Wiring window switch
It's a Zex window switch and has a green wire that goes to a tach signal. Where's the correct spot to splice in?
Thanks. |
MM's nicest mod, :)
you need to have a tach adapter, cause i doubt the zex window switch reads the 12V sine wave pulse of each coil, it probrably needs the 12V square wave pulse that the tach adapter makes.
06 Dodge MegaCab Diesel 455rwhp/815rwtq REAL TRUCKS DON'T USE SPARK PLUGS |
It can be connected to an individual coil. You program the unit according to the tach signal. I'm unsure of which coil and which wire. The red wire on the coils seems to be the common denominator but....
unstoppable @ speed of light
Try PM'ing VMP tuning in the vendor's section. He installed mine when I got tuned and didn't have any problems with it. I wish I had paid more attention to it when he was putting it in, then I would be able to help you more. He got it done in about 30 minutes. Hope that helps a little...
I'm sitting here on the phone with Comp Cams/Zex....
Can you see where he hooked up the green wire? They're telling me it can go to any coil. |
I'll try to run out and take a look reall quick....
I'm not really sure how he did the install. He's got a yellow wire run to the WOT switch, and a white wire run to the back of the ECU. I am guessing that there is a certain wire on there that he plugged/spliced into that reads RPM's. Like I said I don't really know what's what back there, so it may just be best to give him a call... He's usually happy to help with technical problems. But I also have an MSD window switch, and it is probably a little different than what you have...
Mine's Zex. Thanks for looking.
Moderator
Tachometer NOT red or white/lt. blue ac ignition coil or coil pack
This is what we use to get a tach signal for remote start systems on your mustang. hope this helps
![]() ![]() BUILD 2 IN PROGRESS |
Moderator
you can go to the injectors but do not use the common wire, use the one that is un-common on each injector.
yeah it will go to any coil. its usually the right wire of the two.
#12 | |
Underhood wiring is complete, now I've got to get the hot wire through the firewall. I guess it was about 1985 the first time I did that, putting some lights on my Scout. And I've done it for some reason or another every car since. I've never seen a firewall so hard to work with as this one. I have no idea where or how I'm going to get that hot wire through. I'm done for the day. Maybe with rested eyes in the morning I'll see a solution. |
Threads Similar to: Wiring window switch
| window switch? | 00redgt | 99-04 | 6 | November 5th, 2007 06:03 PM |
| rpm window switch. | mustangrebuilder | Audio/Video | 0 | September 18th, 2007 08:58 PM |
| rpm window switch. | mustangrebuilder | 2005 - 2010 | 0 | September 18th, 2007 07:37 PM |
| window switch | barksdaleammo | General Tech | 31 | May 23rd, 2007 09:33 PM |
