Bad brakes, one wheel locks up - Forums at Modded Mustangs
post #1 of 6 Old July 26th, 2010, 08:58 AM Thread Starter
01KnightRiderGT's Avatar
Send a message via MSN to 01KnightRiderGT
Hey gals/guys. Only my front right (passenger) wheel locks up when I firmly apply the brakes. Yes my traction control is out, and ABS as well. Already checked my lines for any pinches or misplaced bends. Any other areas I should check?? All stock brake components with 95K. THANKS
Black Stang Member #13
315's Crew Founder
My Track Videos
01KnightRiderGT is offline
post #2 of 6 Old July 26th, 2010, 09:17 AM
Abyssinian of AX
Jazzer The Cat's Avatar
Could be a bad caliper or pads that is binding, as I had this happen to me in my ol' '72 Vega
It could also be more tire wear, a poor contact patch or road conditions leading to the lock up. If not sure, swap the front wheels and take it for another drive and test it out.
Jazzer
Un-Official Suspension Guide | Choosing a new tire | Brakes upgrade ~ Speeding up slowing down | T-3650 ~ T-56 swap | Tire and Wheel Fitment Guide | The Kitty makes front page news
It would still be fun to have a truck that poops speed bumps in fast succession.
Jazzer The Cat is offline
post #3 of 6 Old July 26th, 2010, 09:27 AM Thread Starter
The right tire always locks up, no mater what condition the road is, does it always on wet roads, dry roads, and grass. Both tires seem to have approximately the same thread depth, going to swap pads, and wheels when I get home today. Just some process of elimination.
If the caliper were bad, wouldn’t it show signs of leakage around the cylinders, as I don’t see any fluids leaking from the caliper.
315's Crew Founder
My Track Videos
post #4 of 6 Old July 26th, 2010, 09:39 AM
Abyssinian of AX
Not necessarily
Years ago, when driving my Vega in the HS days. I had started noticing my car was pulling to the left on occasion. I was a dumb kid, so didn't pick up on the importance right away. One time, while driving down the highway on a hill, this began happening for a minute or two (of course, I was "fighting" the wheel and holding wheel a bit to the right to curb the pulling). When I hit the brakes, due to traffic ahead, the car pulled VERY hard to the right (remember I am holding the wheel to the right at this moment!) and then back to the left when I released the brakes. You can imagine how dangerous this could be
I found that my caliper was not leaking, but the piston was just jammed a bit and would not consistantly retract upon releasing the brakes. When it would "jam", I would have partial brake applied to the drivers wheel only and hence the pulling. When I would hit the brakes, the passenger side would grab much better due to heat-soak on the drivers side. This could be potentially pretty dangerous, so check her out good and PROVE the problem before you continue to drive.
Jazzer
EDIT: I had checked the rotor right away and found the drivers side to be VERY hot due to the binding caliper
post #5 of 6 Old July 26th, 2010, 09:44 AM Thread Starter
hmmm, going to have to check the caliper then, thanks
315's Crew Founder
My Track Videos
post #6 of 6 Old July 26th, 2010, 09:54 AM
TheUNZippee!'s Avatar
Calipers can stick or become completely seized without having a leak anywhere.
Also, if your abs is malfunctioning, that could cause an issue. Another aspect of this to consider is, under how much pedal pressure is this happening? If you have to stand on it to make this happen, it would be perfectly normal for one of the wheels, particularly the right rear, to lock up first due to weight transfer. When you smash on the brake pedal, the car lunges forward, transferring a great deal of it's weight momentarily to the front of the vehicle. And the right rear is quite often the one that becomes 'unloaded' first, which makes it easier for it to lock up.
So if that's the case, it could very well be that nothing is wrong with your brakes.
If this lockup is happening during normal braking, then disregard everything I just wrote and go cheeck your calipers and fix your abs. lol
TheUNZippee! is offline
Human Verification
LinkBack to this Thread: http://www.moddedmustangs.com/forums/99-04/175945-bad-brakes-one-wheel-locks-up.html
almost died. - RateMyBody This thread Refback December 19th, 2010 03:12 PM
