Squeaking GT!
Old March 25th, 2007, 05:51 PM   #1
dmachine22's Avatar
1998 Z28
dmachine22 is on a distinguished road
Squeaking GT!
1.) Squeaks when it's dry or hot outside!
2.) Doesn't squeak when it's raining outside!
3.) Noise is coming from the front drivers side!
4.) Hear when I turn right or left or when going over speed bumps!
5.) And again when it rains it stops for a day or two then when it heats up or it's dry outside it starts squeaking again!
Unknown
Old March 25th, 2007, 07:46 PM   #2
02steedagt is on a distinguished road
Send a message via AIM to 02steedagt
i have a similar squeak sometimes... it's not consistent. so far, i've determined that it's not in the engine compartment. i think that it's in the dash board somewhere.
"America is all about speed. Hot, nasty, bad ass speed."
Eleanor Roosevelt, 1936
Old March 25th, 2007, 08:17 PM   #3
k2boarder3187's Avatar
EVO 8 @ 29psi
k2boarder3187 is on a distinguished road
check your ball joint. if the rubber around it is torn or breaking apart its time to replace it. i had the same problem when it rained out it wouldnt squeak but it did all other times. dont let it go because mine ended up breaking and the front left tire was slammed against the wheel well so i had to get it towed.
2003 EVO 8
The shop built motor, Precision 6262 w/.82 hotside, tial 44mm wg, Buschur RACE 4" FMIC, Kelford 272s etc
524whp @25psi on straight pump gas.
640whp@33psi Pump+meth
Race gas number soon.
TheShopCt.com
Old March 25th, 2007, 08:25 PM   #4
dmachine22's Avatar
1998 Z28
Yeah I was told it was a ball joint, just wanted to see if anyone else would agree with that also thanx!
Unknown
Threads Similar to: Squeaking GT!
squeaking... 01silversnake 99-04 6 September 20th, 2007 10:25 PM
Squeaking... weems 99-04 11 August 6th, 2007 07:50 PM
Squeaking I_eat_rice 99-04 4 July 21st, 2007 03:37 AM
squeaking xedubx 99-04 4 July 15th, 2007 11:34 AM
Squeaking suspension Mystry 96-98 2 May 2nd, 2007 06:35 PM
