VT/CMS Stage II blower cams questions - Page 3
Old June 26th, 2010, 10:03 AM   #41
BakerFX4's Avatar
BakerFX4 has much to be proud ofBakerFX4 has much to be proud ofBakerFX4 has much to be proud ofBakerFX4 has much to be proud ofBakerFX4 has much to be proud ofBakerFX4 has much to be proud ofBakerFX4 has much to be proud ofBakerFX4 has much to be proud ofBakerFX4 has much to be proud ofBakerFX4 has much to be proud of
iTrader: 14 reviews
gambling with engine damage? Hardhitter, havent you been running those cams and blower for a LONG time? At least you have since i can remember. I dont think those cams are radical enough to NEED it. Yes it should have been done but they are mild enough to be ok with it the way they are since they are already installed.
Your choice.
4.75 MMR 900se
Livernois ported heads
HP 292s blower cams
Procharger D1sc at 20+ psi
IW 15% OD pulley
(and more bolt ons)
E85
Tune/numbers coming shortly!!
Old June 26th, 2010, 04:23 PM   #42
1999 Mustang GT
hardhitter has a spectacular aura abouthardhitter has a spectacular aura abouthardhitter has a spectacular aura about
Send a message via AIM to hardhitter
I've had the cams in since February but I've had the blower on for a long time. With the amount of times it has gone severely lean from not having enough pump I am surprised I still have an engine. I'm wondering what is the maximum number of degrees it could be off. The fuel trims are good bank to bank.
Vortech V2 Si
Threads Similar to: VT/CMS Stage II blower cams questions
cms cams stage 2 UPRNewEdge 99-04 21 August 13th, 2010 06:01 AM
vt/cms stage 3 blower cams? wishIhada5.0 99-04 31 April 19th, 2010 10:27 AM
CMS Blower Cams ChrisJ 99-04 71 February 20th, 2009 03:32 PM
