How much is a transmission rebuild? - Forums at Modded Mustangs
post #1 of 9 Old July 11th, 2010, 05:53 PM Thread Starter
Anybody had this done. I won't be doing this myself, probably Aamco or someone similar.
TweederGT03 is offline
post #2 of 9 Old July 11th, 2010, 06:08 PM
liljojo4711's Avatar
if u know who is going to do the work then call them and ask.....
TOPLESS MUSTANG CLUB
Originally Posted by I8ACMRO View Post
I'll try the vaseline tonight. Thanks for the tip.
liljojo4711 is offline
post #3 of 9 Old July 12th, 2010, 04:04 AM
USMC '03 GT's Avatar
well seeing both of my mustangs had rebuilt transmissions, i'll give my insight:
-2003 stocker GT: 1300 for a rebuilt stock trans
-2001 s/c GT: 5000! it'll handle 650 hp, 800 if i put in a manual valve body
really depends on the shop. if your stock one needs repair, just pull one from a junk yard, not worth the hassle unless you get hooked up. and buy an aftermarket trans if you have power and need a beefy trans... i got pOWN'd
I must be a nympho cuz i'm always getting screwed.. oy...
USMC '03 GT is offline
post #4 of 9 Old July 12th, 2010, 04:06 AM
Admanistrator
v606er's Avatar
There is a guy on here in the drivetrain classifieds (his username is e3sean) who is rebuilding them. I think it is around 750$
MAD Stangs #8
v606er is offline
post #5 of 9 Old July 12th, 2010, 04:09 AM
UnixHH's Avatar
Send a message via Yahoo to UnixHH
ProMotion Powertrain you can get a built tr3650 that will handle 750hp for 1700$
480RWHP 450RWTQ 15psi @ 15* on 91 octane
UnixHH is offline
post #6 of 9 Old July 12th, 2010, 04:10 AM
UnixHH's Avatar
UnixHH is offline
post #7 of 9 Old July 12th, 2010, 07:11 AM
manolith's Avatar
i have a promotion powertrane built 3650 and its pretty much broken in already.. so far im happy with it.. it has not seen nitrous yet but it will sometime this week.
2011 GT. Paxton@10psi-ID1000-KB bap-O/R Xpipe-GT500AB-Boss intake-4.10 gears-TA girdle-N2NB Wot box-K Springs-UPR Pro series control arms-Big and littles. 780,000 rwsqp.
https://www.youtube.com/user/Manny32V
instagram: fumaliche
manolith is offline
post #8 of 9 Old July 12th, 2010, 10:12 AM
blownstang's Avatar
Yup... if your car is a stick this is the way to go. If you won't be increasing the hp of your car and just want a stock replacement get a low mileage used trans. A GT/Mach 1 take out will probably only be a few hundred bucks.
2003 DSG Mustang GT TR3650 - 411/403 with a Vortech S trim. Now back to stock.
2004 DSG Mustang Mach 1 4r75w - 423/387 through unlocked converter. Intercooled Vortech V1 S trim, Circle D 4c converter, BCA valve body, VRS o/r x pipe
blownstang is offline
post #9 of 9 Old July 12th, 2010, 11:20 AM
SteviGX's Avatar
Send a message via AIM to SteviGX
I've got the same...very happy with it
Mineral Gray Club Member #2
Just your average 22 year old dumbass
If you didn't build your car, and your bragging about it, STFU
SteviGX is offline
Human Verification
