Turboing mustang
Old June 24th, 2010, 04:15 PM   #1
2004 STI
BIGSXY is on a distinguished road
Turboing mustang
well im new to mustangs and will be purchasing a 99-04 stang. I am horrible with forums and finding stuff. Having said this i am under the beleif that i can run just shy of 500rwhp and be fine. That is my first question is that ok. Second i wanna do cams as well while i have the car apart. for mustangs what would be best to run with a turbo system. And second is Pony Down turbo kits any good they are reasonably priced and seem good.
Im not knew to modifying cars i have 93 240sx that is built and an sti i drive everyday with light modification. Ive had a couple talons as well.
thanks for helpin out if you can
Old June 24th, 2010, 04:19 PM   #2
Tech Exchange Head Honcho
2003 SVT Cobra
11.70 @ 121
weems has much to be proud ofweems has much to be proud ofweems has much to be proud ofweems has much to be proud ofweems has much to be proud ofweems has much to be proud ofweems has much to be proud ofweems has much to be proud ofweems has much to be proud of
I would stay at or under 450 rwhp. Some people clear that but that's where most issues come up with the factory internals.
Check out the on3performance turbo kits too, from what I have seen most people have been fairly happy with them and they are pretty cheap.
Old June 24th, 2010, 04:34 PM   #3
I Poop Entirely Way Too Much
Blown 03 GT
03_StangGuy is just really nice03_StangGuy is just really nice03_StangGuy is just really nice03_StangGuy is just really nice
450 rwhp is the same limit most of the time. When you install a turbo you dont have to take anythin apart.
Old June 24th, 2010, 04:39 PM   #4
blownstang's Avatar
blownstang has a spectacular aura aboutblownstang has a spectacular aura aboutblownstang has a spectacular aura about
You don't need cams. The turbo will be plenty to max out your stock shortblock. Pony Down and On3 are two of the cheaper quality turbo kits, therefore they don't cost as much as a quality system. You will need to modify/fabricate them to make them fit properly. They are not a simple bolt up and will require modification. For a quality kit look to Hellion. Two local guys have the On3 kit and it was definitely no walk in the park for the two shops that did the install.
2003 DSG Mustang GT 5spd
Full Bolt On's, Suspension, Built Rear, V1 S
N/A: 266/300, 3,550lbs, 13.44 @ 100.5 1.77 60'
Non-intercooled: 356/371, 3,575lbs, 12.81 @ 110.47 1.86 60'
Intercooled: 362/370
Old June 25th, 2010, 12:30 PM   #5
2004 STI
its not that hard to do cams so i figured i would while i was working on it i have no problem modifying the kits to make them work i will be doing internals in about 6-8 months so im not to worried but how does the drivetrain hold up
Old June 25th, 2010, 12:32 PM   #6
moosenuk17's Avatar
2000 ford mustang GT
moosenuk17 is a jewel in the roughmoosenuk17 is a jewel in the roughmoosenuk17 is a jewel in the rough
Send a message via AIM to moosenuk17 Send a message via MSN to moosenuk17 Send a message via Yahoo to moosenuk17
like eveyone else said...the internals might give you problems, but for me being at 450 or so it was my DS and tranny...if i was you i would get a different tranny and stronger driveline, 31 spline axels....
2000 kenne bell GT (440HP-432TQ)
Tuned by Joe at http://www.tricktuners.com
dyno vid:http://youtu.be/lr3xpxw2_v8
2011 escape
MUSTANG TAT CREW
Old June 25th, 2010, 12:51 PM   #7
Black Bullitt's Avatar
2001 Mustang Bullitt
Faster than Twinmill
Black Bullitt is just really niceBlack Bullitt is just really niceBlack Bullitt is just really niceBlack Bullitt is just really nice
Send a message via AIM to Black Bullitt
I would agree the Hellion kit is a much better quality kit and comes with everything you need. On3 Performance kit is a good budget build kit, but it doesn't come with the front suspension you need to make the turbo fit, so you have to buy that separate. I would not recommend cams if you are going to run a turbo kit on a stock engine. You will definitely push the integrity of the stock internals.
2001 Bullitt #5069
505rwhp/538rwtq @ 15#s
Originally Posted by FluffyTheRhino View Post
Nothing says "Upgrade EVERYTHING" like busted parts
Old June 25th, 2010, 01:14 PM   #8
0949er's Avatar
12.85 @ 114
0949er is a jewel in the rough0949er is a jewel in the rough0949er is a jewel in the rough0949er is a jewel in the rough
where were you guys 1.5 months ago to tell me I should of stayed with 450 to the wheels???? I want my 3.33" pulley back
MODS:
Vortech V1 T-Trim @ 7.5 PSI (tuned down)
Comp Cam Stage 2's
+ more
432 rwhp / 396 rwtq 02/27/2011
NEW VIDEOS!
**It takes ~$60 a rwhp (over stock) for a 99-04 Mustang GT.** Do the Math
C2H5OH on the horizon
Old June 25th, 2010, 01:21 PM   #9
BYAHHHH!
Scott2001GT's Avatar
2001 Mustang GT
13.874
its been posted millions of times! ^
Old June 25th, 2010, 01:39 PM   #10
2004 STI
thanks for the info what transmission would be a better choice
Old June 25th, 2010, 02:06 PM   #11
blownstang's Avatar
Is it a stick or auto?
Old June 25th, 2010, 02:33 PM   #12
moosenuk17's Avatar
t56 or a tremec 525 i think its called
2011 escape
MUSTANG TAT CREW
Old June 25th, 2010, 02:59 PM   #13
BYAHHHH!
2001 Mustang GT
13.874
a built T45/3650 or a built 4R70w
Old June 25th, 2010, 03:12 PM   #14
2004 STI
manuel transmission
another thing i was wondering about an estimated cost to build a shortblock for 600rwhp and best ideas for internals
Old June 25th, 2010, 03:18 PM   #15
BYAHHHH!
2001 Mustang GT
13.874
stock 03/04 cobra internals with or without your stock crank. arp everything and new bearings ect.
Old June 25th, 2010, 03:28 PM   #16
2011GT1979's Avatar
2011 GT/CS
12.11@113
2011GT1979 will become famous soon enough2011GT1979 will become famous soon enough
A short block can range from a couple thousand to as much as you want to spend on it depending on parts.
2011 Mustang GT/CS 3.31's, Steeda Tri-AX, LCA's, Steeda Axle Back, Steeda CAI, Brenspeed Tune.
2008 Grey Mustang V6
2008 F-350 FX4 Supercab Long Bed (Race Car Hauler BABY!)
My 2011 GT/CS 12.3 @ 110 Pass in HD
Old June 25th, 2010, 03:57 PM   #17
blownstang's Avatar
manuel transmission
You could get a used 03/04 cobra shortblock for around $2,000. For your trans you could have Promotion Powertrain beef it up to handle 750 tq for around $2,000.
Old June 25th, 2010, 04:54 PM   #18
SpeedySam's Avatar
03 Evo 8 "Black Betty"
SpeedySam is on a distinguished road
1996-2004 mustang turbo system
Cheaper than the Hellion kit.
Member of the E85 Army421awhp/407awtq 4G63 FTW
New Time 11.93@119
As of 5/25/10 I own a 2003 Cobra 460 To the wheels
My mom has a SLP LM 2,C&L CAI, and a SCT 93 Tune
Old June 25th, 2010, 05:09 PM   #19
BYAHHHH!
2001 Mustang GT
13.874
i knew a guy who had a HP twin turbo kit. Ran well!
Old June 25th, 2010, 05:12 PM   #20
y2k02's Avatar
02 Mustang GT
9.91@133
y2k02 has a spectacular aura abouty2k02 has a spectacular aura abouty2k02 has a spectacular aura about
I have HP twin 60's on my car.
I have their new style hotside.
I have the whole hotside I bought in 04 available.
http://i160.photobucket.com/albums/t...t/DSCF4024.jpg
2002 GT
PI heads
Twin 60mm turbos
Th400
6.34@114 1/8
9.99@137 1/4
http://i160.photobucket.com/albums/t...t/DSCF5654.jpg
http://i160.photobucket.com/albums/t...2gt/IMG060.jpg
Threads Similar to: Turboing mustang
Turboing The 2v mystk96 99-04 65 April 18th, 2010 03:04 PM
Turboing 98 Cobra joexxx 4V / SVT 20 November 18th, 2009 12:32 PM
Live Broadcast at 5:30 PM Central: Mustang Stories Contest Winner Gets His Mustang unlicensed to drive The Clubhouse 30 July 7th, 2009 09:03 PM
turboing a six? is it hard? scrapdaddy jr. General Tech 7 February 21st, 2007 09:16 PM
So Md Mustang Club 3rd Annual Mustang & Ford Show Hwyman Mid-Atlantic 0 August 8th, 2006 03:39 PM
