HELP coil on plug!!!!!
Old June 25th, 2010, 12:38 AM   #1
kkent is on a distinguished road
ok guys so i got a quick question. i was pulling into my drive way when all of a sudden a loud popping noise started from the engine bay. when i popped the hood i saw that the coil for the second cylinder on the left was moving and poping with air. has anyone had this happen before? is it just an o-ring that went out or did the spark plug strip? also it looks like the injector rail is covering the coil on do i have to remove it to pull the plug? and lastly if it did strip am i fucked or can i fix it? thanks for the help.
p.s. its got 56,xxx miles as far as i know the ignition system is completly stock and I havnt done th 60k service to change any plugs or anything.
Old June 25th, 2010, 12:43 AM   #2
UnixHH's Avatar
2003 Saleen S281
UnixHH is a glorious beacon of lightUnixHH is a glorious beacon of lightUnixHH is a glorious beacon of lightUnixHH is a glorious beacon of lightUnixHH is a glorious beacon of light
Send a message via Yahoo to UnixHH
aHHHHH DUDE THAT SUCKS!! you blew the spark plug out of the head...
480RWHP 450RWTQ 15psi @ 15* on 91 octane
Old June 25th, 2010, 12:44 AM   #3
UnixHH's Avatar
2003 Saleen S281
you need a new head or need to put a helicoil / timesert in.
Old June 25th, 2010, 12:45 AM   #4
UnixHH's Avatar
2003 Saleen S281
and no you dont have to remove the rail. just the 8mm bolt holding the coil on and the wireing harness plug on the coil and it will bend out of the way of the raill just pull up on it and you will probably have your spark plug stuck to it with a piece of the head still on the threads of the plug
Old June 25th, 2010, 01:10 AM   #5
Shitty!!! Ok well do you know how much it might be to do the helicoil done by a shop?
Old June 25th, 2010, 01:18 AM   #6
UnixHH's Avatar
2003 Saleen S281
not a clue.. thankfully i havent had to go down that road yet.. but im sure someone will chime in on it.. did you pull the plug to verify thats what happend? if so id make a new thread staying "need heilicoil or timesert in head" and you should get some replys
Old June 25th, 2010, 01:32 AM   #7
stal94gt's Avatar
2003 mustang v6 ;)
slow
stal94gt has much to be proud ofstal94gt has much to be proud ofstal94gt has much to be proud ofstal94gt has much to be proud ofstal94gt has much to be proud ofstal94gt has much to be proud ofstal94gt has much to be proud ofstal94gt has much to be proud ofstal94gt has much to be proud of
do a timesert best fix. running an oversized plug works with cast heads but has issues with aluminum.
Old June 25th, 2010, 04:38 PM   #8
TyCouey2000GT is an unknown quantity at this point
dude id go check to make sure the plug didnt just spin out before you go tell a shop the wrong problem. it takes 2 minutes to pull off a coil
Your Average GT
Old June 25th, 2010, 05:13 PM   #9
crazystang25 is on a distinguished road
They aren't hard to fix. Just get the timesert kit and follow the directions. I did mine in my dorm parking lot. Welcome to the world of Windsor. And ya it took the threads out of the head.
Old June 25th, 2010, 07:29 PM   #10
Ima check it tonight if it spun out Ima be so gratefully but I'm prepared for the worst. Thanks for the info guys. Feel free to post anyother helpful info
Threads Similar to: HELP coil on plug!!!!!
04 Coil on Plug P45X4F 99-04 11 March 1st, 2010 10:09 AM
2005-2007 Mustang GT 3V Coil Packs & Coil-on-Plug Connec ozan169 2005 - 2010 4 February 7th, 2007 09:03 PM
coil pack to coil on plug conversion mustang_montana 96-98 6 July 24th, 2006 01:32 PM
