500 hp 2v
Old July 7th, 2010, 02:55 AM   #1
02trueblueGT's Avatar
n/a
02trueblueGT will become famous soon enough
500 hp 2v
Just now starting to kick things into gear. I am wanting about 500+ or so with my build. And I figured this would be a good place to get some advice and build lists. I'm thinking Kenne Bell as well. So what are some good lists of an outline for my build (internals mostly) and maybe some cam/head suggestions as well. Thanks!
TRUE BLUE CREW MEMBER #4
Old July 7th, 2010, 03:11 AM   #2
UnixHH's Avatar
2003 Saleen S281
UnixHH is a glorious beacon of lightUnixHH is a glorious beacon of lightUnixHH is a glorious beacon of lightUnixHH is a glorious beacon of lightUnixHH is a glorious beacon of lightUnixHH is a glorious beacon of light
Send a message via Yahoo to UnixHH
whats your budget?
480RWHP 450RWTQ 15psi @ 15* on 91 octane
Old July 7th, 2010, 03:17 AM   #3
Hooo Ha Ha
sharkbait's Avatar
1997 Mustang GT
10.87 @ 125
sharkbait has much to be proud ofsharkbait has much to be proud ofsharkbait has much to be proud ofsharkbait has much to be proud ofsharkbait has much to be proud ofsharkbait has much to be proud ofsharkbait has much to be proud ofsharkbait has much to be proud ofsharkbait has much to be proud of
iTrader: 10 reviews
Lookup Bakers garage.
Copy his setup
496rwhp 580rwtq @ 12psi
76mm Turbo 5.4 swap
#turbo2v
www.JPCracing.com 410-729-0005
Old July 7th, 2010, 03:19 AM   #4
UnixHH's Avatar
2003 Saleen S281
what about me
Old July 7th, 2010, 03:29 AM   #5
Hooo Ha Ha
sharkbait's Avatar
1997 Mustang GT
10.87 @ 125
iTrader: 10 reviews
Your to cool to be copied
76mm Turbo 5.4 swap
#turbo2v
Old July 7th, 2010, 03:31 AM   #6
UnixHH's Avatar
2003 Saleen S281
haha
Old July 7th, 2010, 10:08 AM   #7
Shaun13GT/CS's Avatar
2003 Mustang GT
11.98 @ 118.68mph
Shaun13GT/CS has a reputation beyond reputeShaun13GT/CS has a reputation beyond reputeShaun13GT/CS has a reputation beyond reputeShaun13GT/CS has a reputation beyond reputeShaun13GT/CS has a reputation beyond reputeShaun13GT/CS has a reputation beyond reputeShaun13GT/CS has a reputation beyond reputeShaun13GT/CS has a reputation beyond reputeShaun13GT/CS has a reputation beyond reputeShaun13GT/CS has a reputation beyond reputeShaun13GT/CS has a reputation beyond repute
iTrader: 23 reviews
Yea whats your budget?
With 500rwhp, youll most likley need a new shortblock. You may be able to get away with 500rwhp for a little bit, but everytime you go WOT, youll be chancing the life of the motor.
Kenne Bell 2.1 intercooled Kit 12psi
Shortblock
Fuel Supply, I dont know if youll need a dual pump setup for 500rwhp, but if so then a Cobra Hat, (2) 255lph Fuel Pumps, Kenne Bell 40 amp boost a pump. 60lb Injectors
At that point, Id just go return style fuel system though.
Blower Cams - Houston Performance s292's
Heads - Ported your stockers, or Ported FoxLakes or Trickflow's Twisted Wedge 44cc heads
Idk just some ideas, I dont know what your budget is, or what your goals are for the car
2013 Mustang GT/CS 406rwhp & 397rwtq
Kooks Axleback, UPR o/r X Pipe, Airaid Intake, Shaftmasters Aluminum Driveshaft.
2003 Mustang GT - Vortech 415rwhp SOLD
Old July 7th, 2010, 10:55 AM   #8
BakerFX4's Avatar
BakerFX4 has much to be proud ofBakerFX4 has much to be proud ofBakerFX4 has much to be proud ofBakerFX4 has much to be proud ofBakerFX4 has much to be proud ofBakerFX4 has much to be proud ofBakerFX4 has much to be proud ofBakerFX4 has much to be proud ofBakerFX4 has much to be proud ofBakerFX4 has much to be proud of
iTrader: 15 reviews
MMR rotating assembly with 17cc or 18cc dished pistons and forged h beams and forged crankshaft. (1300-1500)
ported heads (1000-1200)
blower cams (450)
and KB at about 10-12 psi (EXPENSIVE)
dual cobra pump assembly (300 bucks or so)
mafia for your maf or sct ba3000 (150-250)
And then bolt ons of your choice but the above would hit 500rwhp. And my prices are assuming that you build it yourself.
If paying for built shortblock and to put all of the above together, WOW... expensive! lol
4.75 MMR 900se
Livernois ported heads
HP 292s blower cams
Procharger D1sc at 20+ psi
IW 15% OD pulley
(and more bolt ons)
E85
Tune/numbers coming shortly!!
Old July 7th, 2010, 10:57 AM   #9
tkrizzy3 is on a distinguished road
Depends on your budget for sure. Definitely will want a new short block or at least new internals if your putting out that much power.
Old July 7th, 2010, 11:17 AM   #10
Black Bullitt's Avatar
2001 Mustang Bullitt
Faster than Twinmill
Black Bullitt is just really niceBlack Bullitt is just really niceBlack Bullitt is just really niceBlack Bullitt is just really nice
Send a message via AIM to Black Bullitt
Budget is going to be your deciding factor obviously.
Aluminator short block $3,315 shipped from LRS. Best bang for the buck IMO.
MHS Stage 2 heads w/ choice cam $1995 shipped
A KB is going to be some money on top of the above mentioned.
2001 Bullitt #5069
505rwhp/538rwtq @ 15#s
Originally Posted by FluffyTheRhino View Post
Nothing says "Upgrade EVERYTHING" like busted parts
Old July 7th, 2010, 11:19 AM   #11
IMHO go with a turbo, sound is cooler and less common
Old July 7th, 2010, 11:20 AM   #12
Also, you need to look into a fuel setup as Shaun & Baker pointed out. Return style would be the optimal setup, but that's more money yet again.
I have over 7k sunk into my single Hellion build with a Ford Aluminator, mildly ported heads, stock cams, dual GT supercar pumps, flywheel, clutch, gaskets & misc items. That's not to mention my built rear end on top of that. I still need a straight through catback exhaust (probably going Magnaflow magna packs), cobra tank, manual boost controller, and a tune. Hopefully this doesn't discourage you on how much it costs to build our cars, but more of a break down of what you'll encounter on your way to 500 HP.
2001 Bullitt #5069
Old July 7th, 2010, 11:36 AM   #13
slow02gt's Avatar
2002 mustang gt
11.38@119
slow02gt is a jewel in the roughslow02gt is a jewel in the roughslow02gt is a jewel in the roughslow02gt is a jewel in the rough
Send a message via AIM to slow02gt
return style is no needed if he just wants 500 hp...just use cobra tank/hat and pumps.. shouldnt even need boost a pump and 42 or 60s and be fine... guy down has a 2.1 kb with the hp cams and it really didnt make good power for what he has done..those are more good for a centri blower cam..
i say throw some cams and any kind of blower on there and you will be happy with 470-500 to the wheels...to do a built short block to do 500 hp really isnt worth it to me..
a bunch of shit lol..
Old July 7th, 2010, 11:40 AM   #14
I didn't say he needed a return style, I said it was the optimal fuel system. All other returnless style fuel setup are band aid fixes in comparison, but that's neither here nor there. Yes, dual Cobra pumps/hat/tank will work in his situation. In fact I'll be running a dual GT supercar pump setup on a Cobra hat & tank for now until I can get a return style, but that'll be a bit down the road. I don't recall where the 42# injectors max out at. I'll have to go look again. I want to say 500 on 42's is starting to push them, but don't quote me.
2001 Bullitt #5069
Old July 7th, 2010, 12:11 PM   #15
redrocket's Avatar
redrocket is on a distinguished road
i have 5.1 stroker
cms 2.5 blower cam
ported stock heads
retainers and springs
Cobra tank and stock pumps
ba2800 MAF
60#injectors
Vortech V2 sci trim at 12 psi 536 rwhp
RET tuned 718rwhp/588tq
Old July 7th, 2010, 12:15 PM   #16
slow02gt's Avatar
2002 mustang gt
11.38@119
^^^^^so why put all that money in a stroker motor(that really didnt help) blower and injectors and stuff and only run 12lbs...just doesnt seem worth it..
Old July 7th, 2010, 01:45 PM   #17
I8ACMRO's Avatar
2003 Mustang GT
14.03@100
I8ACMRO has a spectacular aura aboutI8ACMRO has a spectacular aura aboutI8ACMRO has a spectacular aura about
Seeing as how he is ONLY running 12psi and getting those numbers is damn good IMO.
http://www.moddedmustangs.com/forums...-member-30498/
Originally Posted by RZNCAIN View Post
Drive the shit out of it and replace shit when it breaks. No point in having these things if we are going to drive them like a bunch of pussies!
Old July 7th, 2010, 01:48 PM   #18
1999 Mustang GT
hardhitter is a jewel in the roughhardhitter is a jewel in the roughhardhitter is a jewel in the rough
Send a message via AIM to hardhitter
Their street mod 600 motor is $500 less. Seems like even better bang for the buck if you're only shooting for 500hp.
Vortech V2 Si
Old July 7th, 2010, 02:13 PM   #19
Trick Tuners's Avatar
KB'd GT
If you want to use a PD blower then get the 2.6, 2.6H or 2.8. The 2.1 is too small and will be near maxed out. You could probably make 50hp more with a 2.6 at the same boost, or get away with more power on pump gas.
Old July 7th, 2010, 04:34 PM   #20
The MMR short block doesn't have ARP bolts through out nor a cobra crank. And for $500 more he can take it past the 600 mark if he decided 500 wasn't enough. It's nice to have the room to grow if he wanted. To get the stuff the aluminator has you'd spend way more with MMR. Bang for the buck...I think so.
2001 Bullitt #5069
Threads Similar to: 500 hp 2v
Need Help With a JL 500/1 weems Audio/Video 15 August 4th, 2009 07:32 PM
I wish i had $22,500 right now.. 510jatt The Clubhouse 5 April 5th, 2009 07:55 PM
Me vs GT 500 DrHolliday Videos 5 August 24th, 2008 04:54 PM
The C-500 deVin 2005 - 2010 6 February 17th, 2007 10:05 PM
500 HP!!! Brianzeke007 V6 Mustangs 19 January 15th, 2007 12:35 AM
