#21 |
13.82@100.26
well it will be making power but its not enough like say the next gear at a lower rpm will actually be faster than riding out that gear. But idk about that, you'd have to ask a boosted guy. You said you have cams, so with your springs i have no idea... you'll hav to ask someone else. I just know with stock springs and cams you wouldn't want to turn that high as of risk of floating a valve. These motors aren't built to turn that high of rpms from the factory.
#22 |
It will be making more power at a higher rpm then how would shifting and making less power be better? I don't get it
Vortech V2 Si
#23 |
13.82@100.26
Eventually the power is going to decrease... i understand what you're saying but you'll also run out of gear and do not want to break something. Lol i'm probably sounding like a dumbass, i'm tired as hell
But riding a car out into 7k rpms can actually be slower instead of shifting at around 6.2k rpms and hitting the next gear at 4.5k rpms. It just depends, idk lol... you should have a feel for your car and where you need to shift, instead of riding it out to a high rpm you just shift on instinct because you can feel that not shifting is actually slower.
#24 |
Then I'm not really taking advantage of the cam or intake
Vortech V2 Si
#25 | |
12.73@111.36
ProCharger P-1SC, 9 psi, STD 396/383; Uncorrected 388/375; SAE 383/370 Mods list in Garage. |
#26 | |
04 mustang gt
7.21 @ 98
serious question
![]() cams + 150 shot |
#27 |
13.82@100.26
Because people usually get annoyed by it, or if they have a build for a higher reving engine. Its to get it out of the way for the builder because this is for race tunes right? Usually race cars can push higher, but for stock internals i'm just saying that the rev limiter is for safety.
#28 |
2003 Mustang GT
Agreed, but if I set my rev limiter at 6,800rpm, the only way Id ever go past 6,300rpm is if I miss shift, and going through the traps, probally about 6,500 with 4.10's and stock tires. My tuner rev'd mine til 6400rpm
![]() Vortech V1 Intercooled @ 11psi 394rwhp/392rwtq @ 9.5psi 415rwhp/400rwtq @ 11psi on Methanol Tuned By: Pete @ Performance Dyno Affordable Supercharger Build Guide Supercharger Info for Noobs |
#29 |
13.82@100.26
Yeah u are... it boosted hp in your peak ranges.
Threads Similar to: lowering the rev limiter, to avoid engine damage
| Rev limiter?!?!??! | 19915.0hh | 5.0 Mustangs | 3 | March 30th, 2010 02:46 PM |
| Rev limiter ?? | acehogg69 | 2005 - 2010 | 7 | August 17th, 2008 12:59 PM |
| rev limiter | blakehunter316 | 5.0 Mustangs | 13 | February 22nd, 2008 11:04 AM |
| Does the 4.6L Have a Rev Limiter? | OcOnnor220 | 99-04 | 26 | January 13th, 2008 12:20 PM |
| rev limiter??? | FoxHoss | 5.0 Mustangs | 9 | October 28th, 2007 02:04 AM |
