LinkBack (1) | Thread Tools |
#1
2002 mustang GT
car is overheating, helppp please
ok, so i noticed that the fan is NOT turning on, wether the ac is on or off.
so if you guys know, where is the fuse for the fan, the relay, or anything else that may cause it to go bad or not work please help |
i dont have a manual but i would think it would be under the hood or under the dash.should have a relay also
yp
Ok, so mine was also overheating in the heated days, what i did is i changed the thermostat. might help you but as far as the relay its under the hood mto your right. and the one under the dash is covered by a black panel hard to find. but seek and u shall find
2003 Mustang GT
Yea its definatley the fuse, check online of your user manual to see where the fuse is located.
![]() Vortech V1 Intercooled @ 11psi 394rwhp/392rwtq @ 9.5psi 415rwhp/400rwtq @ 11psi on Methanol Tuned By: Pete @ Performance Dyno Affordable Supercharger Build Guide Supercharger Info for Noobs |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() iTrader: 4 reviews
Fuse A in the under hood fuse box.
2003 Mustang GT
14.03@100
Sorry to thread jack real quick, but I have a similar problem to this. I have a 180* stat in my car, and when on the freeway my car is either at, or just above, 180* but when I'm on the streets (not in 5th gear) it will get as hot as 230*. What the hell do I do?
^ lower the temp that the fan kicks on
2003 Mustang GT
14.03@100
I don't have a tuner anymore...gotta do it another way
2002 mustang GT
so i figured it out, and the fuse was blown, but i got thinking... fuck, to blow a 50 amp maxi takes alot, and generally, if a fuse blew once, itl blow again, so i went to the fan and spun them by hand and noticed the blades had alot of resistence, and when i got a wire and put it in the fuse holder spot, the wire got real hot, so that led me to know that the fan motor was bad and was pulling alot, so solution,
new fan motor. |
2002 mustang GT
new fan ***
1999 Mustang GT
My low coolant light comes on at odd times and I know its not low. WTF? I parked it for 3 days and the light came on.
Accufab 70mm TB & Plenum, 3.73 gears, Flowmaster exhaust, K&N CAI, Steeda UDP, Aluminum D/S, Eibach 1.5 drop |
mine used to do that.. I got a fluidyne radiator and put more water in the coolant and it helped a lot.. usually won't get more than 195 degrees now.. it used to get to 230 and beyond with the stock radiator.. it was crazy hot
Vortech V2 Si
My coolant light is permanently on. You probably need to clean the sensor out or replace it.
Vortech V2 Si
13.82@100.26
Not to thread jack again, but would this be good to do at the track? Or run a lower thermostat? I usually pop the hood undo the radiator cap and leave the air vents on in the car and let it blow out with just the ignition on.
^wouldnt hurt, if youre not happy with the temps best thing to do is to get a better radiator. In the guy above's case where it just gets hot as hell sitting a light dropping the fan kick on temp should help out a little.
13.82@100.26
Okay thanks ajm, because i popped my radiator cap last time i was waiting in line for the brackets to get through and alot of pressure came out lol. Didnt think it was that hot since i hadn't ran it in a while, but it was a hot night too. I was just figuring if I was running a little lower temp i could run a tad bit better time.
LinkBack to this Thread: http://www.moddedmustangs.com/forums/99-04/171523-car-overheating-helppp-please.html
| Overheating Mustang - Kosmix : Reference, Videos, Images, News, Shopping and more... | This thread | Refback | July 4th, 2010 09:26 AM | |
Threads Similar to: car is overheating, helppp please
| car wont start helppp.... | 03stanggg | V6 Mustangs | 15 | April 12th, 2009 03:14 PM |
| Clutch helppp please!!! | John's_stang | 99-04 | 6 | March 13th, 2009 12:34 AM |
| Misfire... Please Helppp | AFHockey1304 | 96-98 | 1 | May 7th, 2008 06:31 PM |
| neeed helppp | Midnight Stang02 | V6 Mustangs | 7 | February 8th, 2008 10:59 PM |
| overheating and no heat in car, frustrating... | 97TunedMustang | V6 Mustangs | 19 | August 31st, 2007 01:14 AM |
