2002 GT
![]() iTrader: 1 reviews
Tork Tech Build Log
As many of you know I have been asking questions recently relating to the tork tech eaton swap for my 02 gt.
Despite much flaming and links to centri blowers I am still pushing through to do the Eaton swap! Flame all you want etc... I want my positive displacement and dont want to pay the pretty penny for a KB Intercooled setup. With that said, I will tell you what is needed for the swap. Fuel: Bigger fuel pump Bigger injectors Injector Adapters I went with a Ford GT supercar fuel pump and slightly used cobra injectors. Injector Adapters $40 Fuel Pump $80 Injectors $150 Air: Eaton M112 Elbow Throttle Body MAF Air Intake IAC Valve All of the air parts I got are slightly used and they are all stock from the 2003-2004 Cobra. Eaton M112 $200 Elbow/Throttle Body $75 Air Intake/MAF $80 IAC Valve $30 Tork Tech Parts Tork Tech Intercooled Kit $2000 IC Parts Heat Exchanger estimated at $75 used Intercooler Pump unknown price Intercooler Tank unknown price My Goal (without dyno costs or hood solution costs) : Build < $3000 So far I have spent $655 and I still need the following: Heat Exchanger. Intercooler Pump. Intercooler Tank. Tork Tech Intercooled Kit I hope I have not forget any parts, other than miscellaneous little things. All parts that I have bought used have less than 30,000 miles on them. I will have pics up in a few days of what I got so far! And if I get one link to a centri blower then I might go
2002 GT', 5speed, Magnaflow: Magnapacks Cat-less x pipe K&N drop-in air filter |
good luck!
![]() 02GT - Blown motor 86LX 3.8TBI auto replacement daily driver How to retrofit HID's |
#3 | |
J/k Good luck with the build. Thinking about doing the same thing if I can't talk myself into buying a new GT.
#4 | |
2002 GT
In the mean time you can have a bad ass whistle when your driving your car
I don't know what the difference is or if there are any, but there is a S197 Salleen h/e on Ebay for 150. I am sure you can find one from a Termi for around the same price used.
I'm 44, I might grow up before then.
2002 GT
oh man used termi heatexchangers are $75... Ima try to get one for $50, because alot of people have them laying around taking up space.
2002 Mustagg GT
1/4 - We'll see soon
Good luck man. Curious to see your $$ at end. I am going to be doing the GT super car pump too. I am not sure what it entails so curious on your fuel set up. How much RWHP do you think you will get?
" Drive Fast - Take Risks " LawlessRebel ![]() SOLD - My 02 Supercharged. Got a 95 5.0 for a few weeks till I sell or trade it!
2002 GT
well eatons are good up to about 450-500 unported I think. but with stock longblock probably gonna shoot for 400rwhp.
For the gt pump I read you just need a gates sumbersable hose (pprv delete)
yeah on a 4v. i bet you'll still get to 400rwhp though. what size pulley are you running?
2002 Procharged GT 12.503 @ 113.08 351rwhp 353rwtq Car Videos: http://www.youtube.com/user/mell00ut5?feature=mhee
i wish i could afford tork tech. it seems pretty outrageous to me that an intake manifold is 1700 dollars. i mean come on.
#12 | |
2002 GT
# Aluminum lower intake manifold # High capacity intercooler # Front engine cross brace assembly that provides a independent 8-rib supercharger drive assembly with all belt tensioners and idlers. # 7" lower piggy back style crank pulley that attaches to the factory pulley dampener to complete the separate 8-rib drive belt assembly. I think a unported eaton could beat out a stock 2v longblock. However, I wont be the one to find out haha ![]() As for the pulley I am not sure. Once I order tork techs kit I am gonna ask them what they recommend for 400 to the wheels. I am guessing it will probably be between 2.8-2.93.
#13 | |
#14 | |
2002 GT
![]() Yeah I am getting the 2000 dollar one. I am positive you could build a NON-IC Termi setup for less than 2400.
hell yeah man glad to c someone going with this build. been wanting to see it done for sometime now. im wanting to go KB but this looks like a cheaper, but just as powerful, option
![]() Stock Rear Springs FOR SALE! PM Me Stock 99-04 GT Exhaust Manifolds FOR SALE! PM Me |
1999 3V GT/2007 GT D/D
corner carver
good luck, hope it pans out the way you want.
OS2 (SW) USNREAR SEAT DELETE FABRICATOR "RSD pics in garage" 99 3V GT/2007 GT DD |
2010 GT Sterling Grey
12.97 @ 107.34
jesus scott! lol You have done your research!!! how much longer till you would finish this?
OK, I'm gonna be that guy who resurrects an old thread.
I've been working this install on my 01 GT since Feb, and I did the initial start up yesterday. So far I am still getting the tune worked out so no driving impressions yet, but here is a summary of what I found on the install. The major kit components install easily, but the little odds and ends after those are on are a PITA. Also, I had trouble with the IC fittings that run into the manifold. They did not extend far enough into the heat exchanger under the blower, so I had to work them with a bench grinder to make them work. You need many more 03-04 Cobra parts than just the IAC. I don't currently live in an emissions state but that might not always be the case so I opted to install the EGR system while I had it apart. You need a Cobra EGR valve where the fitting faces the drivers side, and the Cobra EGR to manifold tube...that actually lines up perfectly. Factory 03-04 Cobra intake ducting DOES NOT FIT! The oil fill on the valve cover is in the way. I went with a Steeda 03-04 Cobra intake and an Airaid U-Build It. It ended up the 60 degree angle and the sections of straight right off it fit perfectly. The port where Cobra's have the IAT2/MAP sensor. You could get the sensor to plug the hole, but I made a small plate out of one of the old brackets. I then drilled and tapped it for a 1/8" NPT brass T-fitting. One T goes under the plate, one faces the firewall and I ran the boost gauge to it, and the third faces up so I put a 1/4 hose barb in it and have that hooked to the relief actuator. I also got a 1/8 plug so I can bypass the actuator for the additional boost at the track. You need 03-04 Cobra throttle and cruise cables. An 03-04 Cobra hood works if you're like me and not into the Cobra R look. Oh, one last note, the SC belt is a B**CH! Get a 1415mm belt, and install it from under the car. Under the car you get a better grip on the breaker bar to relieve the tensioner, then work it over the crank pulley. I'm very interested in your notes from the install, and if you have any tips for the fine tuning. |
2003 mustang v6 ;)
slow
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() iTrader: 2 reviews
sounds like you got things going pretty good. only think i would do diff is where you tapped in the map senser you should have threaded it and put a iat senser there so you can get your tuner to yank timing if things get to hot. also i would invest in a ice box style water tank. i tried to keep using the stock ic tank it the water was heat soaking when i was at the track. as for the boost accuator, just run a boost/vac line to the top port and leave the bottom port open, i also would not worry about capping off the bypass at the track it does not bleed off boost unless your using the boost purge valve which you should not be running since you do not have the electrical and pcm controls to run one.
![]() bone stock from the factory! |
King Sisyphus
1999 Mustang GT
I am also doing this build. I started an install thread on a different forum though.
Here is the link Tork Tech Install |
Threads Similar to: Tork Tech Build Log
| My 2000 GT + Tork Tech build | Double0Fox | 99-04 | 113 | December 25th, 2010 05:36 PM |
| tork tech | SilverGT04 | 99-04 | 25 | December 1st, 2009 04:23 PM |
| Tork Tech build-up | wishIhada5.0 | 99-04 | 41 | December 29th, 2008 03:21 PM |
| Tork Tech? | Hawaiianbro | 99-04 | 3 | September 22nd, 2008 01:37 AM |
| Tork Tech? | Cricket | 99-04 | 5 | July 5th, 2008 02:59 PM |
