Thought a grille delete was supposed to be an easy install..
Old June 26th, 2010, 02:23 AM   #1
JasonT1124's Avatar
2000 Mustang 4.6l
JasonT1124 is on a distinguished road
Send a message via AIM to JasonT1124
I got my 2 piece grille delete from StandMods today and it didnt come with hardware... the bottom piece seems almost like its a hair too small and doesnt sit flat... and how do I secure the 4 posts in the bottom piece??
Old June 26th, 2010, 02:32 AM   #2
ajm
Have some pics or a better explanation. Im having trouble following what youre saying. Never had to do one before so cant picture what youre talking about off the top of my head. Little more info and im pretty sure i can help you out though.
Old June 26th, 2010, 02:35 AM   #3
JasonT1124's Avatar
2000 Mustang 4.6l
I will put up some pics tomorrow when its bright out if no one can answer this....
but there is 4 "posts" on the bottom of the grille delete that stick down into the bumper (for alignment) and I dont know how to secure them down, so they dont just pop up and move out of place.
Old June 26th, 2010, 02:38 AM   #4
ajm
"press on lock washers"
Cant think of the technical name but get you 4 of those from the parts store, set them on the "posts/dowels" then take a socket bigger than the dowel, yet smaller than the diameter than the washer, id say a 8mm or so, and use it and a hammer to tap it onto the dowel.
You could also use a speed nut but the above is much better.
Old June 26th, 2010, 02:46 AM   #5
JasonT1124's Avatar
2000 Mustang 4.6l
Nice! that will solve my problem! I also just found this:
NoviCane - Mach 1 Grill Installation
His looks a lot more secure... but i dont know if I want to go through all of that trouble...
Old June 26th, 2010, 02:48 AM   #6
ajm
Its up to you. One way or the other i doubt it would go anywhere once its clipped to the header panel up top so no use in doing more than needed, to add to that. It definitely wont go anywhere with the above or a speed nut. Only reason I dont like speednuts is theyre very easy to over tighten and tear shit up with. With the press on lock washer you just tap it in place and youre done. If you ever have to pull the grill off flip up each of the tabs with a mini pick, and theyll slip right off, lay them on the ground, beat the tabs back down with a hammer, slip them on and youre good to go.
Not too sure if a parts store will have the press on lock washers. But im pretty sure homedepot/lowes/whatever carries them. Prolly 20 cents each if that.
Old June 26th, 2010, 11:25 AM   #7
I8ACMRO's Avatar
2003 Mustang GT
14.03@100
I8ACMRO has a spectacular aura aboutI8ACMRO has a spectacular aura aboutI8ACMRO has a spectacular aura about
I never put the 4 screws back on my grille delete from the stock grille. There is a bit of a gap but not bad at all.
http://www.moddedmustangs.com/forums...-member-30498/
Originally Posted by RZNCAIN View Post
Drive the shit out of it and replace shit when it breaks. No point in having these things if we are going to drive them like a bunch of pussies!
Old June 26th, 2010, 11:28 AM   #8
3sportbob's Avatar
MY OTHER RIDE IS YOUR MOM
3sportbob will become famous soon enough
I heard double sided tape and a heat gun do wonders for the install.
“I Saw Elvis at 1000 Feet”
"I was doing fine until about mid-corner when I ran out of talent."
Old June 26th, 2010, 03:21 PM   #9
R3dFyre02's Avatar
R3dFyre02 has a spectacular aura aboutR3dFyre02 has a spectacular aura aboutR3dFyre02 has a spectacular aura about
double sided tape on mine. been 2 years and its still good. simople to do as well.
02GT - Blown motor
86LX 3.8TBI auto replacement daily driver
How to retrofit HID's
Old June 26th, 2010, 03:22 PM   #10
MustangGT06 is an unknown quantity at this point
Same with my GT.
Old June 26th, 2010, 03:37 PM   #11
neverfastenough1's Avatar
Man, glad I got the three piece. No trip to Lowes, no double stick tape, and no gaps. With no hassle install.
Old June 26th, 2010, 04:45 PM   #12
R3dFyre02's Avatar
mine cost me around 20 bucks, and took me maybe 5 mins to install. yep. that was a hassle!
02GT - Blown motor
Old June 26th, 2010, 04:53 PM   #13
BadBlackGT's Avatar
13.82@100.26
BadBlackGT is a jewel in the roughBadBlackGT is a jewel in the roughBadBlackGT is a jewel in the roughBadBlackGT is a jewel in the rough
she cost me around 20 bucks, and took me maybe 5 mins to finish. yep. that was a hassle!
fixt But double sided tape is what i used on my friends car too...
If its got titts or tires, it's gonna give you problems.
Originally Posted by navyman8903 View Post
He has a 500rwhp 1990 5.0L with a cam who's lope takes virginity.
Originally Posted by Towelly View Post
Go find some Chill biscuits, dip them in some Calm the Fuck down sauce and chill the fuck out.
Old June 27th, 2010, 03:32 PM   #14
red02gt is on a distinguished road
ive heard of others using the double side tape too
Threads Similar to: Thought a grille delete was supposed to be an easy install..
grille delete? realrider88 99-04 8 May 23rd, 2010 09:43 PM
thought these things were supposed to be fast!?!? Jucostud The Clubhouse 104 March 24th, 2009 05:51 PM
grille delete 04gtvert 99-04 13 August 12th, 2007 12:16 AM
Grille Delete 04Pony 99-04 12 December 19th, 2006 02:47 AM
Grille Delete ? 00SoSlow V6 Mustangs 4 May 20th, 2006 02:18 AM
