to be proud of
iTrader: 10 reviews
get the 78mm throttle body and plenium combo. its cheap and efficient.
With drag radials maybe 13.8s
street tires probobly a 14.0
410rwhp 520rwtq @ 12.9 psi
Old June 24th, 2010, 02:53 AM   #8
2001 Mustang GT
9.08 1/8
i didnt know that oone was made that size biggest i see normal are 75mm thanks for the help
Old June 24th, 2010, 03:26 AM   #9
Hooo Ha Ha
sharkbait's Avatar
1997 Mustang GT
11.65 @ 115
iTrader: 10 reviews
BBK 78mm Mustang Throttle Intake (96-04 GT) at AmericanMuscle.com - Free Shipping!
heres the part.
I had on for a while when i was N/A and then for when i was boosted.
Loved it.
Old June 24th, 2010, 06:00 AM   #10
2011GT1979's Avatar
2011 GT/CS
12.11@113
2011GT1979 will become famous soon enough2011GT1979 will become famous soon enough
A aftermarket stall like a Yank or Circle D in the 3500+ range would probably take .3 - .6 off your ET on a good set of tires by itself.
Also, to really wake these motors up you need a set of headers and some cams with the above mentioned throttle body. I know a cam is not a bolt on but they sure are nice for N/A power. Or you could go with the greatest bolt on ever, a turbo or S/C kit.
2011 Mustang GT/CS 3.31's, Steeda Tri-AX, LCA's, Steeda Axle Back, Steeda CAI, Brenspeed Tune.
2008 Grey Mustang V6
2008 F-350 FX4 Supercab Long Bed (Race Car Hauler BABY!)
My 2011 GT/CS 12.3 @ 110 Pass in HD
Old June 24th, 2010, 06:03 AM   #11
Black Bullitt's Avatar
2001 Mustang Bullitt
Faster than Twinmill
Black Bullitt is just really niceBlack Bullitt is just really niceBlack Bullitt is just really niceBlack Bullitt is just really nice
Send a message via AIM to Black Bullitt
That's overkill for N/A. 70mm TB is plenty. If you plan on going FI later than yeah, go with the 78mm TB. If not, don't bother.
2001 Bullitt #5069
505rwhp/538rwtq @ 15#s
Originally Posted by FluffyTheRhino View Post
Nothing says "Upgrade EVERYTHING" like busted parts
Old June 24th, 2010, 07:35 AM   #12
red01's Avatar
red01 is on a distinguished road
My friends 04 auto with similiar bolt ons, minus the pulleys just put down 231/279. He runs 14.0-13.9 on street tires and stock gears, you should do a little better.
1997 Mustang GT
04 PI 2V, bolt ons, gears, tune
255/292
www.covertmotorsports.net
Old June 24th, 2010, 09:35 AM   #13
thork's Avatar
1999 Mustang GT
14.18@99.32
thork is on a distinguished road
Send a message via AIM to thork
I have similar mods to you, but I have a TB and a plenum
On new 275/40/17 street tires I ran a 14.52 at the track.
Keep in mind, though, I wasn't "launching", just kinda stomping on the gas when the lights came down (I need a driver mod!).
I also had traction control on and overdrive on.
I'm going back to track tomorrow, looking for 13.9's
Depending on how you drive, I'd say it'll be anywhere from high 13s to 14.5
GOod luck!
Old June 24th, 2010, 01:09 PM   #14
blownstang's Avatar
blownstang has a spectacular aura aboutblownstang has a spectacular aura aboutblownstang has a spectacular aura about
13.8 the way it sits.
2003 DSG Mustang GT 5spd
Full Bolt On's, Suspension, Built Rear, V1 S
N/A: 266/300, 3,550lbs, 13.44 @ 100.5 1.77 60'
Non-intercooled: 356/371, 3,575lbs, 12.81 @ 110.47 1.86 60'
Intercooled: 362/370
Old June 24th, 2010, 01:57 PM   #15
BaznastyDave's Avatar
2004 Mustang
BaznastyDave is a name known to allBaznastyDave is a name known to allBaznastyDave is a name known to allBaznastyDave is a name known to allBaznastyDave is a name known to allBaznastyDave is a name known to all
Keep it from pulling the front wheels off the ground and don't break loose sideways half track and you should run about a 13.9 - 14.2
305/333 WHP/WTQ with CMS Stage II cams
440/552 WHP/WTQ on Spray
7.86 @ 89.1mph, 1.61 60 foot N/A
7.20 @ 98.8MPH 1.55 60 foot on spray
Stock Longblock with Cams
Old June 24th, 2010, 02:05 PM   #16
I8ACMRO's Avatar
2003 Mustang GT
14.03@100
I8ACMRO has a spectacular aura aboutI8ACMRO has a spectacular aura aboutI8ACMRO has a spectacular aura about
You should be seeing 13.8-14.0 I ran 14.03 w/ what I have, and that was launching at 2500 rpms and pedaling w/ a bit of spin on the line.
http://www.moddedmustangs.com/forums...-member-30498/
Originally Posted by RZNCAIN View Post
Drive the shit out of it and replace shit when it breaks. No point in having these things if we are going to drive them like a bunch of pussies!
Old June 26th, 2010, 04:52 AM   #17
2001 Mustang GT
9.08 1/8
lol
Old June 26th, 2010, 04:54 AM   #18
2001 Mustang GT
9.08 1/8
thanks for all the input
Old June 26th, 2010, 04:55 AM   #19
2001 Mustang GT
9.08 1/8
ya the plan is to go with a twin turbo set up if i car ever talk myself in to spending the money
Old June 26th, 2010, 04:55 AM   #20
!FACEPLATED!
F8L GT's Avatar
7.84 @ 86.01
iTrader: 13 reviews
he wont have a problem doing that
Threads Similar to: normal bolt ons
more than bolt ons? look here! SWEET2KSTANG 99-04 27 December 15th, 2010 11:47 AM
Bolt-Ons aasbury312 2005 - 2010 10 March 3rd, 2009 09:12 PM
Looking for bolt-ons XSV 27 V6 Mustangs 18 December 6th, 2007 01:31 AM
bolt ons countrystang0881 2005 - 2010 14 September 26th, 2007 11:49 PM
bolt ons nHuman 96-98 3 February 8th, 2007 10:51 PM
