Hooo Ha Ha
5.4 4v Navigator motor questions
I cant seem to get my mind off this swap.
So i thought id ask a few questions Doing a 5.4 4V swap, would it just be like swapping a 4v 4.6 in my car? Also what intake manifolds are available for the (i think C port) 4v heads. I also heard the navi heads have a larger intake runner and a smaller exhaust runner due to a coolant passage? Is that true? Whats the weakest part of a 5.4?
![]() 496rwhp 580rwtq @ 12psi 76mm Turbo 5.4 swap #turbo2v www.JPCracing.com 410-729-0005 |
You have to run a 5.4 intake, its a wider motor and 4.6 stuff wont fit. Sullivan, hogan and others make intakes for them, they are pricey though 700-1000 dollars new
it does drop in, but with the 4v heads on a 5.4 you will be pushed to the max on space. the exhaust ports arent that bad, they are one of the better stock flowing heads, even coming on a truck. A little pork work REALLY opens these heads up. The stock motors are pretty stout, I helped put one together in a 99 car and with 10lbs of boost was a beast, people say they will handle 700-800 stock, but until I see it, Im not gonna jump on that one. Modified right they will make/handle what ever you want them to make. I want to build one N/A about 11:1 ported heads, good cams, spin it to 7500 should be good for 500ish at the wheels with nothing radical other than the compression ratio
Hooo Ha Ha
So wait.
your saying the bottom end on that car is stronger then the average 4.6?
the car I worked on dynoed 57x but some have said 700-800 it will/can handle. Ive never seen it, does it mean its true or not, I cant say
Hooo Ha Ha
Anyone else had any success with these motor or head of success with these motors?
honestly, if you just buy a good intake and throw some good guts inside it, you will make more power than youll know what to do with
Procrastinator
2003 gt
5.4 32v on the way
the 5.4 dohc is a nice motor when done right, go with a boss290 manifold, 11:1 comp ratio, and some mild cams and you will have a fairly stout NA mod motor.
Hooo Ha Ha
Well going for N/A power is a waste. You can go farther any day with boost.
but the piping gets tricker with that motor in your engine bay, 550 will make you shit your pants, esp with what you have now
Hooo Ha Ha
Are there any roots style superchargers for that setup?
Procrastinator
2003 gt
5.4 32v on the way
if you stick with a 2v 5.4 you can look into a lightning blower.
Hooo Ha Ha
Would a GT500 setup work?
2000 gt
I would think so, but it wouldn't be cheap. Better to go wiu a procharger. A pd blower on a 5.4 will not fit under hood, and I know of no one who makes a hood to clear it.
Procharged 2000 5 Speed BAB GT, built motor, blower cams, speedy dyno tune 412 hp, 450 rw tqHARDCORE CREW BRIGHT ATLANTIC BLUE CREW #1 MEMBER |
Hooo Ha Ha
Im not too worried about the hood issue.
If worst comes to worst il buy a huge ass cowl hood. To me the torque of a 5.4+ PD blower = sex.
i just purchased a 5.4 out of 05 f150, any one know if i can drop this in my 02 gt how it is or will i have to change the heads and front dress over to make it all work
Procrastinator
2003 gt
5.4 32v on the way
if its a 3v, you will have to figure out something with the tb, exhaust manifolds, and something with the cams and it should work.
yeh it is a 3v it came with jba headers and they stick out like beasts , i think ill swap the 2v heads to it so i could use the 270 cams i have on the shelf
#18 | |
The stock 3v 5.4 is my truck hauls ass in a 5000lb truck, only imagine in a mustang
2000 gt
Keep the 3v, it's a much better choice than a 2v
i was thinking to swap the heads because i have all these new parts sitting here and they are all for the 2v heads compbehive springs and comp 270 cams and comp ajustable cam gears so on and plus i dont have all the wire harness for the 3v engine
Threads Similar to: 5.4 4v Navigator motor questions
| 93 Cobra Twin Turbo Dohc 5.4 Navigator Motor | stroked93 | Videos | 3 | July 20th, 2009 01:29 AM |
| motor questions | busaonboost | 96-98 | 5 | June 3rd, 2009 08:59 AM |
| motor questions | superbean | 5.0 Mustangs | 0 | September 22nd, 2008 11:51 PM |
| Navigator Engine. | blitzed589 | Modular Mustangs | 7 | December 28th, 2006 12:52 AM |
