2 valve cylinder head removal and install - Forums at Modded Mustangs
post #1 of 22 Old July 27th, 2010, 06:43 PM Thread Starter
any tech bulletins out there for removing and installing cylinder heads on a 2 valve
stangempire82 is offline
post #2 of 22 Old July 27th, 2010, 07:20 PM
dannyboy281's Avatar
When I did it I went out and bought a chillton manual it helped me out.
2003 Azure Blue Mach 1
MGW, MAC Offroad X, Flowmaster Original 40's, Maganaflow 3.5" Tips, Anthracite 18x9's & 18x10's FR 500's wrapped with Nitto 555's, Eibach Pro Kit,
dannyboy281 is offline
post #3 of 22 Old July 27th, 2010, 11:28 PM
ajm
remove mid pipe, plugs, coils, injectors, fuel rails, tb/plenum, power steering pump, belt, intake manifold, valve covers, crank pulley, timing cover (and needed idler pully(s)
set engine to "safe mode"
remove timing chain tensioners, guides, cams
remove heads
reinstall torqing everything to spec/sequence and using assembly lube. You can find the torque specs/sequences online.
half decent set of metric sockets, in and ft lb torque wrench, and a flat or flex ratchet wrench for one of the ps pump bolts is all you really need if youre limited on tools
ajm is offline
post #4 of 22 Old July 27th, 2010, 11:33 PM
jivepepper's Avatar
There's lot's of resources on the net just takes some searching. I still have never bought a repair manual for my car and it's been 10 years.
665/541 WHP/WTQ 4.6L SOHC 2V ON 93 OCTANE PUMP GAS.
NO METH INJ., NO E85, NO RACE GAS, N2O BABY BOTTLES!
TRAP=POWER: 11.01 @135, IN SUMMER HEAT, 1350' TRACK, 315/35/17 DR'S
jivepepper is offline
post #5 of 22 Old July 27th, 2010, 11:55 PM
Send a message via AIM to hardhitter
remove heads
What about headers?
Vortech V2 Si
hardhitter is offline
post #6 of 22 Old July 27th, 2010, 11:58 PM
ajm
i was waiting for someone to say that, shorties will lift right out with the heads, and considering most dont have long tubes i didnt bother
ajm is offline
post #7 of 22 Old July 27th, 2010, 11:59 PM
but im screwed with long tubes right?
Vortech V2 Si
post #8 of 22 Old July 28th, 2010, 12:00 AM
ajm
yea youll have to pull them. thats one of the main reasons i wont get lt. i dont wanna fool with dropping the k and pulling headers for a quick few hr head swap
ajm is offline
post #9 of 22 Old July 28th, 2010, 12:01 AM
mustang_gtr_99's Avatar
books are cheap, look online for them. Dont forget to unbolt the heads in the right sequence as well. You can actualy warp the block during the procedure.
REAR SEAT DELETE FABRICATOR
"RSD pics in garage"
2010 Shelby GT500 DD/99 3V GT
mustang_gtr_99 is offline
post #10 of 22 Old July 28th, 2010, 12:02 AM
i know i kind of wish i never got them.. i really want to do heads
Vortech V2 Si
post #11 of 22 Old July 28th, 2010, 12:07 AM
ajm
no reason not to, theyll just add a couple hours to what would be a quick 3-4 hour job w/o them
ajm is offline
post #12 of 22 Old July 28th, 2010, 12:14 AM
I think it would take like 5 times longer than that for me to take the headers off and back on. I can't even see half of the bolts.
Vortech V2 Si
post #13 of 22 Old July 28th, 2010, 12:16 AM
ajm
Drop the k member and youll have easy straight up access to them for the most part.
ajm is offline
post #14 of 22 Old July 28th, 2010, 12:23 AM
I can really take the k member off and both headers and put it all back together in about 2 hours?
Vortech V2 Si
post #15 of 22 Old July 28th, 2010, 12:24 AM
I couldnt even imagine doing it while in the car.
post #16 of 22 Old July 28th, 2010, 03:02 AM
I never pulled my SLP LT's out or dropped my K-member when I took off my heads and reinstalled them. Im not sure if you remember me bitching of what a pita it was to bolt back on the LT's, I even had to heat up bend and grind some open end 10mm wrenches to get the job done. I got to admit though I had fun taking her apart.
post #17 of 22 Old July 28th, 2010, 04:17 AM
If you installed the long tubes while the heads were off then why were they hard to put back on?
Vortech V2 Si
post #18 of 22 Old July 28th, 2010, 07:08 AM
Mustang46's Avatar
There are only 8 bolts holding the k-member to the chassis and of course motor mounts.
I am so glad I got a tubular k-member. Made alot easier to get to things.
Mustang46 is offline
post #19 of 22 Old July 28th, 2010, 02:43 PM
How do you keep the motor from falling out or shifting position?
Vortech V2 Si
post #20 of 22 Old July 28th, 2010, 03:33 PM
I didnt install them when the heads were off. I had already previously installed them. So when the heads were back on again I had to rebolt the LTs to the heads.
Human Verification
