Alright, havent asked for much tech help. but cars acting up.
Old June 24th, 2010, 03:29 PM   #1
I Blumpkin Entirely Way Too Much
Dolbs4082's Avatar
2005 Mustang GT
Dolbs4082 is just really niceDolbs4082 is just really niceDolbs4082 is just really niceDolbs4082 is just really nice
Last weekend my car started making some weird noises while i was driving home from my folks. its only when im at low rpm taking off from a stop whether its first or nuetral. its kind of a grinding whinning noise. but it doesnt happen in 2nd or 3rd or nething.
My first thought was tranny fluid. so i emptied all the tranny fluid today on my lunch. looked good and clean (pretty metalic tho, is that normal?) Also it was a little too full? it had about 4 qaurts... when i think stock is 3.17 quarts? correct me if im wrong?
so my next thought is the rear end. when i get home from work tonight im going to pull the rear cover off of it and see if theres any fluid left (i noticed when i pulled it out of the garage today that theres a small puddle under the rear end.
now when re-installing the cover, the local stealership told me to just use rtv, is this the best thing to use. and then i beleive i read that i need to use 3 quarts if it has the friction modifier, or 2 quarts plus 4 oz of modifier.
i havent worked on the rear end of my car much, messed with several other cars, on most there is a plug on the rear plate you unscrew to fill up. i noticed ours dont have it. im assuming there is a plug on the top of the actual housing then? is it the 3/8 drive style just like the tranny plug?
MM + Cleavage member #22
Old June 24th, 2010, 03:33 PM   #2
1999 Mustang GT
hardhitter has a spectacular aura abouthardhitter has a spectacular aura abouthardhitter has a spectacular aura about
Send a message via AIM to hardhitter
The fill plug is on the driver's side of the car on the drive shaft side of the rear end near the top
Vortech V2 Si
Old June 24th, 2010, 03:43 PM   #3
Dolbs4082's Avatar
2005 Mustang GT
Awsome. thats exactly where i was figuring. is it just the 3/8" plug like the tranny?
Old June 24th, 2010, 03:46 PM   #4
Tech Exchange Head Honcho
2003 SVT Cobra
11.70 @ 121
weems has much to be proud ofweems has much to be proud ofweems has much to be proud ofweems has much to be proud ofweems has much to be proud ofweems has much to be proud ofweems has much to be proud ofweems has much to be proud ofweems has much to be proud of
Yep.
Old June 24th, 2010, 03:57 PM   #5
Dolbs4082's Avatar
2005 Mustang GT
Awsome.
My other question would be... i know alot of people have just pulled their shifter off to fill the tranny with fluid. last time i tried that i couldnt get the shifter off, the guy before me must have siliconed it on with some sticky stuff.
So i was wondering, i noticed that if i took the shift boot and all that off, i could then use a peice of clear tubing and snake it down to the top filler hole on the top of the tranny. and then use a funnel from up top. any reason to not do this?
Old June 24th, 2010, 04:16 PM   #6
2003 SVT Cobra
11.70 @ 121
Originally Posted by Dolbs4082 View Post
Awsome.
Nah you could do that. I had the same issue with my shifter, I had to pry it off. But I have always found the easiest way for me to change it is just using one of those cheap pumps.
Old June 24th, 2010, 05:01 PM   #7
UnixHH's Avatar
2003 Saleen S281
UnixHH is a glorious beacon of lightUnixHH is a glorious beacon of lightUnixHH is a glorious beacon of lightUnixHH is a glorious beacon of lightUnixHH is a glorious beacon of light
Send a message via Yahoo to UnixHH
kinda sounds like the pilot bearing to me.. i could be wrong though
480RWHP 450RWTQ 15psi @ 15* on 91 octane
Old June 24th, 2010, 05:03 PM   #8
Dolbs4082's Avatar
2005 Mustang GT
I kinda was wondering about the pilot bearing. i know my throw out bearing is bad. Even tho i just replaced it 1000 miles ago with an oem from ford. and havent raced much with it.
Im wondering if my shift fork is eating my throw out bearings. because i've noticed that my car goes threw throw out bearings like none other.
Old June 24th, 2010, 06:03 PM   #9
00 GT Convertible
13.79 Crap for track prep.
tripleblkmartini is on a distinguished road
iTrader: 6 reviews
Send a message via Skype™ to tripleblkmartini
+1
I had the same problem. Found out my fork was bent and the pilot bearing was shot.
Mods in garage. www.thisshitaintfree.com Always remember those who have fallen before you.
Threads Similar to: Alright, havent asked for much tech help. but cars acting up.
Cars acting up need help 2k3stanggt 99-04 32 March 9th, 2010 09:29 PM
Havent been around much lately... Dolbs4082 The Clubhouse 28 October 30th, 2009 04:24 PM
dry or wet 150 shot? sorry its being asked again but i havent been on in a while Iwannagofast 5.0 Mustangs 28 October 14th, 2008 02:00 PM
Well i havent posted all day Drick The Clubhouse 29 March 18th, 2008 08:04 PM
i havent raced em so i dont know but v8_Funk V6 Mustangs 27 August 2nd, 2007 10:16 PM
