front end slack
i have just replace both outer tie rods,both lower ball joints,and the driver side hub assembly.and new tires on the front and i still have a little play in my wheel.car has a alignment about 3 weeks ago.so what else could it be..inner tie rods.rack n pinion bushing or control arm bushing maybe..and how often does the inner tie rod need changed.
and its not so bad now that i have 245/45 instead of the 255/45 i had on it before
SLOW :(
Have you looked at the rubber disc where it bolts to the rack? I have read that headers cook this gem and makes it fail. Best guess anyway. Top is stock I believe.
anybody else
mm's nitrous mod
2000 mustang gt
11.79@115.83 (old set up)
i would look at rack bushings, or the rag joint on steering shaft.
'01 GT
Good places to start.
whats the best way to check the rack n pinion bushing?
2000 GT 'vert
not to hijack, but I'm in the middle of ball joint and tie rod end replacement. I'm likely to have a drivers side hub replaced as well as the caliper. How was the hub replacement compared to, say, the ball joints?
hub assembly is a piece of cake,pull you caliper off, caliper bracket and rotor and then get you a 36mm socket and remove the nut and hub assembly should come right off,if not tap it with a hammer.and while you that far into it, change out your ball joint..dont disconnect your tie rod right away,wait until you have the ball joint nut off,the tie rod helps hold ur spindle into place while taking the nut off
Threads Similar to: front end slack
| Back end sitting lower than front end? | Blown 97 GT | 96-98 | 31 | October 21st, 2009 03:45 PM |
| Rear end leaking/slack | ROUSH STAGE II | 2005 - 2010 | 14 | June 7th, 2009 03:38 PM |
| front end- again | zmaier | 96-98 | 1 | September 14th, 2008 09:26 PM |
| my front end | justinsstang | General Tech | 7 | February 8th, 2008 11:30 AM |
| Front End | ttop5.0 | All Other Vehicles | 0 | June 28th, 2006 09:03 PM |
