2002 gt not running??? had multiple missfires not running!!
Old July 18th, 2010, 11:23 PM   #1
2002 mustang gt
foxcruzin91lx is on a distinguished road
Hi i'm new to this forum....
MY 2002 mustang gt isn't currently running...
A week ago I had codes for the mass air flow sensor saying it was running to lean... and the car was jerking sometimes at around 1500rpms in 4th or 5th gear..
I cleared the codes and it was fine....
Then he check engine light came on and had multiple misfires at 1000 rpms and then 1,3,5 ,7 cylinders had misfires. and the car was jerking badly at 1500 rpms... and would shut off sometimes...
the the check engine light would flash and i would have no power at all...
I replaced the plugs and the car ran amazing for like 30 minutes. It shut off on the highway and wont start.... no spark I have fuel pressure but no spark...
the car started for 2 seconds on starting fluid...
I did notice the steeda timing adjuster is alittle loose on the crank pulley....
The car has comp cams, bbk long tube headers, off road h-pipe, flowmaster exhaust...
please let me know any information....
Or what fuse does what in car and under hood.
Thanks again!!!
Old July 18th, 2010, 11:32 PM   #2
stal94gt's Avatar
2003 mustang v6 ;)
slow
stal94gt has much to be proud ofstal94gt has much to be proud ofstal94gt has much to be proud ofstal94gt has much to be proud ofstal94gt has much to be proud ofstal94gt has much to be proud ofstal94gt has much to be proud ofstal94gt has much to be proud ofstal94gt has much to be proud of
check the tip of your crank shaft position sensor for scratches or any thing stuck to it. i would get rid of the timing ajuster all together and get a tuner. in the end it may cost you more to keep it than what it is worth. leaving the sensor in the open like that is not a good thing and the spacing the pick up has to be is so tight that many pickups get damaged
Old July 19th, 2010, 12:38 AM   #3
13.2
Mustang02gt is on a distinguished road
haha is the code you pulled on the maf something like p1172 or 1052? sounds like the same symptoms i had with my car after spinning my cam gear off of my cam shaft
Old July 19th, 2010, 11:27 AM   #4
2002 mustang gt
I hope that's not the problem... it was p1131 and 2 others and then p1151 I believe don't remember.... said system to lean bank 1 then hooked it to another scanner and that said the mass air meter on 3 codes....
I was going to take the t/a off and buy a new crank sensor
Old July 19th, 2010, 09:05 PM   #5
2002 mustang gt
turns out the timing adjuster came loose and broke the crank position sensor... the car runs but idles high... so I'm going to mess with the t/a and the iac and see what happens... I also will be buying new coil packs, 24lb injectors, intake manifold, cai, and gears....
Old July 19th, 2010, 09:34 PM   #6
stal94gt's Avatar
2003 mustang v6 ;)
slow
get rid of the timing ajuster it is a pos
Old July 19th, 2010, 11:46 PM   #7
2002 mustang gt
nice.... now there is a minor minor tapping noise in the engine... only at idle... i didn't hear this till i changed the spark plugs... i hope they aren't hitting anything... also wondering if the car is out of time will i hear something like this.... or could it be a sign of a bad injector?
Old July 20th, 2010, 03:47 PM   #8
Trick Tuners's Avatar
KB'd GT
+1
Old July 20th, 2010, 04:00 PM   #9
maxgst's Avatar
maxgst has a spectacular aura aboutmaxgst has a spectacular aura aboutmaxgst has a spectacular aura about
It could be a bad injector, check them for ohms and flow
.............................2000 GT Vert.............................
How To Cut/Remove springs
Threads Similar to: 2002 gt not running??? had multiple missfires not running!!
Got Her Running, But wont stay running...help? Speedstang302 5.0 Mustangs 10 August 28th, 2011 06:58 PM
Up and Running jumperjack 4V / SVT 11 March 31st, 2009 11:59 PM
Running like S**T 347stroker 99-04 18 March 16th, 2009 05:02 PM
running mpboy The Clubhouse 5 February 8th, 2008 10:29 PM
Supercharged 2002 GT....running lean, BOV problems...HELP! jadie24k 99-04 3 February 10th, 2007 08:51 AM
